Question about DCS MO-24-SS Microwave Oven
How do i Remove cover of the dcs 24ss, microwave
2 Suggested Answers
  • 4090 Answers
SOURCE: I have a DCS Model MO-24SS. The other day I was
Main fuse is under outer cover Its a large ceramic fuse and costs about $30
Posted on Aug 16, 2009
Dcs cm024ss microwave Controls work but microwave does not heat
Either the magnetron tube or it's high voltage power supply have failed These are the two most expensive components to replace and it may be more economical to replace the oven than to repair it.
Feb 26, 2015 | DCS Microwave Ovens
Microwave works while door open
Replace. Microwaves are cheap.
Feb 16, 2018 | DCS Microwave Ovens
My dcs mo-24-Ss microwave oven cannot heat the food after turn on, everything working fine other than no microwave come out
Assuming the turntable, inside light, and internal cooling fan all work when you press "Start" to cook, then I would suspect a bad magnetron, or a bad connection at the "FA" terminal of the magnetron.
If one or more of those three items do not work when you hit "Start", the I would suspect a bad door switch or mount.
The DCS MO24SS is essentially a rebranded Sharp R-530E-series microwave with different cosmetics and a higher price.
The service manual for the Sharp model is here.
The internal Sharp parts in the manual will interchange, but not the external cosmetic parts.
You can order Sharp parts from Encompass here.
Nov 22, 2012 | DCS MO-24-SS Microwave Oven
Door won't open on dcs microwave oven
Only way out is to use good glue with a reenforced welding to strengthen the tab which will stand the strain. the other option is to replace the whole unit if the spare can be found or if this can be sourced from an old set.
Oct 31, 2011 | DCS MO-24-SS Microwave Oven
I need a new waveguide cover.
Just go to your machanic or the nearest waveguide selling shops
Feb 26, 2011 | DCS MO-24-SS Microwave Oven
I heard a pop and then i saw sparks inside the oven, the sparks were coming from what looks and feels like a paper cover inside the microwave
This sounds like the inner lining is coming off and alloying the metal interior to spark. You will need to repair the liner and this should fix your problem.
Dec 08, 2009 | DCS MO-24-SS Microwave Oven
DCS - CMO24SS - 900 Watt - Microwave not Heating
If all appears to be running as its working but just no heat. Could be issue with magnetron. You could also have loose connections to magnetron or somewhere in high voltaged as well.
Nov 24, 2009 | DCS CMO-24-SS Convection/Microwave Oven
Jul 25, 2009 | DCS MO-24-SS Microwave Oven
Need to replace melted carousel coupling
You need to remove the bottom cover if it's an over the range model.
If it's a counter top type, there should be a cover over the turntable motor.
On many Sharps, the turntable motor cover comes as an unseparated part of the bottom cover and you have to use sidecuts or snips to cut away the little tabs which hold it in place. Then when you are done, you use a screw to hold the cover back in place.
All this is best done with the microwave on its left side with the door opened, and the turntable and support removed. (Power off, of course).
Once the cover is off, you remove the two screws holding the motor, pull the motor out, then pull ou tthe old coupler.
Install the new coupler with one hand, and push the motor in place. Jiggle the couple as you do so it will mesh with the motor shaft.
Once it's in, replace the motor screws, replace the cover and you are done.
Sep 17, 2008 | DCS CMO-24-SS Convection/Microwave Oven
DCS MO-24-SS Microwave Oven Logo
Top DCS Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Colin Stickland
Colin Stickland
Are you a DCS Microwave Oven Expert? Answer questions, earn points and help others
