Question about Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor
Craftman Lawn mower continues to burn oil at a fast rate
Our Craftman Lawn mower continues to burn oil at a very fast rate. I have to put oil in after each mowing. I can not find a leak any where.
  • 3 Answers
Are you getting a lot of smoke? If so the oil is getting past the rings and burning.
Posted on Jun 23, 2009
2 stroke lawn mower got oil in the engine. What do you do?
if its four cycle oil put fresh two cycle oil and gas mix it start it let it burn the four cycle oil out should take one hour of running to burn it out
Jul 13, 2014 | Garden
Www managemyhome com
SANDY THIS SOUNDS LIKE THE LAWNMOWER IS BURNING OIL FRIST OF ALL CHECK THE OIL LEVEL SOME TIMES PEOPLE PUT TO MUCH OIL IN THE MOTOR BUT THIS ALSO SOUNDS LIKE THE RINGS ON THE PISTON ARE GOING BAD, WHO OLD IS THIS MOWER
May 21, 2014 | Garden
What kind of gas to used on lawn mower 55 158 cc craftman
Ori Hi, most lawnmowers use regular unleaded petrol now. If you have somewhere that oil goes into your mower then it will be normal unleaded but if on the fuel cap it has an oil can picture you need to mix it with two stroke oil.
Sep 07, 2013 | Craftsman 55 Torque 158cc 22" Push Lawn...
Craftman 917.270.711
check to see if the oil smells like gas the needle valve in the carb doesn't seat and gas drains into the engine the oil gets thin and burns it fast
May 30, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Put too much oil in toro lawnmower
Hi cldgaines1...
You do not want excess oil in the crancase, it can cause mechanical problems and smoke a lot.
Drain the excess oil out of the crankcase..
If you have an oil drain it will be located under the mower housing.
If you do not have an oil drain then you will have to tilt the mower with the oil filler plug removed to drain the excess oil from the crankcase.
Please take time to rate me.
Jun 27, 2011 | Toro Power Lawn Mower
The lawn mower is smoking I was told it needs water. Where does the water go?
Hi tjean9...
DO NOT PUT ANY WATER IN THE ENGINE AS THIS WILL RUIN YOUR ENGINE, it is an aircolled engine and does not need water.
Your engine is probably smoking because you have overfilled the engine with oil...your oil level on the engine should be at the bottom two threads of the oil fill hole.
If there is more oil in there than that it will cause your engine to smoke and could cause damage to your engine.
Sometimes if your engine is worn it will also cause the engine to burn oil and smoke.
Free Answer...Please take time to rate me
Jun 03, 2011 | Toro Power Lawn Mower
I need to find out gas to oil ratio on 6.5 hp craftsman lawn mowe
This info is available at any dealer or repair shop. I would recommend contacting them to be sure. The lead says mini-tiller but your question says lawn mower. The 6.5hp motors, as far as I've dealt with were 4 stroke which means no mixture, but check with a dealer or shop, they'll know.
Apr 21, 2010 | Craftsman Gas Mini - Tiller/Edger
I have an 18.5 Intek Craftman Tractor. The battery
pull the plug out and crank it over....if it's been sitting, there's liquid fuel in the cylinder...can't compress liquid...drain the carb too...use fresh fuel...
Apr 18, 2010 | Parks Optical 13.5hp Briggs And Stratton...
Craftman 6.6 self propelled mower blowing oil between the upper &
The Breather or Dip Stick Gasket at Engine. It you had the mower turned on its side befor problem, its coming out of the Muffler. This will go away but check your oil level.
Sep 08, 2009 | Craftsman Garden
Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor Logo
810 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
