Question about Hotpoint Washing Machines
Hotpoint washer agitator barely moves ,its like its washing on delicate for every cycle ! its brand new !
  • 319 Answers
SOURCE: maytag washer, lat9606aae only works in delicate cycle and hand washable
Replace it
Posted on Jan 04, 2008
  • 20 Answers
SOURCE: Washer fills and spins but does not agitate
Im sorry to say, it sounds like the transmission in the washer may have gone out, the unit it self sits at the bottem of the main agitator shaft under the the tub, you may be able to have this replaced, but shop around for the right price.
Posted on Jan 27, 2008
  • 185 Answers
SOURCE: washing machine agitator & drum spin during wash cycle
check the dogs in your agitater
Posted on Mar 25, 2008
My girlfriend's LAT9704 had the EXACT same problem. I replaced the timer module an now it works in all cycles. Part wasn't cheap though - $80
Posted on Apr 09, 2008
SOURCE: agitator will not work on wash cycle
Order the upper aggitator clutch/dog kit $15. Now top half of the aggitator is doing its thing just like the bottom half. Hope this helps someone else too.
Posted on Oct 28, 2008
GE Profile WPRE6100G tub spins while washing
My parent's Hotpoint did the same thing!! The brake on the bottom of the tub is not engaging! It needs replaced!!
May 15, 2012 | GE Profile WPRE6100G Top Load Washer
VBXR1090BOWW The agitator barely moves. Shortly after the wash cycle begins, it seems as if the motor is struggling, the agitator barely moves, and the water turns brown. When in the spin cycle, the...
www.seiaarons.com/GE%20VBXR1090DCC.pdf
http://www.acmehowto.com/howto/appliance/washer/washer.php
It sounds like you may have a faulty motor or drive? You will have to perform the troubleshooting steps in the manual, to check, there is an inspection panel, on the machine, remove the fastenings and look inside there should be a maintenance Sheet, this will help you isolate your problem. Of course if you cannot or do not wish to do it, then I recommend a professional be engaged, always ask for a "Quote" before proceeding with any repair.
Jun 15, 2010 | Hotpoint VBXR1090B Top Load Washer
Explanation of Wash Cycles
Sorry but you only have the one speed on this particular brand. Perm and short are just less time. The best thing to do is always use large water setting and less delicates in the load on a short cycle to compensate for the speed and protect your delicate fabrics.
Jan 27, 2010 | Whirlpool ET8CHEXSQ Dryer
The agitator is barely moving - I am not sure if is fully engaging during the wash cycle? How can I check it out?
If the agitator is working it will move slightly, then back - over and over again and cause the water to, well, agitate.
If you have the machine set to delicates it might not come on full force.
Usually you can check it out by opening the lid during a wash cycle.
If it's barely moving then you might have drive/belt issue.
Dec 07, 2009 | Whirlpool LSQ8000 Top Load Washer
Wash cycle won't start after the tub fills up with water.
There's no delicate or regular spin or agitation If your washer doesn't spin or agitate on either the delicate or regular cycle, check these:
Selector switch
Clutch assembly
Drive motor
Selector switch If your washer has a selector switch on the control panel, make sure the button for your selection is pressed all the way in, or set properly.
Clutch assembly Many GE®/Hotpoint® washers use a clutch and an automatic shift lever. This assembly is quite complicated. If there's a problem with it, you probably should contact a qualified appliance repair technician.
Drive motor Many washing machines have multiple-speed drive motors. Though it's uncommon, the drive motor may work fine on one speed but not on another. If the drive motor has failed on one speed, you need to replace the entire motor.
May 07, 2009 | Washing Machines
Agitator not working properly
if the agitator barely moves, sounds as if yo have a bad set of agitator dogs, part number 80040. if you removeth agitaotr,(7/16 screw) down the center ofthe shaft. yo can removeth efabric softener dispensor by hitting with the palm of hand. after removing the agitator, it can be split in half to reveal hte "agitator dogs" easy repair problalbby about $20 and 30 min tops
Feb 15, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Will only work on cycle, will not agitate in the other cycles
Thanks for your question You say it works on one cycle but not the other lets sat you start a regular wash ,the washer should fill ,wash for the minutes you have set, pump out the water #spin , Stop fills & rinse stop pump out water &spin If you try a delicate cycle and it does not do what it did on regular cycle . You have a timer problem . Thanks for your question hope i helped you solve it . THE APPLIANCE DOC
Sep 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 70 series washer
the agitator dogs are problably remove agitator cap remove bolt holding agitator in ..dogs are part #80040
Jul 19, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
12 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
