Question about Toshiba e-Studio 282 Printer
How to remove error e712 - Toshiba e-Studio 282 Printer
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 115 Answers
Clean RADF (document feeder) feed rolls with wet cloth, and open RADF cover and blow air so to clean and dust or small paper.
Posted on Jul 06, 2014
Tip
Error codes related to Canon ir 2200/2800/3300
E000 Heater temperature fault
(fails to increase)
E001 Overheating detection error
E002 Heater temperature error (fails to reach
specific level; inadequate increase)
E003 Heater temperature error (abnormal
drop; low-temperature detection)
E007 Fixing film rotation error
E010 Main motor rotation error
E014 Fixing motor rotation error
E019 Waste toner case full, sensor error
E032 DA unit communication error
E051 Horizontal registration HP
detention error
E064 Power supply voltage error
(high-voltage error)
E100 Laser BD error
E110 Polygon motor rotation error
E202 No. 1 mirror base HP detecting error
E204 ADF image leading edge signal
detection fault (absent)
E220 Lamp ON error
E225 Standard white plate/edge white
plate read error
E240 Mcon-Dcon communication error
E243 Mcon-control panel
communication error
E248 Backup (EEPROM) error
E261 Zero-cross signal error
E302 Shading error
E315 Image data processing error
E601 Image transfer error
E602 Hard disk error
E604 Image memory fault
E605 Image memory battery fault
E606 HDD error
E674 Fax board error
E677 PDL board mounting error
E710 IPC initialization error (Rcon)
E711 IPC register error (ctrl)
E712 Communication error (with ADF)
E713 Communication error (with sorter
finisher)
E716 Communication error (with pedestal)
E717 Communication error (with ASSIST)
E719 Card reader, coin vendor
communication error
E732 Reader communication error
E733 Printer communication error
E737 SDRAM error
E740 Ethernet board error
E741 PCI bus error
E742 RIP1 board error
E743 Mcon-Rcon communication error
(Rcon detection)
E744 Language error
E746 Resolution conversion board error
E803 MPWS power supply voltage error
(low voltage error)
E805 Fan rotation error
E901 Pedestal main motor rotation error
[ADF]
E420 Back-up data read error
E421 Back-up data write error
E422 IPC error
[Saddle Finisher-G1]
E501 Communication error (Punch unit)
E505 Back-up RAM
E510 Feed motor
E514 Delivery motor
E530 Width plate shift motor
E531 Stapler motor
E532 Stapler slide motor
E537 Alignment motor
E540 Tray ascent/descent motor
E577 Paddle motor
E590 Puncher motor
E592 Puncher sensor error
E593 Puncher shift motor
E5F1 Saddle folder motor
[Finisher-J1]
E500 Communication error
E514 Stack handling motor
E530 Rear alignment motor
E531 Stapler motor
E537 Front alignment motor
E577 Delivery motor
E580 Delivery tray ascent/descent motor
E585 Stack handling error
If the thermistor has a short circuit, the indication in service mode
(COPIER>DISPLAY>ANALOG) will be as follows from the start: FIXC=250°C
for the main thermistor; FIX-E=310°C for the sub thermistor.
Error codes from E000 to E003 can be in some cases reseted from service mode: PROCEDURE:
Press*
Press2
Press8
Press*
Navigate to: COPIER>FUNCTION>CLEAR>ERR.
Turn off and on.
on Aug 03, 2010 | Office Equipment & Supplies
My husband seems to have blown a fuse in our cerwin vega E712 speaker. please advise the model fuse we will need to replace it and were we can purchase the fuse.
Hey
it's a 2.5Amp Slow Blow 2AG fuse..
Most electronics stores stock fuses..also to being a 2AG fuse they are exactly the same as the old auto fuses and thus most auto stores carry them in stock aswell..
but remember.....Fuses blow for a reason
and NEVER put a bigger fuse in!!!. try and find the fault....unless he has just cranked it too much :-)
hope this helps!,ben
Jan 13, 2011 | Cerwin Vega Audio Players & Recorders
Tip
ERROR codes Canon 9800
Canon 9800 E000 The surface temperature of the fixing assembly upper roller fails to rise by a specified value within 90 sec after power-on. The surface temperature of the fixing assembly upper roller fails to reach 150 C within 8 min after power-on. E001 The surface temperature of the fixing assembly upper roller exceeds 250 C. E005 The cleaning belt inside the fixing assembly has been taken up more than a specified length. E010 After generation of the main motor drive signal, two or more pulses are not received within 2 sec. E013 The error detection circuit on the waste toner feed motor driver PCB has detected an overcurrent. E020 The accumulative time during which the toner supply signal (TSP) has been generated by the developing assembly reaches 3 min*. E050 The holding tray home position signal (THP) is not generated within 4 sec while the holding tray motor drive signal (TMDP1, 2) is being generated. The holding tray home position signal (THP) is generated 1 sec or more while the holding tray motor drive signal (TMDP1, 2) is being generated. E203 Input of two or more clock pulses is not received within 2 sec from the scanner motor drive signal is generated. E210 The lens home position signal (LHP) is not generated within 4.8 sec after power switch or door switch has gone ON. The lens home position signal (LHP) is generate 2 sec or more. E240 An error has occurred in the microprocessor on the DC controller PCB. E243 An error has occurred in the microprocessor of the DC controller PCB and the microprocessor in the control panel. E710 An error has occurred in the communication between the DC controller PCB and the controller PCB of the option, and the DC controller has detected the error. E712 No communication is perceived from the RF controller PCB for 200 ms or more the communication is monitored at all times.
on Jan 19, 2010 | Office Equipment & Supplies
Tip
ERROR codes Canon 6150
Canon 6150 E000 Thermistor E001 SSR E002 Thermistor, ht. Lamp thermal fuse or SSR E003 Thermistor, ht. Lamp thermal fuse or SSR E005 Fuser cleaning belt E010 Main drive problem E020 Toner motor, toner level sensor, toner hopper sensor E030 Counter E050 Duplex problem E203 Scan home problem E210 Lens home sensor E401 Document feeder paper pickup motor E402 Document feeder belt clock pulse problem E403 Document feeder main motor clock pulse problem E411 Document feeder sensor problem E500 Sorter/copier interface problem E510 Sorter motor drive E530 Sorter home sensor E531 Stapler swing sensor E540 Sorter lead cam home sensor E541 Sorter lead cam home sensor E710 DC controller board E711 DC controller board E712 Document feeder problem
I have erorr e712 i don't know what is that mean
hi E712 on canon can be one of this element:
  • Connector of RDF (poor contact) ( clean with electronic liquid cleaner)
  • RDF controller PCB is faulty
  • 24V power supply is mising
Oct 24, 2010 | Canon NP 6035 Copier
Tip
ERROR codes Canon 3825
Canon 3825 E000 Low fuser temperature. Heat lamp, thermoswitch, thermofuse, thermistor, SSR E001 High fuser temperature. Thermistor, SSR, pinched wire E002 Low fuser temperature. Same as E002 E003 Same as E000/E001 E010 Same as E002 E022 Motor drive problem E030 Counter E202 Scan motor, sensor E204 Scan motor, sensor E210 Lens motor, sensor E220 Exposure lamp E240 DC controller (main board) E401 Pickup drive problem (might be Doc. Feeder) E402 Document belt drive problem E404 Exit motor (document feeder) E411 Document sensor (document feeder) E500 Sorter/machine communication problem E510 Sorter drive problem E530 Sorter home sensor E531 Stapler unit swing sensor E540 Sorter cam sensor E541 Sorter cam sensor E710 DC controller (main board) E712 DC controller or document feeder board
on Jan 18, 2010 | Office Equipment & Supplies
Tip
ERROR codes Canon 3325
Canon 3325 E000 Low fuser temperature. Heat lamp, thermoswitch, thermofuse, thermistor, SSR E001 High fuser temperature. Thermistor, SSR, pinched wire E002 Low fuser temperature. Same as E002 E003 Same as E000/E001 E010 Same as E002 E022 Motor drive problem E030 Counter E202 Scan motor, sensor E204 Scan motor, sensor E210 Lens motor, sensor E220 Exposure lamp E240 DC controller (main board) E401 Pickup drive problem (might be Doc. Feeder) E402 Document belt drive problem E404 Exit motor (document feeder) E411 Document sensor (document feeder) E500 Sorter/machine communication problem E510 Sorter drive problem E530 Sorter home sensor E531 Stapler unit swing sensor E540 Sorter cam sensor E541 Sorter cam sensor E710 DC controller (main board) E712 DC controller or document feeder board
Tip
ERROR codes Canon 3050
Canon 3050 E000 Fuser temp low. Heat lamp, thermoswitch, thermistor, SSR E001 Fuser temperature too high or shorted thermistor E002 Fuser temperature too low E003 Fuser temperature too low E004 SSR, or lamp reg. board E010 Drive problem E022 DV unit switching problem E030 Counter not working/open E202 Scan problem. Scan sensor, scan motor E204 Scan problem. Scan sensor, scan motor E210 Lens problem. Lens sensor, lens motor E220 Exposure lamp E240 DC controller (main board) E400 RDF circuit board E401 RDF pickup motor drive E402 RDF belt motor drive E403 RDF feed drive problem E404 RDF exit motor E411 RDF sensor problem E500 Sorter board problem E510 Sorter feed motor E512 Sorter delivery motor E514 Sorter delivery motor E520 Sort stack motor E530 ******** motor E531 Stapler motor E535 ******** motor E540 Shift problem E541 Shift problem E710 DC controller E711 DC controller E712 DC controller. Document feeder board or cable
Tip
ERROR codes Canon 3030
Toshiba e-Studio 282 Printer Logo
180 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
