Question about Garden
Lawn tractor troubleshooting
Wheel Horse 264H Appears to be not drawing fuel, How do you test the fuel pump?
  • 4 Answers
More than likely this tractor has a diaphragm fuel pump. The only way of testing these kinds of pumps is to take them apart and make sure the diaphragm is not tore.
Posted on May 17, 2014
SOURCE: DYT 4000 Lawn tractor won't start
I solved the problem after buying carb and fuel pump rebuild kits.The carb kit didn't fit anyway, but didn't need it. The problem was in the fuel filter. I had forgotten the problem happened when I ran out of gas. Inside the fuel filter is a washer held in place by a spring. Without fuel it apparently lost pressure and the washer slipped out of place about 1/2", which was enough to let all the gas through that could. The rebuild kit had a new rubber gasket. I won't let it run out of gas again.
Posted on Aug 11, 2009
  • 548 Answers
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Posted on Aug 22, 2009
  • 8404 Answers
SOURCE: NEED MANUAL FOR TORO WHEEL HORSE GARDEN TRACTOR 416-8
As far as I understand, fixya.com does not stock or sell this mataerial. The purpose of this site is to get direction on a course of action to follow ...
Here is my suggestion ... if you have looked in the manuals section of fixya.com and not found what you are looking for, visit the manufacturers web site which is probably www.toro.com/wheelhorse or something very similar ... Google it to find it ... or you could search www.archive.org
Thanks for using fixya.com
If this helps you, positive comments are appreciated
a
Posted on Oct 26, 2009
SOURCE: john deere 425 lawn tractor. it wont start but it
My John Deere did the same thing. Turned out to be the emergency brake sensor.
Posted on Jan 21, 2010
SOURCE: Poulan Lawn Tractor 42" 14.5 hp Model 733-864 How ...
I need the diagram for a drive belt for a 42'' lawn tractor - 14.5 hp Can ANY ONE help me?
Posted on Jul 14, 2011
Not getting gas to carb. changed fuel pump, bypassed filter. hold gas line below tank and fuel comes out. but not being sucked through pump it appears. help
It has a pressure differential fuel pump, just put a little fuel in the carb. and it should start it may stall but do it 1 more time and then it will stay running as it uses the crank pressure to actuate the fuel pump
May 08, 2015 | Toro Garden
Fuel pump will not draw fuel
check for vacuum while cranking then check the lines for restriction then replace the pump
Apr 18, 2012 | Husqvarna Lawn Tractor  25 HP 54in Deck...
I need to locate a owners manual for a wheel horse 1978 312-8 tractor
I have found this older printed manual of a Wheel Horse lawn tractor for sale on the internet.
http://www.atomicmall.com/view.php?id=705372
I have NOT located the manual for your exact model yet.
Jun 12, 2011 | Garden
Briggs and stratton lawn tractor -463707-0168-f1 fuel line witch side of the carb. dose the fuel line conect ,or dose it conect to the brass fitting @ the bottom of the fuil pump. i wish i could draw you...
My name is Dane and I'll try to help you with your problem. Fuel line will go to the fuel pump. the two other lines on the pump go to the carb and engine vacume. Thanks Dane
Dec 02, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Mower keeps cutting off... It seemed like water in the gas. so I took fuel line off , but no fuel is coming in from the tank. Is this a top draw? Why am I getting no fuel
it should have a gas tank under th seat and it has a fule pump that pulls the gas up to the carb that dosent mean the pump is bad you may need a carb kit
Oct 11, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
What kind of oil do I use in a Wheel Horse lawn tractor?
Your Onan engine will do excellent with Mobil One 0w40, Mobile One 5w30.
DO NOT use hydraulic oil in the transmission/transaxle, you will destroy it. Your tractor uses an Eaton 11 Hydrostatic transmission pump with the oil resevour being the cast iron transaxle. The WheelHorse transaxle is as rugged as they come. It uses a solid cast iron housing, case hardened intermediate gears and forged differential gears with an eight pinion differential.
Your transaxle requires 10w40 synthetic or conventional oil as well as a wix 51410 filter or the OEM wheelHorse filter. It should be changed every 100 hours with conventional oil or 250 hours with synthetic. DO NOT use hydraulic oil!
Jun 24, 2009 | Garden
does it have a manual fuel shut off or a electric selenoid type
May 17, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Cant get gas from tank to engine
check to see if there is a fuel pump diaphram first and rebuild or replace it , otherwise you arent getting any vacuuum in the carb to draw the fuel in.
Apr 17, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
