Question about Samson Servo 200 Amplifier
Hello, my Samson Servo 200 has a problem, when I push the Power-ON button, the Protection Modus don' t started.
  • 42 Answers
You have lost a circuit. this is a problem that you can not fix yourself.
Check to see where the nearest "AUTHORIZED" service center is.
Do NOT take it to Joe Schmoe stereo repair!
Use ONLY an "AUTHORIZED" repair center!
Going anywhere else could result in YOU replacing your unit!
Posted on Jun 14, 2014
5 Suggested Answers
  • 236 Answers
SOURCE: Samson Servo 170 protection circuit problem!
my friend resistors and diodes don't just go off your circuit without a real problem. those parts gave up because of shortage on your power section, i suggest that you check your power transistros first along with the diodes and resistors.
noisy transformers... hmmmm why is that making sound? the solution there is to dip the power transformer to a thick shellac varnish let it there for let's say an hour then let it dry for a day. then place it back in your unit and see if still sounds
Posted on Aug 13, 2008
petraman7
  • 1175 Answers
SOURCE: Samson servo 300 right channel low output power protection on.
Hi...
This amp will need to be serviced
Check on the web for someone who does audio/stereo repair in your area
Posted on Jan 26, 2010
bbl242003
  • 1637 Answers
SOURCE: i am trying to find schematics for the samson 120
Here is a direct page to your needed information http://www.samsontech.com/products/productpage.cfm?prodID=1821
Posted on Jan 30, 2011
  • 38 Answers
SOURCE: my samson servo 200 has
I just repaired a servo 600 Right chan intermitent. I found a strain relief too tight to vol plug [or wire too short]. Solution "cut out the zap strap and re-strap leaving wire of of bundle and plug makes conection and locks into place. :O]
Posted on Oct 06, 2013
I just need schematic for Servo 200
Hi...try this...http://sportsbil.com/other/SAMSON%20SERVO%20170%20260%20550%20SCH.pdf thanks...hope it helps,
Jul 26, 2017 | Audio Players & Recorders
I had phrased the previous question with typo errors
When any electrical item doesn't work after being moved, suspect some kind of physical cause. Such as a bad soldering joint or other damage inside caused by an unknown bang or jolt during the move. Perhaps even an alien object inside like a metal pin etc.
Mar 25, 2015 | Samson Audio Players & Recorders
Protect light on amplifier
Oh dear! Protection system has detected a short in the main power amp. The water has caused a great deal of damage. You will have to replace all the parts that have been damaged. Your nose will lead you to where to look.
Jun 27, 2012 | Samson Servo 170 Amplifier
No sound coming with protection light on
It's either overheated or you may have faulty speaker wiring or a shorted speaker. These directions come from a Samson servo 120a but the theory is the same.
The following conditions will cause the Protection LED to go on:
Initial power-up: For approximately five seconds after initial power-up, the relay
speaker connection circuitry is deactivated and the speaker output is muted. If everything is operating normally, you will hear an audible click at the conclusion of this brief period, as the circuitry is activated and the Servo 120a begins delivering signal to connected speakers (at which point the Speaker LED will light if the Speaker on/off switch is in its "in" position). It is normal for the Protection LED to fade gradually after the amplifier is powered off.
Overheating: A temperature sensing device in the Servo 120a will cause the relay speaker connection circuitry to be activated (and the Protection LED to go on) whenever the operating temperature of the unit rises above a safe level. To guard against this problem, make sure the Servo 120a receives adequate ventilation on all sides ; in extreme environmental conditions, you may also
want to consider the use of cooling fans.
Severe overcurrent conditions: This occurs whenever the signal being output
from the Servo 120a rises to a level above 20% THD (Total Harmonic Distortion).
Shorted speaker cables: This will occur if, due to faulty wiring, the hot and ground signals being output by the Servo 120a short to one another.
Output impedance drops below 2 ohms: This can occur if the Servo 120a is connected to inappropriate speaker systems (see the "Setting Up and Using the Servo 120a" section in this manual for more information).
DC voltage detected at speaker output: The most likely cause of this is an internal failure. In general, any time the Protection LED lights up (other than during the approximately five seconds following initial power-up), there is reason to be concerned. If this occurs, turn the Servo 120a off immediately and carefully check all wiring and external devices in order to locate and correct the condition that caused the LED to light up in the first place.
Dec 27, 2010 | Samson Servo 170 Amplifier
Samson servo 300 right channel low output power protection on.Left channel ok.
Hi...
Jan 22, 2010 | Samson Servo 300 2-Channel Amplifier
Hi when i turn on my servo 170 my protection lite stays on
One of the channels in the amp is bad. That channel will need tobe replaced. You may need to take it to a repair shop.
Nov 12, 2008 | Samson Servo 170 Amplifier
Aug 11, 2008 | Samson Servo 170 Amplifier
193 people viewed this question
Top Samson Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Umali
Vito Vacirca Jr.
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
