Question about Garden
What is the fuel mix ratio for Efco DB26 Trimmer?
    Habit-Forming:
  • 99 Answers
50:1
Posted on May 17, 2014
  • Garden Master
  • 2,448 Answers
I have been using 100 milliliters of 2 cycle oil to 4.5 liters of gas in all my 2 cycle engines and have had no trouble Been doing this for years. I bought a 100 milliliter can of oil at a store and used it Now I by a big can and pour out of the big can into the little one to get the right mixture. Cheaper that way as well.
AlmostBob
  • 550 Answers
SOURCE: Gas/oil mix ratio for Ryobi Trimmer
50:1
Posted on Oct 10, 2008
panilling9
  • 284 Answers
SOURCE: HT-17 Hedge Trimmer Fuel Ratio?
I use 40:1 in mine always have works perfect 3.2oz of reputable 2 cycle oil to one gallon of fresh gas
try to find the oil that has fuel stabilizer already in it
Posted on Jun 12, 2009
AUTODOC01
  • 216 Answers
SOURCE: gasoline mix ratio for Efco 8753 brushcutter
if you buy the small bottles of oil mix it with one gallon of gas easiest way .
Posted on Aug 25, 2009
  • 10 Answers
SOURCE: What is the correct ratio for fuel mix for a ECHO
A 50:1 ratio with 89 Octane fuel can be used in all ECHO 2-stroke equipment, provided the oil is ISO-L-EGD and JASO M345 FC/FD certified. ISO-L-EGD and JASO M345 FC/FD oil must be used with a mid-grade (89 octane) or premium gasoline in all 1997 and newer engines.
A 50:1 Ratio = 1 US Gal. 89 Octane + 2.6 fl. oz. ECHO POWER BLEND OIL
Echo Power Blend Universal 2-Stroke Oil can be used in all of our 2-cycle air-cooled equipment ever made. You may also use this oil in any other brand of 2-cycle air cooled equipment, but it should always be mixed at the 50:1 ratio whether or not it was a 32:1 or 16:1 etc. machine. This oil is the highest quality 2-cycle oil on the market today. There is no need to have more than 1 tank of fuel for your 2-cycle equipment any more.
Use only fresh gasoline with a minimum octane rating of 89 through 93 (mid-grade to premium) at all times. The gasoline suppliers blend mid-grade and premium gasoline with greater amounts of detergents and anti-oxidizing additives to keep the engines clean. Lack of these detergents and additives in a 2-stroke engine will cause a heavy build-up of varnish and gum deposits on the piston surface and ring grooves. Regular unleaded 87 octane or lower gasoline may not contain enough of the detergent additives that are needed in a 2-stroke engine to keep varnish, gum, and tar deposits from forming. Use of 87 octane fuel may shorten the life of the engine.
ALL TWO-STROKE OILS ARE NOT EQUAL!
ECHO POWER BLEND OIL, is manufactured exclusively for ECHO, Inc. and meets the (ISO) International Standards Organizations highest performance rating of ISO-L-EGD for Air Cooled 2 Stroke oils and is JASO M345 FC/FD REGISTERED. Years of research and testing have resulted in an oil that is fully compatible with fuels containing 10% ethanol and can be used in all air - cooled, outdoor power equipment 2-Stroke engines at 50:1 ratio. ISO-L-EGD and JASO M345 FC/FD rated oils must be used with a mid-grade (89 octane) or premium gasoline in all 1997 and newer engines. Always look for the JASO M345 FC/FD square logo and registration number to ensure you are using the highest quality 2-stroke oil for your ECHO product.
ECHO POWER BLEND OIL is made for high revving, (7,000 RPM and up) air-cooled 2-stroke engines that are E.P.A. and C.A.R.B. emissions certified. Make sure the oil has a EGD and FC/FD certification. Oils that meet ISO, EGA/EGB/EGC and JASO FA and FB are of lesser quality, designed for applications such as water-cooled boat engines, low RPM lawnmower engines, or snowmobile engines and should not be used in ECHO Engines. Prior to 1997, oils were not manufactured to these higher standards. Some or most of the oils were simply 30 or 40 weight 4-stroke engine oil with minimum amounts of additives. ECHO POWER BLEND OIL is the highest quality 2-Stroke oil available and will provide maximum protection against engine wear and carbon buildup.
Posted on Sep 05, 2009
wilsodfarm
  • 986 Answers
SOURCE: what is the fuel mix ratio for a homelite ut15084c
50 to 1
Posted on Oct 18, 2009
Testimonial: "thanks for the quick response"
What is the fuel mix for efco tg2600xp
25:1
CAUTION: DO NOT USE AUTOMOTIVE OIL OR 2-CYCLE OUTBOARD OIL
Jul 28, 2017 | Efco Garden
What is gas to oil mix ratio on weedeater string trimmer
The ratio is 40:1 Just add 3.2 ounces of 2 cycle oil to one gallon of fuel. Be sure to cap off the tank and shake to distribute the oil throughout the fuel before adding to weed eater.
Sep 19, 2014 | Poulan/Weed Eater No. Te475 952711797 17"...
McCulloch MAC 60 SX trimmer fuel mixture ratio is?
Check the links below for fuel/gas ratio.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
User manuals McCulloch Service
I trust this information proves beneficial.
May 26, 2014 | McCulloch Trimmer Plus Attachment: Add On...
Troy built 27cc string trimmer Model TB21 EC. What is the gas oil mix ratio?
4 cycle engines do not run on mixed fuel. Run on straight fuel. They have a spot to put oil in just like a lawn mover, and should be changed regularly. @ stroke engines run on mixed fuel.
Sep 27, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
FUEL MIX
Oil Mix Ratio:
The following ratios have been recommended for the last 10-15 years.
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
McCulloch, Poulan & Wen; recommend 40:1.
1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
Chinese chainsaws recommend 25:1.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Sep 05, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Fuel oil mix for a Poulan 14" saw ?
Oil Mix Ratio:
Sep 02, 2010 | Garden
Need to know the gas to oil ratio for my feather lite weedeater. Model FL21
"Echo Power Blend Universal 2-Stroke Oil can be used in all of our 2-cycle air-cooled equipment ever made. You may also use this oil in any other brand of 2-cycle air cooled equipment, but it should always be mixed at the 50:1 ratio whether or not it was a 32:1 or 16:1 etc. machine. This oil is the highest quality 2-cycle oil on the market today. There is no need to have more than 1 tank of fuel for your 2-cycle equipment any more."
The above excerpt is from the Echo FAQs (6) here:
http://www.echo-usa.com/faqs/
Oil Mix Ratio:
Lou
May 17, 2010 | Echo Rapid Loader, Trimmer Head
Model PM374 mixture ratio please
Hello George:
I cannot find an OM for your saw. I did find 3 IPLs the oldest being 1993. I have 2 McCulloch (1983 & 87) saws both older than yours and their OMs recommend the current mix ratio of 40:1
Oil Mix Ratio:
Lou
May 10, 2010 | McCulloch Garden
Fuel mix ratio for poulan counter vibe 3400 chain saw and for a homelite st-145 weed trimmer
Oil Mix Ratio: (last 5-10 years)
If me I would have the Poulan tweaked to run properly on 50:1 and use that in both. It will start easier and take much longer to carbon foul.
Lou
Apr 30, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Gasoline mix ratio for Efco 8753 brushcutter
Aug 25, 2009 | Garden
Garden Logo
73 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
