Question about Watches
I need to know the size of the battery for a Arkitekt FS3038 Fossil Watch
I lost the battery so now I cannot find the size
5 Suggested Answers
escapement
  • 2334 Answers
SOURCE: REMOVING LINKS FROM FOSSIL ARKITEKT MENS WATCH
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 09, 2009
slp11508
  • 43 Answers
SOURCE: remove links from fossil metal band
The links most likely need a tool that will push the pins out so you can adjust the bracelet. This can be easily done by any jeweler or watch store. You can also order these types of tools online to do it yourself at home. Please do not attempt to remove links without the proper tools as you will not be able to remove them and you will also damage both the bracelet and the pins.
Posted on Jan 14, 2009
SOURCE: can't find the watch band for fossil arkitekt fs
I have the same watch Fossil FS-4127 and I too can't find a replacement band. Appears to be planned obsolesence by Fossil. This FixYa site is almost as bad as Fossil, which is all advertisements and no answers whatsoever.
Posted on Jan 28, 2010
gemineye61
  • 831 Answers
SOURCE: I don't have the original battery to my watch, and
<P>Thank you for contacting FixYa.</P><P>Unfortunately, unless it is stamped on the back of the watch, or it is in your manual, there is no way of knowing the battery that goes in any watch without the old one, or very accurate sizing of the area it goes in. You can try to contact Fossil via this link:</P><P><A href="http://www.fossil.com/en_US/shop/customer_care/static/fossil-customercare.html">http://www.fossil.com/en_US/shop/customer_care/static/fossil-customercare.html</A></P><P>Best regards.</P>
Posted on Aug 24, 2010
I lost the battery to my women's Skagen watch style 355SSGS. Whaat is the battery size that I need to buy? Thankss
Take your watch to a jeweler who, for a reasonable sum, wil install the correct replacement battery
Dec 04, 2016 | Skagen Watches
Battery size for Jr-9118 i lost old battery
The battery is a 371 eveready will cross reference to many
Sep 16, 2016 | Watches
What battery size does a fossil arkitekt fs-2759 take? Thank you
Just take the watch to your nearest jeweler. They can quickly replace it for you....probably cheaper than what you would pay for the battery yourself.
Mar 02, 2015 | Fossil Watches
What kind battery does a pulsar pj6054 take?
have you check the bottom of your purse .that where wife usually find lost little thing EH!
Jan 29, 2015 | Pulsar Watches
What size of battery does a Nixon The Esquire use
A jeweler will be able to get the right size in there. Most jewelers will do it for the cost of the battery.
Sep 04, 2014 | Nixon The Esquire Watch
What is the battery size for fossil fs4159
Take your watch to a jeweler to identify type and possibly replace it.
Jun 16, 2014 | Fossil Arkitekt watch
Lost battery
RENETA Battery # 321
or
maxewell battery # SR616SW
Apr 07, 2014 | Kenneth Cole Kc9109 New York MenS Kc9109...
HOW TO REPLACE BATTERYIN MY FOSSIL ARKITEKT WATCH
Take your watch to a jeweler for battery replacement.
Feb 15, 2014 | Fossil Arkitekt watch
Lost battery foe guess watch U13586L2
I just opened my watch to replace the battery. The number on the battery is: SR920SW
Hope that helps.
Feb 08, 2014 | Newegg Guess Womens U13586l2 Silver...
Watches Logo
23 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
