Question about Welding Tools
Miller trailblazer 302
Trying to find the serial number for the starter in order to replace it.
4 Suggested Answers
luxur4
  • 92 Answers
SOURCE: I have what looks like a selnoid a black coil with
Contact your local Miller welding supplier or miller direct they are good people who will give you all the held you need
Posted on Jan 27, 2010
luis_david
  • 407 Answers
SOURCE: I need the part number
Hi:
Part number for the ground output terminal is MIL 039046, list price is $24.34.
For the Big Blue need to specify what engine/model does your machine has or serial number.
Posted on Aug 08, 2011
  • 1212 Answers
SOURCE: trouble shooting miller trailblazer 302 engine powers out when air arcing
Blow cabinet clean of dust and check connections in cabinet and handle. first, Then check the wires to the step up solenoid and make sure they have sound connections and that solenoid is mounted securely. If you do much outside at night, have someone watch with the cabinet open and see where it sparks when the engine drops speed. Int he dark, even small sparks you would not see inthe daytime or the shop apper reasonably well.
Posted on Sep 25, 2012
Miller trailblazer 302 diesel welder, full tank of diesel, gauge shows empty, starts but then stops
the Trailblazer 302 diesel, has a fuel level sensor that tells Control PCB2 if there is fuel in the tank. PCB2 sends a signal to CR1, which lets voltage go to the Fuel Solenoid. If the sensor is bad, PCB2, CR1, or the fuel solenoid, fuel will not get to the engine. I am including the manual for the Trailblazer. Now keep in mind, the circuit may be a little bit different based on serial number. In the center of page 46 will be the fuel circuitry. Good luck https://www.millerwelds.com/files/owners-manuals/O217454U_MIL.pdf
Sep 05, 2017 | Miller Welding Tools
My TB 302 cranks and runs at high idle does not idle down. I have power at all recepticals but no power at welding leads. I have checked all breakers and fuses, they are ok. what do I need to do next
there are a few things you can check on your machine,
make sure your machine is not in the remote control position, make your process switch is in the electrode hot position, the trailblazer has three slip rings, make sure the carbon brushes are not "stuck" in the holders, there are 2 circuit boards in your machine, make sure the plugs are properly inserted into the receptacles and making good contact, also make sure your ignition switch plug is clean and making good contact
Mar 17, 2016 | Miller Trailblazer 302 AC/DC Welder...
Miller trailblazer 302 it has 110 volts but no 220 volts
Both sets of the 120? If both of those are there (all 4 outlets), then the machine is producing 220v. So get a flashlight and look into the holes on the 220 receptacle, or check the wires on the backside of the receptacle. All that 220 is, is two 120 volts out of phase.
Feb 19, 2015 | Miller Trailblazer 302 Welder Generator...
Operation manual for a miller trailblazer 302 stock number 907217
www.millerwelds.com have the serial number handy. Click on service, then owners manuals and follow the directions.
Oct 07, 2014 | Miller Trailblazer 302 Welder Generator...
I have miller 302 everything working good but stick weld not working
Make sure your both selector click ( AMPS range and then CURRENT)
Good luck .Patrick
Feb 17, 2014 | Miller Trailblazer 302 Welder Generator...
I have miller 302. Outlet power working but stick weld not work
Check your machines fuses. For location of fuses look into your owner's manual.
I need the part number for the termial output and ground for my 302 diesel Trailblazer and a part number for the starter motor for my 400P Big Blue Diesel. Also any suggestions on spare parts I should...
Hi:
Aug 07, 2011 | Miller Trailblazer 302 Welder Generator...
Where do I find a replacement part for exhaust?
Go to your nearest welding supplier, if you have Praxair near you gi there and ask the saleman to pull up the part brakdown and find the right part number, saleman will ask you for serial number on the machine, it takes only two days to get it from factory.
Jan 09, 2011 | Miller Trailblazer 302 Welder Generator...
Serial #JK642666 What is the age
According to Miller's chart your machine was manufactured on July 1989.
Dec 28, 2010 | Miller Trailblazer 302 Welder Generator...
Welding Tools Logo
26 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
