Question about spirit2011 Power Supply Power Station 2900mah Power Bank Charger Battery Charge
How do I charge my power bank? - spirit2011 Power Supply Power Station 2900mah Power Bank Charger Battery Charge
Jam hx-hp420 wireless headphones only plays when its connected for recharge battery, when unpugged the charging cable headphones turn off right away
Looking at reviews from their websites, plenty of people have problems with them. Sounds like it's either the battery, or the charge circuit in them. You might want to try one of the battery packs that are used to recharge cell phones if you want to use them. JAM Transit Bluetooth Headphones
cservice@jamaudio.com is their customer service email
for power banks Amazon com Portable Power Banks Cell Phones Accessories
Jan 21, 2017 | The Audio Players & Recorders
I'm lost I have a superex slim power bank 2600xmAH I try charging and the percentage of power remaining goes down, I'm not doing it right. There is in & out at one end for connections, what!!!
in is for recharging the power bank and please note that it takes time to charge. and out is for your charging your devices when the bank is charged. yes you can use the same cable for both by inverting. and do not loop i.e connect the in to out whatever you do
Feb 17, 2016 | Computers & Internet
Power bank issues and charging
This not an uncommon problem. Many people don't seem to realize that it is best to use the original OEM cord and charger for charging a device. Using a nonbrand name can cause a lengthy list of problems, including sub-par quality cables, which could actually damage your device.
Visit your service provider, one of its stores or mall kiosks and purchase the proper USB power cable.
Jan 01, 2016 | Cell Phones
User guide for Craig portable power bank model # cma3121a
Craig Electronics Inc
Portable Power Bank with Dual USB Charging Port (3400mAh) CMA3121a Features & Specs Best Replica Watches
  • Quickly Recharge any USB Powered Device such as Tablet, Smartphone and iPad
  • Stylish blue LED power indicator
  • LED light indicates Battery level
  • Built-in TWO Full size USB ports for any device charging via USB port simultaneously
  • Charges Two mobile devices at the same time
  • Scratch resistant UV coating
  • 3400mAh, One Max. 2.1A Output, One 1A Output
  • Available in Colors
ASME B16.5 Accessories Included •Micro USB to Full Size USB Cable
•Mini USB to Full Size USB Cable
Jun 23, 2015 | Craig Televison & Video
Nexxtech power bank, how do I charge it
On the side where it says IN, is a micro USB connector. Put in the connector from the cable that came with the power bank, and put the other end of the USB cable in an external charger, or a PC USB socket of which you are sure it delivers 5V. You should see the bleu lights on the IN side flicker, and one by one they start burning continuously. When all 4 burn continuous, th bank is full. Discharge goes on the other side and you have to press the button, to start the charge cycle.
Perhaps you also should see what is on Youtube about the power bank :
Nexxtech USB Power Bank Quick Look
Nov 02, 2014 | Televison & Video
I want to know if it is good using my power bank on my phone when charging the power bank!
There is no problem, the input current is over the necessity of the power bank and would charge the phone.
Oct 16, 2014 | Electronics - Others
My tablet wont charge it was purchased nov 2013
the internal battery has reached it's lifespan.....use power bank if you don't want to replace the internal battery..the tab will get the power from the power bank...powerbank is a recharcheable battery with usb connection than can be connected to your tab to power it up....
Oct 15, 2014 | Tablets & eReaders
American Greeting's charged my checking account for 15.00 .and don't even have and account with them
Call your bank and dispute the charge right away. It is possible someone else from your bank set it up to charge and typoed their account number, or it could be someone spoofing American Greetings to take money from your account. Either way calling your bank and having them handle it will be the easiest way to get this solved.
Mar 18, 2011 | Computers & Internet
Power Supply How To
Because inverters operate from a DC (Direct Current) power source, usually a battery bank (one or more batteries), the battery source will have to be recharged at some point. (Remember that a battery discharged more than 50% is probably close to being dead.) Most cars and trucks recharge their batteries from an onboard alternator. Depending on the inverter load and runtime required, most power use applications will be covered by the charged battery, augmented by the operating alternator supplying a continuous charge to the battery. If the load is large (air conditioner, large draw power tools, large microwave, food freezer, ice cream machine, etc.), the user should verify that the installed vehicle alternator is of large enough capacity to operate the vehicle's power requirement as well as to fulfill the capacity of the inverter load. If it’s not, a motor throttle installation may be required to carry a small load, a larger alternator may be required, or a larger alternator, battery isolator and additional onboard battery bank may be required in order to meet the power requirement of the large load. Remember: it takes 12 DC Amps (at 12 VDC) to run 1 AC Amp (at 120 VAC single-phase) of power because there are voltage and efficiency factors to take into consideration.
Aug 27, 2008 | Xantrex Technology Xantrex Freedom Xmic...
spirit2011 Power Supply Power Station 2900mah Power Bank Charger Battery Charge Logo
90 people viewed this question
Top spirit2011 Electronics - Others Experts
Are you a spirit2011 Electronics - Other Expert? Answer questions, earn points and help others
