Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Why does engine die when brake released or mower engaged?
Have mowed once this year with no problems. new battery put in, no mice in engine. starts fine but dies when brake released or mower deck engaged. thought engine would not start if switch in seat not activated
You likely have a faulty operator presence seat switch. This switch is designed to shut down the engine if the operator leaves the seat without shutting off the PTO and engaging the parking brake. An easy way to tell if the seat switch is bad is unplug the switch from the wiring harness receptacle. Jumper the wiring harness receptacle. Start the engine and disengage the brake. Engage the blades. If the engine doesn't shut off, replace the seat switch. They're not expensive, and you really should keep all your mower's safety features operational to help protect you from any potential liability.
Posted on Sep 20, 2015
  • 4 Answers
The first thing I would check is to make sure the drive belt is not binding somewhere.
Posted on May 17, 2014
3 Suggested Answers
SOURCE: I have 16 hp Craftsman riding mower with a Kohler engine.
It may think you are in reverse and is killing the motor to keep you from backing up with the blade running. Look for switch that is telling it when you are in reverse, maybe it is stuck with grass or other debris. another possibility is that the blades are jammed and they are stalliing the motor. Mines stalls easily when cold.
Posted on Mar 12, 2009
RonInFla
  • 86 Answers
SOURCE: STARTS GOOD BUT ENGINE DIES WHEN CLUTCH RELEASED
cut the wires running to the switch...try again...if same, stripp back wires, and twist together...wrap in tape or use some sort of connector...it's electric and should be treated as such...try again...still ?? Start finding those switches and repeat the process til it works...theres usually 3 or 4...
Posted on Apr 18, 2010
Testimonial: "Haven't tried the suggested solution but makes sense."
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Mower starts; release brake or engage mowing blade and motor dies.
sounds like one of the safety switches has failed .
Sep 06, 2015 | Garden
Why does mower die when brake released or mower engaged?
ck your occupant (seat) switch it might have gotten dislodged or unhooked when fueling it
May 17, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Battery drains and won't charge
I would start by having battery tested. If u remove it and take it to auto parts store they will test it for free. It could be that the battery will not hold a charge or your tractors alt. is not putting out a charge
Apr 04, 2014 | Garden
L130 John Deere PTO problems
you have a bad seat switch
Sep 21, 2012 | John Deere Garden
Electric blade clutch won't work and battery went dead
If you have a new battery and it went dead that quickly I would check the charging system on the mower engine. Many of them use a voltage regulator and if it goes bad it will not properly charge the battery. Get the engine running (do not engage the PTO) and use a multimeter set on DC voltage. Place the multimeter leads on the battery and you should see approximately 13-14 volts DC at the battery terminals when it is running. If less then that then it's a problem with the charging system and further tests would be needed to figure out if it is a bad regulator or charging coil.
Aug 23, 2012 | Husqvarna Garden
John Deere La175 Battery doesn't charge while mowing. After I mow for an hour or so and turn tractor off, it won't start. When I put the charger on it for a second or two, it turns over and runs....
I had the same problem. My LA 175 mowere deck would not engage and I figured out that the battery was not sending the sufficient 12volts to the mower deck to run the mower. I replaced the battery and that fixed the problem only to reveal the original problem. Within 2 hours of mowing the battery again died. I replaced the voltage regulator and that didnt help. I need suggestions on where to go from here please. Anybody?
Apr 22, 2012 | Garden
I went to go mow the lawn for the first time this season. Tractor started right up. took the deck cleaned and greased it. Went to engage the p.t.o. for the mower and the tractor stalled. Can't figure...
Hi and welcome to FixYa, I am Kelly.
The power sequence for engaging the blade deck is. Clutch brake pedal depressed, operator in seat, Enage selected and brake pedal released. When the blade enages the engine igniton kill wire is routed through the seat switch AND the PTO clutch. If either the PTO Clutch or the seat switch has a problem the engine dies. Same goes for the clutch brake pedal switch... if the clutch brake is not coming all the way up the engine will die.
If you respond with a model number (example LX2000) I can show via a manual where you need to troubleshoot using a meter.
Do a couple of good bounces on the seat, check the clutch brake pedal switch for clicks and then attempt to an engagement.
Also inspect the PTO clutch wires and connectors for corrosion.
Thanks for choosing FixYa,
Kelly
Apr 23, 2011 | Garden
WILL NOT START craftman LT1000 YR.2000
most likely the blades are still in the on position,but you have a seat switch, parking brake switch, and the blade switch, also the mow in reverse key switch. if mower dies once you let out the clutch in reverse with blades on and key wrong.
Apr 22, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Last weekend I sharpened the blades, changed the oil filter, the oil, and the spark plug, put in fresh gas and started the mower up and mowed the lawn no problem. This weekend, it started right up but when...
There is an operator presence switch under the seat...if the mower shuts off when you release the brake, this switch is faulty and must be replaced
May 02, 2009 | Garden
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
314 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
