Numeric ups red light indicates - Computers & Internet
  • Ron Dufek
    Ron Dufek May 17, 2014
    Hi sridhar , I want to help you with your problem, but I need more information from you. What does it Indicate?
    Problem Solver:
  • 6 Answers
Red. Light means bad batteries
Posted on May 29, 2014
2 Suggested Answers
SOURCE: numeric ups with fault indication
Please Change Battery or Check the PCB Masfecter
Posted on Jun 17, 2010
Numeric ups red light indicates?
1. low batery (not proper charging due to bad or not proper acid level)
2 short circuit
3.inner ICs needs to change
Apr 26, 2014 | Computers & Internet
Numeric 600 ex redlight indication problem
i m the service technician of computer, cctv, printer ,monitor, ups etc.. numeric ups 600 ex problem red light and long beep .......
the problem is ups transformer ,, change or rewinding the transformer problem will be solve
Mar 02, 2014 | QVS NetStar (UPS650A) UPS System
KX-T3250B; the 5 red indicators on the upper right corner are flashing...
these 5 leds lights when phone is out of program. every phone should have his own indicator showing (when handset is off) his position in chain of phones. to make them stop flashing do following:
1. push and hold "PROGRAME" button until "MUTE" indicator lights (you'll hear beep sound).
2. push one "1" to "5" button on numeric keyboard depending on telephone's position in chain (must be unique).
3. push "MEMORY" button.
Now when you pickup handset only one indicator should light.
sorry, my English is not perfect :-(
Feb 04, 2011 | Panasonic Lands Phones
Zeppelin indicates normal lights.. Off=red , on =blue But does not play. Trouble began when machine began by playing only intermittently. Then not at all. If the unit is left to sit with I-pod connected,...
report to b and w, sounds like the arm or the ampifier is playing up. when they check it, they will also make sure you have the upd to date power supply which has been bought in to resolve the numerous red light issues.
Aug 07, 2010 | B&W Bowers and Wilkins Zeppelin iPod Music...
Numeric UPS not working
when i on my ups it is indicating to fault showing a red light and giving a long beep sound and no output voltage is coming from it do i need to configure?please help me
May 10, 2010 | Opti -UPS BackUp-Time 525BT (UPS-525BT)...
Numeric keypad does not respond.
make sure that the num lock is on. There are 5 indicator lights on the left side of the power button, the first indicator on the left is Num Lock, make sure this is lit up.
Mar 30, 2010 | Dell Inspiron 6000 Notebook
Philips universal remote codes
Hi Troysingleto. The code can depend on what model of URC you have. According to a site I found by Googling, the code for Apex TVs on one common URC from Philips is 044. Here are the steps to input it directly:
1. Press and hold the Code Search button until the red indicator stays on. Release the Code Search button.
2. Press and release the desired mode button (TV, DVD, etc). The red indicator blinks, then stays lit.
3. Enter the 3 digit code (044) . Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
4. With your device on, press CHANNEL Up. If the device responds, no further programming is required. Note: If some buttons do not operate your equipment, try one of the other codes for your brand.
If that code does not work, you can still find the code using this manual procedure first posted on FixYa by cptnkirk4064:
1. Manually turn on device to be controlled.
2. Press and hold the "Code Search" button until the red indicator light stays on, then release it.
3. Press and quickly release the desired code button (TV, VCR, etc). The red indicator light should blink once.
4.Press the "Channel Up" button repeatedly (up to 300 times) until thedevice to be controlled changes channel. The red indicator light shouldblink off with each button press. If you accidentally overshoot therequired code, press the "Channel Down" button to backtrack through thelibrary until the device changes channel. Pressing "Channel Up" changesdirection again.
5. Press and release "Mute" button to install the code.
If you wish to actually identify the code once this has been done, this is the procedure:
1. Press and hold the "Code Search" button until the red indicator stays on. Release the "Code Search" button.
2. Press and release the desired mode button (TV, VCR, etc.). The red indicator light blinks and then stays on.
3. Press and release the "Code Search" button. The red indicator light goes off.
4.To find the first digit for the code stored under the mode key pressedin "Step 2" press each numeric key from 1-9 in turn. When the redindicator light blinks off, the number you pressed is the first digitfor the code you are searching for.
5. To find the second digit,repeat "Step 4," this time when the red indicator light blinks off,this is the second digit in your number.
6. Repeat again for the third digit in your code number.
Once I find out the code for my TV or DVD player, I write it on a small piece of paper (make sure to note which unit code is for!) and tape it to the inside of the lid to the battery compartment for future reference.
Best of luck!
Feb 13, 2009 | Apex Digital AT2002S 20" TV
Lost owners manual
I do not believe this is available on-line, but have some info that might help you use the remote.
To Search For A Code:
  3. Press and quickly release the desired ode button (TV, VCR, etc.). The red indicator light should blink once.
  4. Press the "Channel Up" button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator light should blink off with each button press. If you accidentally overshoot the required code, press the "Channel Down" button to backtrack through the library until the device changes channel. Pressing "Channel Up" changes direction again.
To Identify The Code That Was Found:
  4. To find the first digit for the code stored under the mode key pressed in "Step 2" press each numeric key from 1-9 in turn. When the red indicator light blinks off, the number you pressed is the first digit for the code you are searching for.
  5. To find the second digit, repeat "Step 4," this time when the red indicator light blinks off, this is the second digit in your number.
I hope this helps out,
Chris
Dec 23, 2008 | Philips PH-DVD5 Remote Control
Numeric ups with fault indication
Oct 14, 2008 | QVS NetStar (UPS650A) UPS System
Code for apex tv through philips universal remote
Go to www.urc.philips.com/
Follow the steps..its easy. It will ask for the model of your remote which you will find where your batteries are located..The code I used for my APEX tv was 0023.. to load the code first hold the setup button until the red light stays on..then press tv or whatever mode you are setting up..then enter the code and if the red light goes off it is the right code and you should then press channel up to see if it works...If this code doesn't work the site above offers other codes.. Hope this helps!!
Aug 30, 2008 | Apex Digital ADV3800 DVD Player/VCR
Computers & Internet Logo
140 people viewed this question
David Payne
David Payne
