Question about Troy Bilt Pony 6.5 Hp Rear Tine Tiller
No gas is getting from the gas tank to the carburater
  • jlawson7 Jun 25, 2009
    I NEED A CARBURATOR FOR A TROY BUILT ROTOR TILLER.
    I HAS 8 HORSE KOLER ENGIN
  • 79 Answers
Check in line filter, if none, pull the line off at the carb, if no gas flow, blow into the tank to remove the restriction. If the tank is full of rust, remove it, dump out the gas, fill the tank with sharp rock pebbles the size of peas to a 1/8 inch of the bottom. Shake the pebbles around in the tank till all the rust is loosened. Dump out the pebbles, wash the tank throughly with water and pour out on a white rag until all rust and pebbles are not visable on the dump rag. Dry the tank in the sun, then reassemble. Remove bowl on carb to acertain fuel flow to the bowl, and it is also clean. If motor still runs inconsistantly, drop the center nut again that holds the needle jet, this should clear the problem.
Posted on Jun 24, 2009
There are 2 gas lines from the carburater going to the gas tank does it matter which one goes where?
The larger one is the pressure line to the fuel injection, the smaller one is the returned fuel line
Oct 18, 2016 | Homelite Garden
How do i connect gas Lines from tank to carburater
Your bike has been one of the most difficult models to look up. I have only been able to find 1 reference image to help you, but I think you have gotten this far already. There may be 4 lines, but only 2 of them should connect to the fuel tank. The only advice I can give you is, they all have different diameter hoses, so you can't put a little hose on a big connection. Same is true reversed. I hope this helps.
Aug 24, 2015 | 1986 Suzuki GSX 550 ES
I have a 1988 club car gas golf cart. I have done everything that I can think off. cleaned carburater, drained all fuel tank, replaced battery, replaced some of the gas lines. golf cart will only run...
When you say cleaned carburater did you take it all apart and spray carb cleaner through all the ports, it only takes the smallest debris for it to not run properly
Sep 07, 2017 | Cars & Trucks
What steps do I take to get a Yamaha EF1000 gas powered electric generator going again after it has been sitting around for years with gas in the tank? How do I drain the gas from the tank and carburater?...
You can disconnect the fuel line from the carb and drain the gas. It would be even better to then remove the fuel tank. If this is the generator with the large plastic tank, quite often the rubber gromet in the bottom of the tank with shout off vavle in it will deteriorate into a black gooey mess, and leak. If so that will have to be replaced. Clean inside of tank with fresh gasoline. Remove bowl from carburator and clean throughly. If you know how to work on engines, remove the carburator and clean throughly, notice how all springs and linkage were connected before removeal. Be sure all passage ways in carb are clean. Always use sta-bill in your gas.
Jul 23, 2010 | Yamaha Electrical Supplies
My '02 Gmc sonoma will crank but not start I checked the distributer cap and cleaned it with no luck I also checked the plug wires for fray's but they seem ok. Pooring a cap of gas into the carburater will...
Yes and yes, first I would check fuses and relays for the pump and the injectors also you can jump the relay socket and see if the pump energizes. one other tip is to hit the bottom of the tank, sometimes the vibration will knock the pump from its stuck state. it still needs replaced
Jun 20, 2010 | 2002 GMC Sonoma Extended Cab
2003 honda crf230f will not start.bike worked fine last fall.i put a new spark plug in it,cleaned the carburater,cleaned the air filter & changed the oil.it seems to have good spark but just keeps cranking...
IF you have a battery get a new one ; put in new gas ; super; dsid you ajest any screws on carb. You tight need to run a prime tank right to your carb to prime it; and then hook your tank backup new gas lines to your carb. Now break out with the WD40 to spray all switches for rust.
Mar 23, 2009 | 2003 Honda CRF 230 F
Truck doesn't start
there is a bleeder on the gas rail bleed some out on a rag and see if it was gas you filled up with or water i have run in to gas stations not fixing cracked tanks and as you know water floats on gas.start rag on fire gas is good if it doesnt light than you need to hurt someone heehe. ok now if your gas is good then the next step is to turn your ignition key on but not try to start and listen to see if you can here the fuel pump kicken in if not there is your problem is so then you need to replace your fuel line filter. good luck.
Nov 16, 2008 | 1991 Chevrolet K1500
Troy Bilt Pony 6.5 Hp Rear Tine Tiller Logo
256 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
