Astra 2.0 dti 2004 glow plug fuse location - Computers & Internet
    New Friend:
  • 21 Answers
Check with your local Opel/Vauxall dealer.
Posted on Jun 21, 2014
Where is the knock sensor on a Kia Sedona 2.9 diesel, 2004 LA
Here is the location of the "Knock Sensor" you requested, I hope it helps you. It is Number 17. for future reference here is the list of the others
1 = Camshaft position sensor (CMP)
2 = Crankshaft position sensor (CKP)
3 = Engine Control relay (EC) -engine bay fusebox/relay plate 1
4 = Engine Coolant temperature sensor (ECT)
5 = Exhaust gas recirculation valve actuator (EGR)
6 = Fuel Filter
7 = Fuel Filter Heater - in fuel filter housing
8 = Fuel Flow control valve - on high pressure fuel pump
9 = Fuel Rail pressure sensor(FRP)
10 = Fuel Temperature sensor - on high pressure fuel pump
11 = Glow Plugs
12 = Glow Plug Relay 1 - engine bay fuse box/relay plate 2
13 = Glow Plug relay 2 - engine bay fuse box/relay plate 2
14 = High Pressure fuel pump
15 = Injectors
16 = Intake air temperature sensor (IAT) - in MAF sensor
17 = Knock Sensor (KS)
18 = Mass Air Flow sensor (MAF)
Feb 04, 2015 | 2004 Kia Sedona
I drive a Jeep Cherokee 2.5 CRD 2004 model. I had a problem with the alternator and battery died,bought a new battery and put it in. When I try to start the car, the glow plug light does not come on and it...
Hello, please check all fuses first, if ok under hood I believe on pass front junction box locate the (IOD) fuse which will be labeled (IOD) on box cover and in owners manual fuse location and amp size. It may be a different color than all the other fuses. Pull the (IOD) fuse out and wait for a few minutes and reinstall. Try starting vehicle. Also when alternator problem addressed make sure main 40 to 80 amp max fuse is not blown out. Just to be on safe side recheck battery ground and other ground wires that may have been disturbed during repair. To check glow plugs if all else fails right rear top of engine is coolant temp sensor, disconnect sensor, this will cause ECU to think its cold and energize glow plugs, and allowing glow plug light to be illuminated.
Feb 21, 2018 | Jeep Cherokee Cars & Trucks
Engine code p0380
EOBD II Error Code: P0380
Fault Location:
Glow Plug/Heater Circuit Malfunction
Possible Cause:
1.No Pre-Glow Period.
2.Poor Cold Starting.
3.Wiring harness.
4. Glow plug relay.
6. Fuse.
7. Glow plugs.
8. Engine control module (ECM).
Possible Solutions:
Check Glow Plug Wiring.
Check Glow Plug(s).
Mar 19, 2013 | 2005 Toyota Yaris Verso
The power to the glow plugs on vauxhall astra diesel dti 2000 reg is constantly fashing when the engine is running, but goes off when the engi ne is stopped, and only the ignition is on.
yes common fault ,ignore it as its a problem with a earth point on the back of the speedo in some cases in others its the computer but the heaters are not coming on ,same as the opels i work on here except you have a grithin or however you spell it on the front badge
Mar 02, 2013 | Vauxhall Cars & Trucks
Location of fuse box 04 astra 4 door hatch
wheres fuse bow for washers on a astra hatchback 2004
Mar 17, 2012 | 2004 Holden Astra
No reversing liights onvauxhall astra estate 53plate 2004 1.7 dti have checked the following lamps all fuses switch what next?
check the adjustment of the switch to see if it lights the backup lights anywhere in the shift range (while car is not running, but ignition is on, on a level surface).
Jul 29, 2010 | GMC Savana Cars & Trucks
Heater plugs for nissan terrano 2
i have a nissan terrano 2.7 dti heater light not coming on some times dose and some times does'nt and it wont start
Oct 06, 2009 | 2002 Nissan Pathfinder
Hi got a 2000 astra 1.7 dti just recently it is difficult to start from cold but when started and warmed up starts first time any ideas cheers
Have the glow plugs checked.It could be they are not working.Or the glowplug relay has blown.Have them both checked.They are your problem.
Sep 16, 2009 | 2006 Isuzu I 290
Will a 2.5 td fit into my astravan 2004 1.7 tdi
Forget it to costly, a BMW is a in line 6, the Astra has aV 6 engine.
Aug 08, 2009 | 2003 BMW 325
I have a 1997 ford F350 WITH A 7.3L DIESEL, it turns over but will not start. My wail to start light or other indicator lights do not come on when I turn on the key.
The first thing to do is locate the owner manual.
Look for the glow plug relay MAIN FUSE location.
The glow plug portion of your van is not working.
This difficulty scale from 1 to 10 is a 9.
You will need a DVM and tool undo the cables to each glow plugs.
It's a 1 to 2 hours troubleshooting job.
I'm going to fire off a quick list
Check / replace blown glow plug relay main fuse
Disconnect each center nut of the glow plug wire. PLEASE CHECK ONE AT A TIME.
Read the resistance between the center of the glow plug and the metal base of the plug.
Please take good note on each glow plug resistance reading.
MAKE SURE all cables are put back and tighten properly.
Compare the resistance on all cylinders.
OPEN/high resistance is bad glow plug.
In general 3 ohm or less is OK.
You should buy one and use its value as baseline.
Glow plug relay can be bad.
You will need the VOM and a friend to turn the key.
Check the voltage to each glow plugs. It should be 12.6-13.6 volt.
Be careful,the plugs will get HOT.
Compare the voltage on each cylinders.
So the problem can be combination of
glow plug relay
glow plugs
ignition switch is unlikely but I'm going to list it anyway.
Once again,this is a difficult and time consuming job. I will ask a friend to help out,
Good luck.
Jul 23, 2009 | Ford F-350 Cars & Trucks
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
