Question about Orion 1200D Car Audio Amplifier
Orion 2400 watt competion amp led on top doesnt light up
3 Suggested Answers
etirbynnor
  • 655 Answers
SOURCE: wiring diagram
Hello rivertoyz,
If your F250 has the stock radio, there are no preamp outputs, so you will need to use the speaker outputs. The best solution would be to wire a LOC (line output converter) to the rear channels and run RCA cables to the amp.
Speaker wire color code:
Left rear positive - Gray/Light Blue
Left rear negative - Tan/Yellow
Right rear positive - Orange/Red
Right rear negative - Brown/Pink
You'll need an amp wiring kit with 4gauge power and ground. Both the LOC and wiring kits are available at numerous online stores. The best service is from www.crutchfield.com. Another reputable online seller is www.sonicelectronix.com.
You did not say what subwoofer(s) you intend to use with the amp. If you want to stick with the Maxxsonics product, a pair of 10" Orion HP10D2's would be an excellent match. Wire each of the subs dual voice coils in series for 4ohms, then parallel them to the amp for a final load of 2ohms. Both of the linked retailers above sell the Orion's and many other brands as well. Just make sure that your sub selection has adequate power handling capability. At least 1000 watts RMS if you use a single sub and 500 watts RMS if you go with 2.
Hope this helps.
Posted on Jun 02, 2009
  • 8 Answers
SOURCE: orion 2400 mono
the amp needs to reset.
Posted on Jan 17, 2013
Green light comes on for a sec the red light comes on,1200 watt sony xplod amp 10'' Orion sub,I think the subs right around 3000 watts. What's wrong?:(
Your Sony Xplod amplifier turns on briefly (green light) then possibly senses a mismatch between the nominal output impedance of the amplifier and impedance of your Orion sub and goes into protect mode (red light) to prevent internal damage.
Jul 19, 2014 | Car Audio & Video
Will a 800 watts run an orion h212.2 subwoofer
Depending on the type of amp, yes. not all amps are created equal, just because it says 800 watts doesnt make it so. but a true 800 would be plenty.
Dec 31, 2012 | Orion H2 12.2 Car Subwoofer
IS ORION HCCAD5000 AMP ENOUGH FOR 2 ORION HCCA10.2!
No. These subs are rated at 1500 RMS each. So you need an amp that will produce at least 3000 watts RMS at 2 ohm load or if you wire each sub to a separate amp down to 1 ohm...then you will need an amp that will produce at least 1500 RMS. Those subs can handle more than they are rated though.
Sep 19, 2012 | Orion HCCA 10.2 Car Subwoofer
How many 100 watt light bulbs can I hook to a 20 amp breaker (120 volts)
A 20 Amp breaker will support 2400 Watts with a 120 Volt line.
120 Volts times 20 Amps (Amperes) = 2400 Watts.
Answer? 24 100Watt light bulbs.
HOWEVER, you should always allow 1 cushion of 100 Watts.
That would be 23 100Watt light bulbs.
(Wait until you add electric motors to the equation. Things start getting a little more complicated)
(I always use 20 amp breakers for lighting. 15 amp breakers for lighting is phased out.
Secondly a 20 amp breaker requires using 12-2 or 12-3 wiring. (12/2, 12/3)
SO does the receptacles.
Therefore 12 gauge wiring is used throughout the house, until you come to the heavier loads )
[ 12/2 = 2 insulated conductors, and one bare copper ground wire.
12/3 = 3 insulated conductors, and one bare copper ground wire.
Remember, with 12/2 the Black wire is ALWAYS the Hot wire. White is Common (Neutral). Bare copper is Ground wire.
12/3 has 3 conducting wires.
One Black, one Red, and one White for the Common. (Neutral) Bare copper is Ground.
Used for 3-way switches ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 30, 2011 | Hammering
Why doesnt my 2400 watt amp turn on?
The size of the wire affects the performance of an amp, but the amp should still turn on. 12 volts is 12 volts. So you tested with another amp, on the same wires, and it works fine.The only thing you can really check on the new amp is the fuses in the side. If those are blown, then you should be able to (Unless the amp is fried, and that's why it blew the fuses in the first place) fire it right up. If the fuses arent blown, and you have all your power, and ground, and still nothing.. Well then in that case the amp is just bad, and regardless of the wattage, you just don't fix a Pyle amp.
Aug 08, 2009 | Kenwood KAC-8152D Car Audio Amplifier
Wiring diagram
Hello rivertoyz,
Hope this helps.
Jun 01, 2009 | Orion XTR Pro 2400 Car Audio Amplifier
Orion xtr15 to a american leagacy la 660 amp
your only choice is to run the amplifier at a 4 ohm mono load - this will not reult in the amplifier making much power.
Positive on sub to Positive on amp.
Negative on sub to Negative on amp.
This is your only possibility.
Adding a second sub in the same fashion will result in a 2 ohm load, and your amplifier will run at its rated potential.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Mar 05, 2009 | Orion Xtreme XTR15 Car Speaker
Orion 2400 mono
My esp light is blinking yellowish and the amp isn't putting out. I have power to it, just not putting power to my subs. anyone know how to help?
Feb 25, 2008 | Orion XTR Pro 2400 Car Audio Amplifier
Amp not working correctly goes into protection
Disconnect the speaker wires from the amplifier and see if it still goes into protection mode. If it still goes into protect with the speakers disconnected, there's a problem with the amp; if not, you may have a blown speaker or a shorted speaker wire.
Feb 22, 2007 | Legacy LA2098 Car Audio Amplifier
Orion 1200D Car Audio Amplifier Logo
Top Orion Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Mark Skinner
Are you an Orion Car Audio and Video Expert? Answer questions, earn points and help others
