Question about Polycom VSX 6000 (220022222001) Video Conference
How solve in my POLYCOM VSX 6000 showing error "unsupported signal adjust your PC output"
My SONY TV is working fine in my laptop, but when I put POLYCOM signal to SONY TV there are showing in TV screen "Unsupported Signal adjust your PC output".
  • 4 Answers
Try using the S-Video output and then try using the VGA output from the VSX 6000 unit. The unit can be fixed to output from either as the first monitor output (you may have the dual monitor option enabled). If this does not work the resolution of the TV might be HD, the output of your VSX 6000 is Standard Definition. You will need a monitor that accepts standard definition. If this does not work, I would reboot your VSX 6000 and try again. David
Posted on May 24, 2014
  • 3 Answers
SOURCE: Not able to getting video from Remote far end.
Is the Indian site within the firewall? If so, I would focus on the firewall. Does the US site have a firewall? They may be blocking outbound traffic. If you are connecting but no video, it sounds like UDP traffic is still being blocked somewhere. If you can, you may want to assign public IPs on the units and test outside of the firewall.
Hope this helps..
Posted on Jul 23, 2008
  • 7 Answers
SOURCE: Polycom Viewstation 14XX
RMA it with your support provider
Posted on Jan 14, 2009
SOURCE: polycom vsx 7000
no the power supply is propreitory( has multiple voltages) & is not advisable, u could blow up ur expensive confeencing equipemt.polycom has designed it in that manner!!
Posted on Feb 08, 2009
  • 10 Answers
SOURCE: Can not able to dial out any number from Polycom VSX 7000.
Check out the following things:-
1. When dialing a ISDN number, be sure that the call preference has not been set to IP H.323 on the home screen just below the dialing field.
2. Check with your service provider that outwards dialling have been enabled on the lines provided to you.
Posted on Apr 02, 2009
  • 6 Answers
SOURCE: polycom vsx 7000 remote controll not working
Did you check to see if the batteries were still good or in the remote correctly?
Posted on Jan 26, 2011
Tip
VSX 6000 - Time Server down
I have such a problem: when I connect VSX 6000 to the Internet, it doesn't work. It is connected through the swith D-Link, total length of network cables is about 150 metres. Inside the diagnostik I see, that Time Server is red, i.e doesn't work. But IP Network lights green! IP adress is phisical, whithout proxy and firewalls.
I want to notice, that notebook, connected to the same LAN-port works whithout problems!
on Feb 12, 2008 | Polycom VSX 6000 (220022222001) Video...
3 way video conf
Your VSX 6000 does not support Multipoint. YOu will have to move up to the VSX 7000 or 8000. The VSX 7000 supports MP and the VSX 8000 supports 6 site mp if you have that option installed. DAVID
Dec 12, 2012 | Polycom VSX 6000 (220022222001) Video...
Message of Unsupported video signal after attaching laptop to TV.
it sounds like the resolution the laptop is trying to send is not one of the resolutions that the television can display. TVs can display a range of resolutions, so try changing the laptop resolution, either increasing it (make the pixels smaller) or lower the resolution, try a variety of resolutions, one should work.
Jul 11, 2010 | Dell Latitude D420 Notebook
Trying to connect my pc to tv have a message on screen of tv saying unsupported signal adjust your pc output.how do i do that
Your TV you are trying to connect to the pc may not be compatible with the connecting device or the connection output to the TV is incorrect.
Please provide more information as to you issue such as :
a. model number
b. year manufactured
c. Has the manual to the TV been viewed
d. PC information needed (out puts/inputs)
Jun 21, 2010 | Computers & Internet
Unsupported Signal. Adjust your PC output
Boot into safe mode or VGA mode and reduce the resolution to 800 by 600 and set the refresh rate to 60. After this, reboot normally and check the box to have your video to display only the settings that work for your system, and choose the desired resolution, and refresh should be 70-85 to reduce flicker. Appears as tho your video card is set too hot for the monitor.
MORE: In safe mode or vga mode you may not be able to adjust the settings. Fine. After a reboot, you may be able to start normally and the vga settings might still be there (640x480). Then you can adjust them.
Jan 23, 2009 | Intel Motherboard
Pc setting for sony bravia
'Unsupported Signal' Error indicates that TV is accepting the signals for Video but not able to display because resolution doesn't matches. Else the message would be 'No Signal'.
Follow the steps-
NOTE- Make sure cable is 15 pin(at both ends) VGA cable, working fine between PC & Monitor.
1.The standard resolution of laptop(any) which would support is 1024*768.
2. Toggle the display output from Laptop Fn Keys depending on Laptop Brand.
3. Connect the cable after settings made.
Also PC Settings will not be highlighted until connection is made.
Jan 20, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Can't get to the home screen
I've just solved that problem in the VSX 7000 of my girlfriend's Job.
Your VSX7000 has at least 4 video outputs, 1 for VGA and Supervideo 1 and Supervideo 2.
Firstly you should try VGA connector, because the main menu may be there, so you could change the configuracion.
If you can't see main screen in any of the output connectors you'll have to use the http tool.
In your internet browser enter the camera IP address, and you'll get the Web Interface of the VSX7000.
It will prompt you for user & password, the default options are "Admin" and your VSX7000 serial number (14 digits) you can find this number under the camera.
Once you're in the Web Main Menu, click on Site Map. There you can choose what you want to see in the screen of Monitor1 (My menus are in Spanish, maybe your menu says something like "screens" but I'm sure you'll find it)
If you choose Monitor/Screen 1 as Svideo, and select it as output for Local, Remote and Content you should see the Main Menu after the VSX7000 Reboots.
I hope it would be useful for you, if you have any problem with this let me know... This VSX7000 is working fine now, so yours should work!
Sep 19, 2007 | Polycom VSX 7000 Video Conference
Polycom VSX 6000 (220022222001) Video Conference Logo
118 people viewed this question
Top Polycom Lands Phones Experts
Gerald Ridge
Gerald Ridge
Level 1 Expert
Sandeep Kamat
Sandeep Kamat
TEKUSER
TEKUSER
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
