Question about Fisher and Paykel Washing Machines
How do you replace the fuse on the control board
Model WA37T26G
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 142 Answers
The fuse on the CCU control board cannot be replaced.
Unless you would have a fuse that blew from age, replacing would not solve the reason why the fuse blew. A new one could equally blow when you start the machine.
Posted on May 17, 2014
Add clothes evenly, turn on get no water, water is turn on, makes a humming sound but is doing nothing? somebody can help please. Thanks
sounds like a valve fault. this fault can be caused by the electronic board not powering the valves also. check power to valves during fill, if power, replace valve. if no power replace board.
Oct 09, 2013 | Fisher and Paykel WA37T26G Top Load Washer
My machine wont power on. I checked the outlet and it is fine.
you have blown the fuse on the main board. you will need to check short circuits in your pump and motor, and for leaks onto any electrics, and then replace the motor control board (or try to replace fuse on board if other components look fine ie no burn marks)
Oct 06, 2013 | Fisher and Paykel WA37T26G Top Load Washer
Rotor wont spin
make this tests and fix it. God bless you
Thermal Fuse
If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work. The thermal fuse is usually located in the control panel on the control board or mounted to the bottom of the tank behind the lower panel. The thermal fuse can be checked for continuity.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Door Switch
The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Door Latch
If the dishwasher does not start, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
Main Control Board
The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel
If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad
Timer
The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Jul 24, 2013 | Fisher and Paykel Dishwashers
No power
test this steps and fix it.God bless you
Thermal Fuse
Door Switch
Door Latch
Main Control Board
Touchpad
Timer
Jul 22, 2013 | Westinghouse Dishwashers
Is there a fuse in the WL80T
Yes a 4amp fuse in the brown motor controller board.
Dec 29, 2012 | Fisher and Paykel WA37T26G Top Load Washer
Hi, I have a fisher and paykel washing machine model #WA37T26G and I noticed yesterday and today that the lights lit on the electronic board was 1,6,7,8...not sure if it was the same yesterday and not sure...
to work out the fault code go from right to left far right light is 1 the next is 2 next is 4 then 8, then 16,32,64,128. add up which lights correspond to your machine and then you can google that code and find what your problem is
Aug 19, 2017 | Fisher and Paykel WA37T26G Top Load Washer
Washing Machines Logo
224 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
