Question about Craftsman Garden
Battery won't charge How can I trouble shoot electrical
    Problem Solver:
  • 11 Answers
*if your battery wont charge,
1) you might check for an "in-line" fuse from the "stater" to the starter cyliniod . could be blown.
2) or the "stater" , which is located under the fly wheel is gone bad.. it will need replaced..(this isnt cheep)
3) make sure all your battery and cyliniod wire leads are good and tight.
p.s. IM TYPING "S.T.A.T.E.R." not starter..the charging mechanism is called a "stater" not alternater...f.y.i.
Posted on Jun 24, 2009
Battery light on 96 lexus ls400 replace battery and alternator
Did you check fuse's ? there has to be B+ voltage to the alternator for it to work . Four wires at the Alternator ? If you want to try an fix this yourself , which I don't think you should if you don't know automotive electrical systems . Go to youtube an check out some videos on charging system testing an on basic electrical trouble shooting . Then go to www.bbbind.com/ for wiring diagrams of the charging circuit .
Dec 15, 2015 | Lexus Cars & Trucks
Battery wont start the car ,ill charge the battery its ok for a few hours then its dead ,alt charging good ,battery is new,every fuse in both pannels are hot with key off please help
The battery dies after sitting for a few hours ? Parasitic drain on the battery ! With the key off all fuse's shouldn't be hot ! Bad ignition switch . Find a wiring diagram at www.bbbind.com an check power at ignition switch . Look on you tube , a lot of videos on basic electrical trouble shooting .
Nov 13, 2015 | Cars & Trucks
My odometer was flashing when I stopped when I continue down road it went blank cut bike off try to start back it killed battery couldn't even charge it
Hi, Wesley and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Faulty starter button/switch.
6. Faulty jiffy stand or clutch pull in switch/sensor.
7. Security alarm needs a reset.
8. Starter control circuit, relay, or solenoid faulty.
9. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have nice a day.
What to do When Your Motorcycle Won Start
Steps to Take When Your Motorcycle Won Start Dennis Kirk Powersports Blog
TROUBLE SHOOTING
What Do Check When My Motorcycle Won Start Honda Shadow Forums Shadow...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jul 05, 2015 | Road Motorcycles
Bobcat just quit running while I was feeding hay. no lights no nothing
Also check cables and connectors. One connector could have become hot and made a shortage.
Jan 17, 2015 | Cars & Trucks
Troubleshoot battery
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 06, 2012 | Acer Aspire 5600 Series 5630-6951 Laptop
My poulan pro lawn tractor won't start. when i turn the key it click's 1 time can you help ?
Have you checked the battery terminal connections? Is the battery charged fully? Are you sitting on the seat when you try to crank the mower? Could be any of the above but most likely battery connection or the battery is discharged or old.
Aug 20, 2012 | Poulan Pro Lawn Tractor 2006 and Newer...
My Acer Aspire one notebook ZG5 won't turn/boot on, help?
1. Dead AC adapter
2. Dead battery
3. Broken AC-socket on laptop, so no power is received, and battery is not charging.
4. Dead ON/OFF switch
5. Dead motherboard
Take your computer to a qualified technician, for professional trouble-shooting & remediation.
Jul 19, 2011 | Computers & Internet
MY BATTERY WONT STAY CHARGED. HOW DO I GO ABOUT TROUBLE SHOOTING.
Battery problems are usually caused by too long a charge with electricity, thus exceeding the load. try drying the battery in hot sun for a while, then try to use. usually successful.
May 10, 2011 | Sport & Outdoor - Others
Garden Logo
578 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
