Rate of w455h electrolux washing machine motor control board
  • 351 Answers
SOURCE: Asko W640 Front Loading Washing
may be carbons in motor and or board
Posted on Aug 27, 2008
  • 50 Answers
SOURCE: how do you change the control motor board on a
Access is from the back of the machine. Motor control is on the left side tucked in beside the motor.
Posted on Feb 26, 2009
JAN_yuanjia
  • 470 Answers
SOURCE: Electrolux EW 1005f washing machine trouble.
try to go for the technician of washing machine, cuz you have the chance to replace it by replacing another board by there old unit that available and compatible to your washing machine
Posted on Mar 31, 2009
hattonhall
  • 349 Answers
SOURCE: MAH5500BWW "LR" Motor Control Board Failure
By the time you have finished mucking about it will likely cost you much more than it would to have a Techo come out to give you a quote for a few dollars to see if it is all worth it as regards your budget!
Posted on Oct 19, 2009
BIKER T
  • 909 Answers
SOURCE: is the memory board gone in my electrolux washing
Sad to say, yes "Replace the board". Quote no. on the board as there are newer updates as models change.
Posted on May 23, 2010
Electrolux w455h washing machine is comming error 45 moter not floow..what is the reason comming like this????thanks...
Family error code E40 is visible to customers and (could be E41,E42,E43,E44 and E45 only visible in service mode) means problem with open door or door interlock.
I suggest rapid reading alarm code when appliance is in normal operating mode (e.g. during the execution of the washing
programme):
Press and hold down START/PAUSE and any of the option buttons for at least two seconds: the LEDs initially switch off, and then display the flashing sequence corresponding to the alarm.
The alarm sequence continues as long as the two buttons are held down.
E41 - Door open
E42 - Problems of door closure
E43 - Interlock power supply triac faulty
E44 - Door interlock sensor faulty
E45 - Door interlock sensing circuit triac faulty
Possible causes:
Door interlock faulty, wiring faulty or PCB faulty.
Dado
Apr 05, 2016 | Electrolux Washing Machines
Eror 021
Try to check this video
May 11, 2014 | Washing Machines
Electrolux washer displaying error code E5E
Communication problem. Check the wiring between the Main
Control Board and the Speed Control Board. Wiring bad, correct wiring problem. Wiring good, replace the Main Control Board. If the problem is not corrected, replace the Speed Control Board.
Dec 28, 2012 | Electrolux 134743500 Fridgidaire Washer...
Washing machine, Electrolux just stopped working. It cannot be used now
Sorry but with such a fault it is virtually impossible for anybody on this FixYa forum to guess remotely what is wrong with your washer.
It could be internal wiring/plugs sockets, control panel switches, control PCB, water inlet control valves, door solenoid, main motor, drain motor etc..
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 12, 2011 | Electrolux Washing Machines
I have an electrolux washing machine model atfb6700 front loading bought in 2008 that does not spin. It will turn on the wash cycle but the motor buzzes in both cycles. Is it the motor or motor boards?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The motor is toasted...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 09, 2010 | Electrolux Washing Machines
A washing machine Electrolux EWF 1025 does not start up.
E50 is displayed if the there is no drum rotation. drum jammed not allowing motor to turn/ no circuit through motor(poss worn out carbon brushes) less likeley but poss short on motor relay on electronic board.
Jul 24, 2010 | Electrolux Washing Machines
E56 on electrolux EWF14108W
e56 is a motor or motor control circuit board fault
May 29, 2010 | Electrolux EW1000i Front Load Washer
Electrolux EWF 1495, spin does not work in quick60 cycle
it,ll will be a circuit board fault, probally the motor inverter board there is 3 pcbs in this model.
May 27, 2010 | Electrolux EIFLW55HIW Front Load Washer...
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
