Question about Friedrich QuietMaster Electronic SS12J30D Air Conditioner
Indoor ac fan wont turn on - Friedrich QuietMaster Electronic SS12J30D Air Conditioner
Myblowermotor on my goodman furnace will only work when the heat is turned on when i turn on the ac the blower motor wont kick on but the the ac unit turns on i can here the outside unit working
Is this a new tstat? How about trying cooling with fan in on position , what happens? What is the model number of your indoor unit please.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
May 25, 2018 | Goodman Heating & Cooling
Concept 1000 ac unit. Fan comes on but no air come into the house and the line freezes outside next to the unit. I'm lost!
Check your indoor air handler unit. If the coil is frozen, it is usually one of two problems. You are low on freon, or your filters are clogged and not allowing enough airflow over the coil.
Mar 20, 2017 | Heating & Cooling
Central unit
Seems like defective wiring or thermostat. The thermostat wires needs be checked. Another thing if the ac unit has economizer feature.
With the thermostat removed, if possible wires still connected to thermostat base, jump R-G, indoor fan should turn on: jump R-Y, compressor and outdoor fan should start (may feature a few minutes time delay): jump R-W, heater should start and indoor fan after a time delay.
What you want to see is R-G and R-Y working and if this is no problem, the thermostat may be due for replacement
Jun 21, 2015 | Heating & Cooling
Goodman ac fan wont turn on
Indoor fan or outdoor fan? Indoor fan not coming on may be due to a open door switch. When the air filter is replaced or the door to the indoor fan may have a button switch that makes contact or closes when the door is in place and this switch if existent in your unit, is probably open. A safety feature for when the door is opened, no one gets hurt.
Jun 28, 2014 | Goodman Heating & Cooling
AC unit wont work, inside coils are hissing but outside unit not turning on.
If thisnis a central air conditioner and there is hissing at the indoor coil then the compressor is running, it is possible that both fans are not running. The indoor motor may not run if the control board is bad, capacitor is bad or the motor itself is bad. The outdoor fan may have a bad capacitor or the motor itself is bad
Jul 23, 2012 | Heating & Cooling
8 blinks on unit shutoff,no continuous run
Indoor unit Fan problem. This is caused by the Indoor fan being locked. Check fan motor is plugged in correctly, Electrically & Mechanically sound.
Check the fan motor turns freely, check the AC Voltage supplied to the fan motor, this will vary from 120 V ac at low speed to 170V AC at high speed. If no
Voltage is present the the PCB is faulty, if Voltage is present the fan motor will be Fault.
Helpful?
Jan 19, 2011 | Heating & Cooling
I have a code 8 on my wall unit
Voltage is present the the PCB is faulty, if Voltage is present the fan motor will be Faulty
Jan 07, 2011 | Heating & Cooling
It simply wont turn on
a thought is , exactly what wont turn on? the indoor blower? the outdoor fan or the outdoor compressor?. be specific for goodness sakes. i assume you mean the ac wont turn on since its cold here in fla. dont know where you are since you didnt say. if it blows but not cold then outdoor unit is problem. if air out side being discharged is cool then compressor isnt running. check caps and volts through contactor. if ok check power directly into compressor. if ok the look at amps etc.
Oct 15, 2008 | Electrolux Heating & Cooling
BDP furnace + model 585A030080YACR
Sounds like your indoor fan motor is not working, check either the cap or the indoor fan motor it's self.
Jun 26, 2008 | Carrier Heating & Cooling
Friedrich QuietMaster Electronic SS12J30D Air Conditioner Logo
89 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Tim Whalen
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
