Question about Vehicle Parts & Accessories
How to replace brake switch connector on 96 ford explorer?
    New Friend:
REMOVAL:
Lift the locking tab on the switch connector and disconnect the wiring.
Remove the hairpin retainer, slide the stoplamp switch, pushrod and nylon washer off of the pedal. Remove the washer, then the switch by sliding it up or down.
On some vehicles equipped with speed control, the spacer washer is replaced by the dump valve adapter washer.
INSTALLATION:
Position it so that the U-shaped side is nearest the pedal and directly over/under the pin.
Slide the switch up or down, trapping the master cylinder pushrod and bushing between the switch side plates.
Push the switch and pushrod assembly firmly towards the brake pedal arm. Assemble the outside white plastic washer to the pin and install the hairpin retainer.
Don't substitute any other type of retainer. Use only the Ford specified hairpin retainer.
Assemble the connector on the switch.
Check stoplamp operation.
Make sure that the stoplamp switch wiring has sufficient travel during a full pedal stroke.
how to replace brake switch connector on 96 ford e - 30e040be-8072-46f6-85da-9887df0d3153.jpg
Posted on Jun 04, 2014
96 Ford Windstar Brake stopped working out of no where. I replaced the bulbs and yet the brake lights still won't work. Any ideas?
96. Could be the brake switch died. Do you have a high mount brake light in the back? If so, does it work? If it doesn't it is the brake switch. mounted by the brake pedal. If it does, then it is the turn signal switch that needs replaced.
Sep 04, 2015 | Ford Cars & Trucks
Brake lights not working
check your brake light switch on rear of brake pedal, connector could be off or switch has to be replaced ( make sure to check all fuses first)if this is helpful please leave good feedback
Apr 11, 2013 | 1999 Ford Explorer
My 03 ford explorer wont go into park. It taks the other gears but not park. please help
Check the brake lights, if they don't work the system will not come out of part. if the brake lights are not working check the brake light switch connector, the wire breaks inside the connector and although the switch is connected there is not any actual electrical connection just plastic insulator over broken wires. The dealer sells repair connectors.
Nov 01, 2012 | 2003 Ford Explorer
How do i change the brake switch on my 1996 ford explorer
Remove the panel under the dash above the brake pedal, lock up and you will see the switch on the brake pedal arm, you must remove the retainer cip as shown in the diagram below, it is #2. The switch is #6 in the diagram, it is a 15 minute job. I will caution you that the problem here is often not the brake light switch but the 2 wire connector to it, the copper wire conductor inside the outer plastic insulator breaks, so use a 12 volt test light ($4 at Autozone) to verify that you have power into the switch, if you do check the dead wire out of the switch to make sure the conductor is intact before you replace the switch. You can easily do this by removing the connector from the switch and putting a paper clip in it to see if the brake lights come on, if they do the brake light switch is the problem, if not then go to Ford and buy a repair connector for the brake light switch. Solder the new connector on (if needed) don't use crimp connectors.
Oct 27, 2011 | 1996 Ford Explorer
I want to try to replace the brake light switch for my 02 Ford Explorer XLT. Can I do it myself with relative ease and can someone, step by step, walk me through it. Thanks!
YOU CAN REPLACE BRAKE LIGHT SWITCH BY YOUR SELF NOT A HARD JOB AT ALL.WHAT YOU HAVE TO DO IS REMOVE THE TRIM PANEL BELOW THE STEERING COLUMN.UNPLUG THE ELECTRICAL CONNECTOR AT BRAKE LIGHT SWITCH. TO LOCATE BRAKE LIGHT SWITCH LOOK UP AT BRAKE PEDAL ARM.YOU WILL SEE A SWITCH TOUCHING BRAKE PEDAL ARM.THAT THE SWITCH YOU WILL DISCONNECT UNPLUG THE ELECTRICAL CONNECTOR FROM BRAKE SWITCH. REMOVE THE COTTER PIN.AND DISENGAGE THE BRAKE LIGHT SWITCH FROM THE MASTER CYLINDER PUSH ROD AND FROM THE PIN ON THE BRAKE PEDAL. PUT EVERY THING BACK VISA VERSA.
Apr 13, 2011 | 2002 Ford Explorer
My 02 explorer wont shift out of park and the breke lights wont come on. The ford dealer said its most likely the brake switch. So I ordered one but I dont know where its located to replace it.
Look under the dash right above the brake pedal. It will be mounted to the lever the brake pedal is attached to. there will be a clip that needs to be removed and then the pin can be pulled out and the switch can then be removed.
Inspect the wiring on the connector. It is common for the wires to break right at the connector. If there broken you can try to repair or you can also get a pigtail from the dealer.
Oct 27, 2010 | 2002 Ford Explorer
My 1999 Explorer's brake lights don't work every time you depress
If you have replaced the switch then u need to test the connecter to the switch, the wires break inside the plastic outer insulation cover, u can buy a repair connector from Ford to fix this.
Nov 22, 2009 | 1999 Ford Explorer
96 Ford Explorer - Grinding on the driver side wheel and lots of noise. Pulls to the right and symptoms subside at higher speeds.
Do you have noise without braking? Could be the wheel bearings are shot if you have noise with or without braking, if you only have noise while braking you probally just need a brake job.
Jul 29, 2009 | 1996 Ford Explorer
My 96 ford explorer that wont start.
Your Transmission because Mine happen the same way
Mar 02, 2009 | 1996 Ford Explorer
Vehicle Parts & Accessories Logo
50 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
