Question about Panasonic Technics Sa Gx100 Amplifier Tuner Stereo Receiver Am/fm Audio Control Center
Technics receiver no sound and all connections are correct
Amplifier does not seem to work. What part inside could be replaced?
2 Suggested Answers
  • 4234 Answers
SOURCE: My Technics stereo system ...the display screen shows nothing
The question is, do you hear any sound? Is just the display off or is the entire unit shutdown? Can you tell?
These displays are known to develope poor solder connections at the power input and ground pins. If you can solder, open up the unit (unplugged of course) and examine the pins for the display. This will be on the PC board attached to the front panel. The pins at either end of a long line of pins will be the power and ground pins. Reasolder those pins, taking care not to short the pins together and try the unit once done. If that does not resolve the problem (assuming it is just a display problem), update this with as many details as you can about the behavior of the unit and we'll look further.
Dan
Posted on Nov 18, 2009
Can i hook a amplifier to my technics receiver model no sa-ax720
If the Amplifier has more Output Power and Better Quality Sound then it is worthwhile to do so -Yes you can connect Amp to Technics Receiver you have mentioned
Jun 24, 2015 | Technics Audio Players & Recorders
What are the functions of the impedance button on the Technics SA-AX730
This allows you to select the correct amplifier output impedance for the particular speakers you have connected, Proper selection insures the best efficiency, response and prevents potential damage to speakers or the amplifier, Refer to page 17 of this manual:
http://audio.manualsonline.com/manuals/mfg/technics/technics_sa_saax730.html
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Nov 20, 2014 | Technics Audio Players & Recorders
My technics sh-eh780 stereo seems to work but the sound is very dull in sound
Unless there's an issue with internal components of the amplifier or speakers, a common cause of this is reversed speaker polarity.
The wires between the + and - terminals of the speakers MUST connect to the same + and - terminals on the back of the stereo amplifier. The speaker wires that came with the stereo are color coded to help prevent mis-wiring. If you did not pay attention to this or used different wires for any reason, you need to ensure that the wires between the each of the speaker's 4 terminals connect to the correct group and + / - terminals on the amp.
See page 6 of the manual here: https://support.panasonic.co.nz/docstore/SC-EH780%20Operating%20Instructions.pdf
Make sure that the surround and center speakers are connected correctly, too.
Apr 06, 2014 | Technics SC-EH780 CD Shelf System
Hi I just got a Technics SU V2 amp and can't get sound from the speakers. What size speakers would suit this amp? What is the correct method to connect the speaker leads to the back of this amp,...
Being a 500W amplifier, you need to connect speakers with 300W each. The correct method to connect speakers is red terminal of speaker should be connected to red terminal of amplifier & black to black. The left side to left side speaker & right to right speaker. There may be main & remote terminals. Main speakers are the speakers at local place of the amplifier & remote for remotely placed speakers. I do have Technics SU-V85A which is somewhat similar. Enjoy! A nice piece to listen.
Oct 22, 2011 | Technics SUV500 2-Channel Amplifier
Technics su z2 amp shuts off sound
hello. we cant help if we dont know what music source you are using.
Apr 13, 2009 | Technics SA-AX530 Receiver
Problem with subwoofer and one off the speakers.
check out the amplifier ic in the receiver unit of subwoofer as the number of ic is IC346JC this has to be replaced.
Mar 13, 2009 | Technics SA-DX940
TECHNICS SUPER BASS, DOUBLE BASS AND TRIPLE AMPLIFIER
Have you checked all circuit boards for good solder connections.
Also if the boards had been wet from anything, you might clean the boards and resolder all connections specially in the power supply and audio section.
Let me know.
Jan 26, 2009 | Technics SUV500 2-Channel Amplifier
I need help
Loose connection on "POWER-SUPPLY" and sometimes solder loose on "C I S BOARD" due to extreme - heat of amplifier. $137.51 repair done in 1HR as I waited at CENTURY SOUND ELECTRONICS.
Jan 19, 2008 | Audio Players & Recorders
Panasonic Technics Sa Gx100 Amplifier Tuner Stereo Receiver Am/fm Audio Control Center Logo
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
