I have a samsung plano tv. I am unable to change the channel. When we change the channel, the last channel remains the same over all the channels
    Top Expert:
  • Televison & ... Master
  • 75,581 Answers
Try a hard reset to this TV. To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 20 minutes or so. This must make it a hard reset. If it doesn't help you, its main system control memory IC is faulty, and should be replaced. Contact any service technician. This IC is not a hard to get one. But, replacement and re-configure is somewhat difficult to a normal user. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
Posted on May 17, 2014
snakehead
  • 1074 Answers
SOURCE: Can't change Proline TV / Video combo to scart
visit www.partstore.com to purchase a originald remote for your set if they do not have it they can get it for you.good luck
Posted on Apr 08, 2007
  • 1694 Answers
SOURCE: remote control problems
Feed cable signal directly to tv(no BOX) activate auto-program for channel memory.
Posted on Oct 02, 2007
chris5563
  • 37 Answers
SOURCE: How to disable parental lock
You can try these codes 2211 or 3308 if they do not work you will need to reset the unit. You will need to unplug it for 45 minutes that will reset the TV to factory settings. Then the pass codes I provided should work.
Posted on Nov 07, 2007
SOURCE: Black box appears in TV screen
The problem with the black box happened to me. I had pushed the subtitle button on my remote by mistake. Interestingly enough, as soon as I pushed the SUBTITLE key again, on the remote, the black boxes disappeared.
It also says CC which means closed captioned-- So the bottom on my remote is Subtitle, and then on the subtitle button is cc...
I hope this helps
Posted on Oct 17, 2008
dblak305
SOURCE: unable to get tv to aux screen
Purchase a new remote from orion.$10 for the remote + $5 for shipping and handling. Call customer service at 1-800-289-0980.
Remote usally arrives within 4 to 5 days.
Posted on May 11, 2009
I have direct tv and accidentally changed the channel on the Samsung tv manually now I don't get my direct tv what is the defalt channel fo the samsungg
Press the last channel view button if you did that only the once, it should go back to the channel it was on prior to the "accident channel". I hope this helps, Jesus loves you, John 3:16-17 (KJV)
Jun 21, 2018 | Samsung Televison & Video
Using a samsung remote AA59-00312D on my samsung plano tv, how do i switch or change to watch on cable, its on auto mode now
The TV/AV button on the remote should work. If not, Check the remote control for its infra-red emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Oct 03, 2014 | Televison & Video
Samsung plano dnie jr flat screen tv : channels does not change with remote or by tv button, sometimes no picture is displayed the screen becomes blue
Main system control memory IC fault. Contact any service technician to replace it. This is not a work, that a user can do with ease.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 13, 2014 | Samsung Televison & Video
Missing cable channels
You need to contact your cable service provider about this, it is a signal issue not a TV issue.
Apr 24, 2017 | Samsung SyncMaster Televison & Video
Panasonic omnivision TV VCR combo connected to cable box unable to change channels with either remote . When up or down channel buttons are pressed it goes to "line" when channel numbers are pressed it...
cable box needs connected to the antenna in on the vcr..the setup is ..cable box..vcr combo ..tv ..unless your tv has multiple inputs like ours..most of the new ones require a digital signal..it may reqiure a converter box..
Jan 11, 2014 | Televison & Video
Samsung Plano TV lock. Can't play DVDs. How to unlock?
There may be a ratings lock in the dvd setup menu that is preventing certain ratings from playing. Go to the settings and check to see what level they are at and set them to an appropriate level. If it is a burned DVD it may not be finalized, or in a wrong format.
Aug 05, 2009 | Televison & Video
Wharfedale LCD3210AF Television- Digital problems!
Well there is still a problem with the TV. I found that by unplugging the power cable that the digital channels worked. But, when I turned the TV on today the problem had returned, I had to take out the power cable again!
Feb 11, 2008 | Televison & Video
Cannot change channels in digital mode
Solution that worked for me:
Beware: Although the process should be safe, it technically voids your warranty.
Enter the service menu:
1 - turn of tv with remote
2 - press and release in the following order on the remote: Info, Menu, Mute. Make sure remote is pointing at the tv
3 - turn on the tv from the remote
4 - you will see the service menu. using the down arrow on the remote select the Reset option. Using the right arrow button at this point will do a hard reset.
5 - Wait a few seconds, turn TV on
6 - you will have to rescan analogue and digital channel but it should be working now.
Jan 29, 2008 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
