Question about Plumbing
I have a 1992 Lincoln town car and i would like to know how much atifreeze do i need to put back in once i flushed the car and do i need to pt it in while the car is running?
    Novelist:
    Champion:
  • 210 Answers
Marcus, if possible, find the capacity of the cooling system and refill with a mixture of 50/50, water to anti-freeze. You can buy it that way, but I don't recommend it as you wind up paying for water you can get from a hose in your back yard. When you start your refill, the radiator will fill first, then the thermostat will be closed, so it won't let the anti-freeze move in to the motor block At this point you should start the engine, warm it up and wait for the thermostat to open. When that happens, it will take all the liquid you had in the radiator and put it into the block. Fill the radiator as the engine warms up. When the liquid levels off, won't take any more without overflowing, you're done. You should have had the cap tested to make sure it holds the recommended pressure for the system before you started this project, so either replace the old cap on the system or put on the new one, and you're done. .
Posted on May 17, 2014
Fuse number for a 1992 lincoln
92-94 Lincoln Town Car Fuse Box Diagram - Auto Fuse Box ...
www.autofuseboxdiagram.com/8895-92-94-lincoln-town-car-fuse-box-...
Sep 11, 2012 - 92 94 Lincoln Town Car Fuse Box Map 276x300 92 94 Lincoln Town Car Fuse Box 92-94 Lincoln Town Car Fuse Box Map. Fuse Panel Layout ...
Aug 26, 2015 | 1992 Lincoln Town Car
Replace an ignition switch on an 1992 Lincoln. Town car
Im not a mechanic nor an expert but I have had my ignition switched replace. I know that u have to remove the steering wheel in order to remove the switch. Thats the only hint I have but if u need to start car ASAP I do know how to get it to start by guting out the switch and using a screw driver to start the ingine.
Feb 18, 2012 | 1992 Lincoln Town Car
2000 Lincoln Town Car. The A/C unit is erratic. When I increase speed, the a/c blower increases. To get any heat I have to put the temperature to 90 degrees. Any advice?
The heater core and radiator require flushing every 2 years / 24,000 miles.
The coolant cap on the reserve tank need to be pressure tested.
Please do the flush with water and it it circle for 1 day then re-flush again
Fill with 50/50 coolant mix.
Jan 31, 2011 | 2000 Lincoln Town Car
The motor runs, but does not operate the power window on the passenger side, front.
I have same problem in my 1992 Lincoln town car? I wish to know the answer to this question to. Please someone help!
Nov 07, 2010 | 1992 Lincoln Town Car
I need a belt diagram for a 1992 lincoln town car
hi,
sir i was not able to get you the exact full sized picture for but this will help you.......since 1992 model it is not available in net....]
http://images.google.co.in/images?hl=en&q=serpentine%20belt%20diagram%201992%20lincoln%20town&um=1&ie=UTF-8&sa=N&tab=wi
you cant enlarge the image because it is removed
Sep 28, 2009 | 2004 Dodge Durango
How do I repair an oil leak from the oil filter for a 1992 Lincoln Town Car
Make sure the old filter gasket is not stuck on the filter housing. sometimes the old filter gasket comes off the old filter and when you put on the new one it will leak.
Mar 28, 2009 | 1992 Lincoln Town Car
Plumbing Logo
70 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
