Question about Singer Futura Xl-400 All-In-One Sewing And Embroidery Machine
What does the 10 light mean
I have monogrammed a few items, but sometimes the fabric from what i'm monogramming will get hung in the bobbin area with tangled thread, but I can normally clean it out and continue, but now I have the #10 light on and my machine will not allow me to monogram...what does the #10 light mean?? How do I fix it??
    Novelist:
  • 268 Answers
Manual for this machine is here: http://www.singerco.com/uploads/download/bbd749beb7151a637824d777a05c51b4fb50b0a4.pdf
10 means the hoop size is too small to let the hoop move to the proper position, install a bigger hoop, according to the error codes on the next to last page.
Posted on May 21, 2014
bargainbox
  • 1388 Answers
SOURCE: bobbin thread
that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistant diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Mar 16, 2008
  • 323 Answers
SOURCE: thread tangles around shuttle
Either the thread is not in the take up lever or it is not in the tension. Rethread the machine. Raise the presser foot and pull on the thread between the tension and take up. It should be loose. Lower the presser foot, pull on the thread between the tension and take up lever. It should be tighter. Make sure the thread is in the slot of the take up lever and pulled to the front of the lever.
sewman7
Posted on May 22, 2008
  • 99 Answers
SOURCE: Amatur Sewer?threads tangled below
Stop sewing! You need to adjust your tension. Your book will explain exactly how to do this. If you can't find your book, try setting the tensions to the same number. If your tension adjustments have a mark at a certain number, use that setting for most materials. If not, try setting it to about 3.
To test your settings, thread your bobbin with a different color, then do a test stitch. Check the top and bottom stitches for a spot of the other color thread showing through. If the bobbin thread shows in the top, raise the bobbin tension setting a bit and try it again.
Hope this FixesYa!
Posted on Aug 11, 2008
  • 69 Answers
SOURCE: On my Singer Scholastic, the thread jams in the bobbin area
It sounds like it is not threaded properly through the tension disc. Try rethreading and make sure the presser foot lever is in the up position. If it continues, once threaded and with the presser foot down, pull on the thread through the needle. If it has resistance, it is threaded properly. If it pulls easily then there is a problem in the tension area. Check to see if there are peices of thread broke off in between the tension disc.
Posted on Feb 07, 2009
SOURCE: top thread gets tangled in bobbin and won't pull up like
I'm new to sewing, and I had a similar problem where the top thread went all the way around the bobbin thingy and got stuck every time--solution: the bobbin case wasn't all the way in.  The arm had to go in a slot at the top and it sort of snapped in, then it worked fine.  Maybe it will help you!
Posted on Nov 06, 2009
I have the Creative Sensation and want to monogram a letter in a circle. How do I do this? Does it have to be embroidered?
You could use an applique (satin) stitch freehand on your machine. But, it takes some practice with steady hands to get it to look nice.
In the video, she uses a heat bonded stabilizer. If you don't use a bonded stabilizer, you'd want to put the fabric and stabilizer in a hoop to keep the fabric tight. If you are going to manipulate the fabric manually, you also would drop the feed dogs.
Machine Applique Tutorial
Tips for Machine Appliqu
Sewing Perfect Satin Stitch Wildly Wonderful Wearables Patterns Notions...
How to Monogram with Basic Sewing Machine (in this video, she turns the fabric while stitching but to get a nice letter, you can try not turning the fabric to go around curves)
How to embroider on home sewing machine (she manually manipulates the fabric, uses a free motion quilting foot, drops the feed dogs, and uses stabilizer and a hoop)
Dec 01, 2016 | Sewing Machines
Can this to freehand machine embroidery?
If you can drop the feed dogs (or have a plate to cover the feed dogs), the machine has a zig-zag stitch, and you have a darning foot or free motion foot, you can do free motion quilting, hand manipulated embroidery (monograms), and applique on a basic sewing machine. It will take some testing and quite a bit of practice. You can also use an embroidery foot to monogram and applique. You will want to sink the needle into the fabric at every corner and frequently when creating curves so you can move the fabric.
Search the internet for instructions & tutorials on how to set up your machine and the best way to accomplish what you want.
How to Use Monogramming Foot
Machine Applique Sewing
Jan 12, 2016 | Sewing Machines
My bobbin thread is part of my embroidery on my memory craft 11000
you may have the fabric not tight enough in the hoop or try using the same colour thread in the bobbin
Nov 02, 2014 | Janome 11000 Memory Craft Special Edition...
Why is my bobbin thread showing?
Perhaps you should run your bobbin thread through the small hole on the lever that moves in and out. That is what you do when you sew a buttonhole, which is the kind of stitch a monogram makes. I haven't tried it because I don't do monograms, but it makes sense. Also experiement with the tension settings.
Jul 05, 2014 | Bernina Sewing Machines
Embroidery machine not pulling top thread on 385.19000
White on top means that the top tension isn't right some how. Now that can be because it wasn't threaded properly with the foot in the up position... or it could mean that you've got the little thread catcher **** on your spool catching the thread and causing problems. Sometimes if it catches it will wind a few layers of thread around the thread spindle the spools sits on. That isn't readily notice until you get mad and pull the spool off.... and finally see it. LOL
Carefully examine the path of the upper thread too.
Good luck.
Aug 19, 2012 | Kenmore 19001
I I my brand new brother xr-7700 manual says to look on page 49 -50 for monograming but NOTHING THERE
I think that you will find that monogramming is done free style, we used to lower the feed dog and put our piece to be monogrammed into an embroidery hoop then use a satin stitches and sew whatever we wanted. You can call Brother. I downloaded your manual (after looking at your manual) I see what you mean
Apr 16, 2011 | Brother XR7700
I have loose loops on the top side of my fabric when i monogram, what should i do?
The first thing to try is to decrease the upper thread tension as it may be too tight. You also may need to increase your bobbin tension. Another possibility is that your machine may need to be re-threaded in case it's not threaded correctly.If none of these solutions work, you may have to change the needle as it may be bent. Also, make sure your needle is the right one for this type of fabric and thread.
I hope this helps.
Mar 22, 2010 | PfaFF Creative 7570
Husqvarna viking Platinum 775 fabric won't advance
Most of the time the bobbin case gets hung under the feed dogs, take your needle plate off and the bobbin cover there is a gray colored finger with a number 10 torx screw holding it in you can also try a small flat head screw driver, remove that finger and then remove your bobbin clean the hook out and replace the bobbin making sure it seats itself on the hook with the small notch on the bobbin case lining up with a small metall spring on the back right side of the hook area.
Jun 07, 2009 | Husqvarna Sewing Machines
Singer Futura Xl-400 All-In-One Sewing And Embroidery Machine Logo
59 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
