Question about Black & Decker Garden
Fix starter button on black and decker 2900 mower
When I push in button and pull up handle the motor does not start
  • 21 Answers
SOURCE: replacement batterys for cmm1200 black&decker
www.Buy.com UB12180 Sealed Lead Acid Battery - D5745, $31.99 a piece plus shipping.
Posted on Apr 13, 2009
  • 8 Answers
SOURCE: Mower starts up great and then dies
If it's a briggs engine, sounds like you have water / debris in your carb fuel bowl. Using spray carb cleaner will only work if you remove the bowl and clean the carb jets. Also, you could have water in the gas tank as well. First, remove your air filter, then remove the 3 screws that attach your filter bracket to your carburator and mower. Take off your fuel line at the carb and drain all your gas into a clear jar. If it looks very yellow, cloudy, or see water in the bottom of the jug, change your gas. Using a half inch socket wrench, after gas line is disconnected, remove the fuel bowl and clean with carb cleaner. Also, examine the bolt you just removed. There are 2 jets in the side and one at the end. Using the carb cleaner, make sure they are clean as well. Use the carb cleaner extension tube to spray up inside the bottom center of the carb, where the bolt threads, to clean that area as well. After all this make sure ur float assembly is intact and reassemblt the bowl to the carb and reattach the the fuel line. finish bt reattaching the air filter support bracket makinf sure the gasket between the carb and the bracket isn't damaged.
Posted on May 25, 2009
  • 1619 Answers
SOURCE: i need to fix athe pull string on my toro push
remove bolts from cover and remove the cover. Should be able to access the assembly for the pull rope. Go to a local mower repair shop buy some new line. The old line should just be knotted up on the spring loaded wheel in there. You put a new piece on put in a new knot, put some turns on the assembly to basically wing the spring so it snaps back when pulled, put line through whole and attach to pull handle.
Posted on Jul 11, 2009
SOURCE: Poulan 550 Series push mower won't pull start
Poulan 550 series self propeeled mower. Mower starts and stops running after 10 seconds. Gas tank full. Filter cleaned.
Posted on Sep 17, 2010
kel1guy2002
  • 3740 Answers
SOURCE: I have a Briggs & Stratton 500 series push lawn
Hi and welcome to FixYa, I am Kelly.
When a primer bulb is slow to return to a static conditon there is a restriction in the fuel supply. Since this carb is mounted directly on top of the fuel tank the troubleshooting for this involves removing the gas tank and carb as an assembly from the engine. Remove the end bolt and then the side bolt spacer that is just above the tank. Be careful or the spacer will drop. Pull out on the tank until it slides off of the intake. When the tank is free of the engine tile the bottom of the tank toward you and disconnect the throttle linkage. NOTE the hole the linkage is connected to! Set the tank on a flat surface and remove the carb mounting screws. STOP! Do not lift the carb off of the tank until your sure that the gasket and diaphragm are not stuck to both mounting surfaces. You may have to carefuly slide a thin knife blade FLAT across the top of the tank to free the carb from the tank. There will be a SPRING on the bottom of the cabr also. Do not lose this spring and ensure you see how it is installed! Once the carb is free of the tank clean the screen under the carb and the carb with carb cleaner. Reassemble carb to tank. Fill tank with gas and re-check primer bulb BEFORE you reinstall the tank and carb on the engine. If it still does not work.. properly you need to clean the passages again. Worst case you remove the primber bulb to see if there is debris inside the bulb plunger area. Installing tank and carb to engine....
Tip the bottom of the tank toward you.. connect the throttle linkage, watch the o-ring that is in the carb intake sealing area and make sure it seals. Install side bolt and then the end bolt.
Just back tracking here.. I have determined this is most likely a 11A-B04E000 Yard machine with a 5.0 Hp engine... ( Briggs and Stratton refers to this engine as the 10T500 series.
ENGINE Parts list is here:
http://www.brandnewmowers.com/pdf/11A-104B090EIPL.pdf
Thanks for choosing FixYa,
Kelly
Posted on Jun 28, 2011
Could be bad gas or clogged carb. Drain the gas tank, fill with fresh gas with Stabile. Remove the bowl from the bottom of the carb and clean the carb. All mowers now have a low oil cutoff sensor, ensure the oil is full. Did you check for a blown fuse? Battery fully charged, 12.8 volts or higher.
May 17, 2014 | Black & Decker Garden
Black decker 36v won't start
Sounds like its burnt out. Or shorting out.
Jul 04, 2012 | Black & Decker 19" Electric Lawnhog...
Handle unhooked
spring and metal hook should have a metal cable to it and the handle with handle depressed cable pulls back hook [safety/shut off] which lets mower start
Oct 07, 2009 | Black & Decker 19" Electric Lawnhog...
WIRING DIAGRAM? FOR BLACK AND DECKER ELECTRIC LAWN MOWER MM 850
looking down at the terminals, rotate push-button to the right. the wiring sequence is R, W at the top, then Black (in, from power source) , Black (out, to motor).
Sep 27, 2009 | Black & Decker 19" Electric Lawnhog...
Have a black and decker 19in electric mower. was
The "wedge" of the plastic lever wears, so you need to replace the lever or build up that section of the lever. Some cyanoacrylate (Super Glue / Krazy Glue) and a piece of a zip tie will work.
Sep 23, 2009 | Black & Decker 19" Electric Lawnhog...
I have a black & decker lawnhog mm875 lawn mower that just stopped working. the power to the mower is good. can you help
I had the same problem. Its the switch.
When you pull the plastic handle up, it pushes down a button switch located in the handle. Over time (and with use) the parts begin to wear and the handle is no longer aligned properly with the button. So, ........ when you pull the handke up the button is not pushed in far enough to start the mower.
I want to bypass the handle and hard wire the mower but I can't find a wiring diagram.
May 04, 2008 | Black & Decker 19" Electric Lawnhog...
Electric Lawn Mower
orange lever has to be pulled up.release the mower will stop.
Nov 08, 2007 | Black & Decker 19" Electric Lawnhog...
Garden Logo
15 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
