Question about Bissell Vacuums
Proheatpet formula tank leaks excessively when installed
    Problem Solver:
  • 7 Answers
BTW...if it is not a crack...it could be the seal at the bottom of the holding tank. Mine has a lil rubber seal and pin. Fill the tank part way, use your finger to play with that pin n seal over the sink...see if you can find a position where the water stops dripping out. I have to do that when I fill my tank...free fix wihtout having to spend 30-50 on a replacment tank
Posted on May 31, 2014
  • Mommy Fix It May 31, 2014
    I also see Bissell serves the seal separately (a good thing)http://www.vacpartswarehouse.com/Bissell...
    E6000...best self leveling sealant I know of ...cost around 5.00 can be purchased at Michaels or Hobby Lobby or try your local WalMart (save on gas n time-call first). NOTE:if you cannot access interior of tank...use a long straw to flow the glue down. McDonalds has wider straws than normal that work nice for this Will self level just make sure you have the tank at the right angel. On exterior scuff it and apply a coat of E6000 as well. Also make sure interior is dry and free of cleaning solution residue Walmart Amazing 6000 Craft Glue 2 oz
How do i get my bissell to stop leaking water?
The rubber gasket on the bottom of the 2-in-1 tank is probably lodged in the base of the unit. It should be connected to the nozzle on the bottom of the 2-in-1 tank. You can pull it out of the base and reattach it to the tank. This should stop it from leaking. The formula tank on the back has the same gasket so you can pull that out and see how it should fit on. Hope that helps.
Apr 05, 2012 | Bissell 2X Proheat 9200 rug cleaner
How do you put the soultion in and how do you use it
Here is link to the users manual:
http://www.bissell.com/assets/0/132/134/228/14489708-7c37-4678-a90a-79e6825ef104.pdf
but real quick, heres the essentials:
Fill the SmartMix/formula tank
Lift the formula tank up and out of the machine base.
Fill the formula tank
by first unscrewing the cap
and insert. Always use genuine BISSELL formulas
to maximize cleaning and for the safety of your
machine. Fill formula up to the line and replace the
cap and insert. Place formula tank into the slot in the
back of the machine for a snug fit.
2b.
If using the BISSELL 3X Concentrated Fiber Cleansing
Formula: Add 3 capfuls of 3X Concentrated Fiber
Cleansing formula to the formula tank, and then fill
with warm water to the line.
Note: If bottle leaks, check for proper positioning
of red gromment and straw insert.
Good luck and thanks for using FIXYA
Please rate us if you are happy :)
Apr 06, 2011 | Bissell 1697-7 Powersteamer Pro Deluxe...
I have a Bissell Proheat 2x cleaner which has worked perfectly on every occasion. Today I filled the machine as usual with water and formula and switched on, the motor ran, the lights were on and the...
Please check the following with liquid in both tanks.
- Check to see if the machine will spray through the hose with the setting on tools. If it does, the pump is fine. Continue troubleshooting.
- Check for debris on spray tips. Clean them with a soft brush (on old tooth brush works well). The spray tips may be lifted out for easier access.
- Ensure the tank lid is properly attached to the bottom of the tank. To attach this properly, remove the Water Tank from the machine. Hook the front window onto the lip of the bottom container and then allow the window with lid to cover the complete tank. Secure the latch on the back of the bottom tank to the back of the tank lid. THE TANK LID CANNOT BE ATTACHED PROPERLY IF THE BOTTOM TANK IS ALREADY INSTALLED IN THE MACHINE.
- Check the bottom of the Water Tank and the Formula Tank to make sure each has a red auto-load gasket attached. Make sure the Water Tank and the Formula Tank are seated properly. Depress the x on this gasket to ensure this depresses and release back out. Liquid from the tank should dispense.
- Remove the handle completely and re-attach. Once the handle is re-attached, re-attempt to spray.
If the machine continues to not spray, check the following:
REMOVE THE COLLECTION TANK:
• Make sure the unit is set to water rinse
• Remove the smart mix bottle and fill it with water only
• Place the smart mix bottle into the collection tank reservoir
• Run the unit and try to spray. If the machine sprays, you will be able to see the water level decreasing in the smart mix bottle and you will need to replace the bottom tank. It is possibly warped.
If these suggestions do not resolve the issue contact BISSELL Consumer Services.
1-800-237-7691
Mon-Fri: 8am to 10pm ET
Sat: 9am to 8pm ET
Sep 27, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
We cannot get the water and soap to dispense in out Bissell steamcleaner
Check to ensure there is liquid in the water tank and the formula bottle.
Note: This machine will spray with liquid in the Water tank only if the machine is set to the Water Rinse setting. On any other setting, you need to have liquid in the formula tank as well.
If no: add liquid to the Water tank and the Formula tank.
If yes: check each of the following....
-If everything is seated and attached properly, prime the machine by turning off the power, waiting one minute, and then turning the power back on and depressing the trigger on the handle.
- If priming the unit fails to fix the problem, remove the handle completely and re-attach. Once the handle is re-attached, re-attempt to spray.
Aug 13, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Pressing the handle to release cleaning solution does nothing. The cleaning solution does not come out. Carpet is dry.
If your machine continues to not spray, please take your machine to a local BISSELL Authorized Service Center for inspection and repair. BISSELL provides you with a one year warranty for any defective or malfunctioning part.
To locate your nearest BISSELL Authorized Service Center, go to www.bissell.com. Click on the Customer Support tab near the top of the homepage and enter your zip code in the Service Center locator box to perform your search.
You can also locate a Service Center by phone, 24 hours a day, by calling 1-800-237-7691 and choosing option #1.
Aug 03, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
My bissell steam cleaner will not spray any water
Jun 15, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have the Bissell heat pro 2x 8920 and the water doesn't come out. The soap just mixes with water tank and the carpet stays dry
Jun 14, 2010 | Bissell 8920 ProHeat 2XTM Upright Vacuum
I have misplaced the directions for the Bissell powersteamer powerbrush. I need the directions for filling the u tank etc.
Release the handle and lay the machine handle
back to access the Tank.
2. Remove the Tank from the base of the machine by
lifting the Tank carry Handle.
3. Carry like a bucket to the sink. Rotate the Handle
forward to unlatch the lid. Lift off and set the lid aside.
4. Fill up the Bladder with clean hot tap water.
*Do not boil or microwave water as it can
destroy the Bladder.
5.
Replace the top of the Tank by matching the lid
and tank edges. Handle must be in the forward
position in order to replace lid. Rotate the handle
to the carrying position to latch the lid.
Note: Remember to secure the lid and test to
make sure it is secure before picking up the Tank.
6.
Place tank into machine base, seating firmly in place.
Rotate tank handle back into latched position. Bring
machine handle back into upright position.
1.
Lift the formula Tank up and out of the machine base.
2. To fill the Formula Tank, first unscrew the Cap
and Insert. Always use genuine BISSELL formulas
Cap and Insert. Place Formula Tank back into the
base of machine, making sure it is seated securely.
of red gromment and straw.
Apr 29, 2008 | Bissell 1699 ProHeat Clear View Upright...
Vacuums Logo
20 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
