Question about Whirlpool Accubake RF362LXTS Electric Kitchen Range
Recalls for range, model RF362LXTB 3
What recalls are for whirlpool Accubake RK362LXTB 3
  • 2920 Answers
SOURCE: Whirlpool Electric Range RF362LXTB caught fire
i would repair it...
Posted on Feb 04, 2009
Maytag317
  • 1136 Answers
SOURCE: Whirlpool 465 accubake gas range stuck in the "lock" mode.
Hi, Try setting it to clean, then cancel the clean cycle right away. Sometimes this helps. Please let me know.
Thanks
Vic
Posted on May 17, 2009
SOURCE: Whirlpool Gold Accubake Range
try holding down the start button for 3 seconds
Posted on Nov 15, 2009
  • 132 Answers
SOURCE: timer beeper failure on Whirlpool Gold oven/range oven
Most of the beepers I am familiar with are built into the main control clock board assembly. The only way to repair this is to replace the whole main control board, not a cheap part.
Posted on Jan 14, 2010
spectaculusc
  • 321 Answers
SOURCE: I HAVE A WHIRLPOOL ACCUBAKE RANGE, THE OVEN AND
There are four other things to check on the oven, you will have to run a test on the broiler element, oven thermostat, selector switch and the oven cycling relay.
To test the broiler element, To access the broil element located on the roof of the oven cavity, first open the oven and remove the oven racks. Remove the screws that secure the element to the oven, remove the holding brackets from the element and slide the element forward.
There is normally a small amount of excess wiring attached to the terminals on the element that allow a little room for maneuverability (you may have to tilt the element to get the terminals through the holes). Look for loose or disconnected wires and if there is no sign of burning; reconnect the wiring to the back of the terminal. If a terminal end is damaged, replace it with a terminal end designed specifically for oven use only.
To test the broil element, remove the wires from the broil element terminals by removing the screws from the terminal or pulling the wires off the broil element terminal. Remember to label the wires for reinstallation.
Visually check the entire element for signs of burn.
Test the broiler element for continuity. Using the ohmmeter, set the range scale on R x 1 and place the probes on the element terminals. There should be continuity, with readings ranging from 19 to 115 ohms, however readings will vary from manufacturer to manufacturer and according to unit size and the wattage, be sure to check your manual for the manufacturer's specifications.
If there are any signs of element burning, or if there is no continuity, replace the element.
To test for a grounded broil element, place one probe on the element outer surface and the other on the element terminal as in the ground test for the baking element. If continuity exists, the element has shorted and should be replaced. Be sure to test both terminals.
To test a dual broil element, remove the wires from their terminals. Using the ohmmeter, set the range on R x 1. Place the probes on terminals A and C to check for continuity, followed by terminals B and C. To test for a grounded element, place one probe on the element outer surface. With the other probe, touch terminal A, followed by B and then C. If continuity exists, the element has shorted and should be replaced.
To install a new broil element, simply reverse the disassembly procedures and reassemble, being sure to follow the wiring diagram and install the wires to the correct terminals
To test the oven thermostat: Access the oven thermostat, which is located in different places depending on the make and model: On freestanding ranges, access the thermostat by removing the screws that hold the back panel in place at both ends. On models with front-loading controls, remove the panel and tilt it for access. Be careful not to let the wires disconnect from their components. Some built-in models have a removable backsplash. Lift the backsplash, rest it on the cook top and remove the screws from the backsplash, which holds the rear panel. On wall ovens or eye-level ranges, access the control panel by opening the door and removing the screws that secure it. The screws may be under the exhaust hood or below the control panel. If the control panel is hinged, simply tilt it towards you. On some models both the rear and front control panels must be removed. The screws may be found on the trim and occasionally the trim must be removed.
When testing the thermostat switch contacts for continuity, refer to the wiring diagram and remove only those wires being tested - and only one pair at a time. Test switch contact terminals as per your wiring diagram. If the switch lacks continuity at any of the contact terminal points then the entire thermostat switch needs to be replaced. Adjusting the thermostat: Test the oven temperature by placing the tester in the oven's center and leaving it for 30 minutes at 350 degrees. Record the minimum and maximum temperatures of three cycles, then add those figures together, divide the result by six and you have the oven's average temperature.
If the average temperature is more than 25 degrees off, try calibrating the thermostat by following your appliance manual instructions for thermostat calibration.
Normally, thermostats are calibrated by pulling the oven's thermostat knob off, turning the knob over and adjusting the calibration ring on the back. If your oven doesn't have a calibration ring you may need to replace the thermostat.
To remove the thermostat: Disconnect the capillary tube and push it through the back oven wall, being careful not to break the flammable capillary tube wire. Remove the screws that secure the thermostat to the control panel and gently pull the thermostat out, leaving the wires in place. To install a new thermostat, reverse the disassembly procedures (Step 7 above), transferring the wires individually from the old unit to the new.
To test the selector switch: In order to gain access to the oven selector dial, first move the range away from the wall and remove the back cover panel by undoing the retaining screws. This will expose the back of the oven selector dial. Note: There are many styles of ranges. If this does not describe your range, refer to your owner's manual for instructions on gaining access to your oven selector dial. Now you can begin to test each pair of switch contacts for continuity with your VOM. Using the ohmmeter function, set the range scale to R x 1, and touch one test lead to each terminal of the switch contacts to be tested. There will be several pairs of contacts, one pair for each setting (eg. broil, bake, etc.). Refer carefully to your wiring diagram (often placed on the inside of the access panel) when testing. It is a good idea to label the wires as you test and only remove one pair of wires at a time. If there is no continuity between any pair of contacts, the switch is defective and must be replaced. To install a new oven selector dial switch, remove the old switch from the control panel by undoing the nut or screws holding the switch in place, leaving all wires attached. Transfer the wires one at a time from the old switch to the correct terminal of the new switch. Check your wiring diagram to make sure all wires are on the correct terminals. Now mount the new switch to the back of the control panel and replace the cover.
To test the oven cycling relay: In order to gain access to the oven cycling relay, refer to your owner's manual. Removing the back panel of the range accesses most relays, but some ranges locate the relay under the oven compartment where the utility drawer is usually located. Now you can test the relay using your VOM. First, label each wire attached to the relay and remove them from the relay terminals. Using your VOM's ohmmeter function, set the range to R x 1 and touch one test lead to the terminal marked L and the other test lead to terminal H2. There should be NO continuity. Next, test the terminals marked H1 and H2. Again, there should be NO continuity. Finally, test the S and R terminals. Continuity should exist between these two terminals. If your relay does not pass all these tests, it is defective and should be replaced. To remove the relay, undo the two screws securing it to the range and replace with the correct new relay. Refer to your wiring diagram and labeled wires to ensure that the wires are on the correct terminals. Now replace the back panel or drawer and test the oven.
Hope this was helpful to you. Thanks for using fixya.
Posted on Jan 27, 2011
I have a code E6. What is the code?
The should be another code with the E6 - Fx.
Dec 02, 2012 | Whirlpool Accubake RF362LXTB (Dual Fuel)...
Hello. We have a Whirlpool Accubake range and we heard a pop and saw a spark under one of our 8" burners. What ever happened tripped the circut. After resetting the circut, the rest of the oven and...
I had a problem with my Whirlpool range. It would not regulate temperature properly on the two large 8" burners. I found the problem was the "infinite switch". The infinite switch regulates temperature of the electric stove elements.
I found this video (see youtube link below) informative and it solved my problem. I found the correct infinite switch on Amazon (my infinite switch was this $21.00 one: https://www.amazon.com/gp/product/B004XLEJ7M/ref=oh_aui_search_detailpage?ie=UTF8&psc=1). The fix to replace 2 infinite switches (both 8" burner switches) took me 1 hour, including cleaning the floor under the stove (nasty!). All was well afterward.
https://www.youtube.com/watch?v=F4gCWNdu2io
Apr 14, 2017 | Whirlpool Accubake RF362LXTB (Dual Fuel)...
Need light for oven and where can I buy the drip bowls square? TY
You can order parts by calling 1-800-813-4500
Thanks and please have your model number handy.
Aug 26, 2011 | Whirlpool Accubake RF362LXTB (Dual Fuel)...
Is there any kind of pilot light that I need to light? I just had the gas turned and none of the burners will light and the oven won't get hot.
There may be a gas shutoff on the range gas supply. If so,turn it on.
If it is already on,turn on a surface burner and use a match ti light it.
It will take several minutes for the air to purge from a system once gas supply has been restored.
Aug 03, 2011 | Whirlpool Accubake RF362LXTB (Dual Fuel)...
Stove sparks but doesn't light
If gas flows and burner sparks,the holes in burner near where the electrode(spark plug) is are clogged. A safety pin or paper clip pushed through those burner holes will clear the blockage
Good luck
I hope this helps,if it does please give me a 4 thumbs up rating&and perhaps a testimonial :)
Gene
Jul 30, 2011 | Whirlpool Accubake RF362LXTB (Dual Fuel)...
Whirlpool mod. WFG361LVS 0 SER RW3911592 code : F5E2 on baker
This probably a problem with the wiring of the door lock assembly. Here is a list of Whirlpool error codes.
Mar 20, 2011 | Whirlpool Accubake RF362LXTB (Dual Fuel)...
I have an error code "f1 - e1"..help plzzzzzzzzzzzzzzzz.
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 09, 2010 | Whirlpool Accubake RF362LXTB (Dual Fuel)...
Whirlpool Accubake RF362LXTS Electric Kitchen Range Logo
63 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
