Question about Car Audio & Video
How can we fix the stereo in our car (Volvo s80 2000)?
The stereo in our car doesn't want to work. We've fixed the fuses, but it hasn't changed.
  • Jimmyjr May 19, 2014
    Hi leo Lopez, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? What was you doing when it stopped working just need more info. Did you jump some one off change the battery...
    Problem Solver:
  • 3 Answers
If you don't see any text appearing on the screen, then it may be because your radio blew off , you can buy another one at the scrapyard
Posted on Jun 12, 2014
3 Suggested Answers
  • 5 Answers
SOURCE: my stereo just isnt working.
if this works run new wires. to legit spots. twist both hots togeather put fuse on run to fusebox then ground to metal bolt that bolts n2 metal it should come on if not radio is bad
Posted on Oct 17, 2010
  • 7 Answers
SOURCE: Kenwood car stereo face got wet and now won't work, how do i fix it?
If the unit is already fried you may try to soak it in the highest alchol % of rubbing Alcohol for a day then allow the unit to dry Which should happen within a day or so because of the evaporation rate of the alcohol. This should remove the internally locked water and allow for the unit to resume Function without internally shorting.
Posted on Jun 07, 2013
Keyboard will not turn on
If it hasn\'t been dropped or bumped, check the adapter. Work backwards from the keyboard. It doesn\'t take much for the casio adapters to pack a sad. If there\'s an overload in your switchboard, it\'s usually the Casio that packs a sad...everything else is fine, microwave, tv, stereo - just not the casio. Their adapters are garbage and until recently - they\'ve just gotten better
Oct 02, 2013 | Casio Music
[VOLVO s60 2001 turbo] My steering wheel buttons issue not working
Is the vehicle fitted with the standard stereo fitted by the manufacturer?
If not, then there is a strong chance that these controls are not compatible.
Nov 18, 2012 | 2001 Volvo S60
Volvo power antenna doesn't work
Check power to the antena with the stereo on. If power is available, then change the antena motor.
Nov 04, 2012 | 1994 Volvo 940
My drivers side brake light doesn't work on my 1992 volvo 240
Check for power at the bulb socket then make sure it has a good ground.
Feb 24, 2012 | 1992 Volvo 240
What is DIM,Volvo s80,2000
Drivers Information Module, basically it is the instrument cluster
Nov 18, 2011 | 2004 Volvo XC70
What' mean Heater Control Circuit Sensor,Bank2,Sensor 1,Volvo S80,2000?
Heater control circuit is your O2/oxygen sensor which controls your emissions and keeps the car running efficiently. They go out quite frequently and need to be replaced. Wont cause any drivability issues other then lower fuel economy and check engine light. Sensors run between $50-$200 each.
Nov 11, 2011 | 2000 Volvo S80
Toyota Corolla 1997 I've installed kickers in the rear (KS series to match the front)... had those going for a couple of weeks with no problems. Yesterday i went to install the KS400 series in the...
take one of the front speakers out and pull out the head unit and unplug a set of audio wires(front right, front left ect.) and hook it up directly from the radio to the speaker there for bypassing all the cars wires. If it works then there's a problem with the car's wiring(maybe an inline amp). If it doesn't work, then try a known good speaker from somewhere else(home stereo speaker for example) and connect it to the radio, if the speaker works, your radio is fine and there may be a problem with the speakers. If it doesn't work then you have a problem with the head unit.
Jul 22, 2011 | Kicker KS400 Coaxial Car Speaker
1993 240 volvo, radio, door locks, clock do not work. not fuse.
check all your fuses,,,sometime the radio display is on a separate fuse.....
Feb 02, 2009 | 1993 Volvo 240
Car Audio & Video Logo
41 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
