Question about Electronics - Others
My sandisk micro sd card of 8 gb. when inserted to laptop showing that it got corrupted & to use it i have to format & all data in it will be erased. plz provide solution as it contains my valuable data.
  • 36 Answers
I'm sorry bro there is no way to help you out now.
The disk has been corrupted meaning that a single or several bits may be dislocated. I has to be formatted.
I would suggest to keep a 2nd copy-backup always when you are storing data on optical or digital disks.
Posted on May 17, 2014
  • 398 Answers
First off we need to make sure that it's the Card and not your computer. Does your machine read other cards? If so go to the next paragraph. If you don't have other memory cards to try to find another computer to try your card in., or if you can read your card in another computer, or other cards can't be read in your computer then your computer has the problem, and I would reinstall the drivers.
If you card is the problem the only thing to try is to clean the contacts. Lay the card down on a flat surface; gently rub the contacts with a pencil eraser to buff the contacts. Be careful not to use as much force as to damage the contacts.
But finally, you've probably heard this before but, "All media goes bad." Removable media is particularly vulnerable due to the way most people handle it. I have all my important files in at least 3 locations. But I too learned this lesson the hard way.
  • 94 Answers
SOURCE: SanDisk Micro SD Card problems.
the card needs to be formated on n73.
if still not work than the card is faulty
Posted on Jun 12, 2008
SOURCE: Micro SD 2 GB just stopped working
I had this same issue added music to my card did a safe remove from my comp. placed in phone and it stated "No memory card inserted" and wont read in adapter in computer Im so Sad i lost all my pics/memories :( it just means that the Card is Fried (Burnt Out) no way to fix this their just like SIM cards In 3G phones and if the copper bars get scratched or bent just the slightest bit it kills the SD card.
Posted on Oct 29, 2008
  • 3 Answers
SOURCE: Formatting errors on 2 memory cards - old 1gb & new 4gb micro sd sandisk
http://www.sdcard.org/consumers/formatter/eula/
Go here follow the instructions to get a formatter program
Posted on Dec 29, 2008
SOURCE: My Mac doesn't reconize my 8 GB SanDisk microSDHC memory card
Go into Finder-preferences and select under devices: external disks
Posted on Feb 24, 2010
  • 109 Answers
SOURCE: sandisk 2gb sd card unable
Hi
Please follow these steps to recover the data from your memory card.
1. Go to http://www.recovermemorycards.com/
2. Download the software from the website.
3. Install it on your computer and recover the data from memory card
Posted on Jul 31, 2010
FORMATEAR MICRO SD HC 8GB
Depending on your laptop, 8 GB SD cards may not work. That said, insert the SD card, open Computer, right click on the SD Card icon, format.
Dec 13, 2012 | Toshiba Computers & Internet
Sandisk ultra sdhc card won't record in my canon digital camera. i get a memory card error
All you have to do is
Step One
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Insert micro SD
3. Open EASEUS Data Recovery, choose Complete Recovery - Next
4. Select the drive micro SD - Next
5. Save the data to the hard disk (max. 1GB)
6. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4, 5)
After all data is secure, do the process repair micro SD
Step Two
The first alternative - use the software HP Drive Key Boot Utility
Using the HP Drive Key Boot Utility, for Win XP
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe - select Install.
3. Insert micro SD
4. Then, open the program "HP Drive Key Boot Utility" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
5. Remove the micro SD from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, for Win Vista or Seven
2. Then, double click the file cp006049.exe - select Extract
3. Insert micro SD
4. Then, double click file hpdkbu.exe - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Insert micro SD
3. Open program HDD Low Level Format Tool, select micro SD - continue
4. Click S.M.A.R.T - click Get Smart Attributes
5. Click LOW LEVEL FORMAT - click Format this device
6. Wait until the process is complete - press OK
7. Remove the micro SD from the USB port, then insert it again.
8. Quick format micro SD (FAT file system)
9. Restore all data, to the micro SD.
I hope this information helps.
Oct 15, 2011 | SanDisk 2GB microSD Memory Card
I have locked my memory card and forgotten the password. Format card also requires password and my laptop cannot read it. Please help.
All you have to do is:
Step One:
2. Choose Complete Recovery - Next
3. Choose the drive micro SD - Next
4. Save the data to the hard disk (max. 1GB)
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4)
After all data is secure, do the process of removing the micro SD password
Step Two:
3. If you are using Win XP, double click the file cp006049.exe - select Install.
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extrack.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Finish.
6. Remove the micro SD from the USB port, then insert it again.
7. Quick format micro SD (FAT file system)
8. Restore all data, to the micro SD.
2. Select micro SD - Continue
3. Click S.M.A.R.T - click Get Smart Attributes
4. Click LOW LEVEL FORMAT - click Format this device
5. Wait until the process is complete - press OK
I hope this information helps. Thank you for using FixYa!
Oct 11, 2011 | SanDisk 2GB microSD Memory Card
My Sandisk 'Wake up your phone' adapter & the micro one won't let me add music or anything else. It says that the disk is write-protected. Help?!
Micro SD write protect means there is damage to the firmware. Micro SD write protect, the data can be saved. Follow these steps:
Step One
After all data is secure, do the process repair micro SD.
Based on experience, the following methods can be used to repair the damage: RAW file system, used space 0 bytes, free space 0 bytes, micro SD can not be in the format, micro SD corrupt. To write protect a micro SD cases, 40% probability of success. But, you can try it. Good luck.
Step Two
Using the HP Drive Key Boot Utility, the first way
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extract.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
Using the HP Drive Key Boot Utility, a second way
1. Open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - select Backup / Restore - click Restore - From filename, click Browse - Look In. Find the file initrd.img
2. If you are using Win XP, the location of the file in C: \ Program Files \ Compaq \ hpdkbu \ flash \ initrd.img - Next
3. If you are using Win Vista or Seven, the location of the file in the folder where you extract the files cp006049.exe. After the file is found, press Next
4. This process, will take a very long time, so you wait. This way you do for a capacity of 2GB. This involves when, the first way did not work. If the process runs smoothly, the chances of success, but if the process is running very slow, the possibility of failure and immediately stop the process. If you are unsure, or afraid to make mistakes, you should not do it this way.
5. After the process is complete, remove the micro SD card from the USB port, then insert it again.
Oct 10, 2011 | SanDisk 2GB microSD Memory Card
My 1 gb micro sd card is corrupted and my nokia E63 phone and DELL inspiron is not recognising it
    • 1 If your aim is to repair a corrupted SD card so that you can use it to store files then proceed to step #2.
      If your aim is to recover the files on the SD card without erasing them, proceed to step #5.
    • 2 Insert the SD card into a digital camera card slot and choose to format your card. If this doesn't work then move on to the next step...
    • 3 Place the SD card into your computers SD card slot.
      Right click on the SD card drive letter IF it appears and choose to "format."
      If this doesn't work, proceed to the next step...
    • 4:You will need to go to the website
      Here you will download, install, and run the program to format your SD card. This is the most advanced step of the three, but most likely to work 99% of the time.
    • 5
      If you want to recover files ON your SD without erasing them, then you need to download and run the software on this site.
      http://www.cgsecurity.org/wiki/TestDisk_Download
      This is the best free software available for this type of problem.
Jun 02, 2011 | Maxell 4 GB Class 6 Micro SDHC Card with...
I have forget my memory card password which use in nokia 2690
If you lose or forget the password for your phone's memory card, there is no way to recover the password or access the data, even by taking your phone to a Nokia Care Point.
However, you may still be able to use the memory card if you can successfully format it. Formatting the card will not work in every case.
Formatting will erase all the data on the card.
To format you memory card:
1) Select Menu>Memory. Your phone shows the details of the memory card.
2) Select Options>Format memory card.
Thanking you
davevipul197
May 11, 2011 | SanDisk 2GB microSD Memory Card
Trouble in formatting my SD micro sd for my lg chocolate cellpfon
use some other card reader for the purpose and format it from there.
Feb 14, 2009 | SanDisk 2GB microSD Memory Card
Adding a 8GB MICRO SD card to the Sansa e260
I read somewhere that a 4 GB Micro SD card is the largest you can put in the SanDisk Sansa E260 expansion slot. It's maximum capacity is 8 GB, with internal + external memory put together. This is from what I've read. Hope this helps.
Sep 20, 2008 | SanDisk Sansa e260 MP3 Player
Electronics - Others Logo
37 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
