Question about Dishwashers
Whirlpool gold gu2275xtvyo powder still left in dispenser
  • Dishwashers Master
  • 17,326 Answers
Look close at the holes in the spray bars. The can get food stuck in them. Check the sump for debris.
Posted on May 17, 2014
2 Suggested Answers
freetek
  • 5568 Answers
SOURCE: the powder dispenser on my ls 610a dishwasher
Try to make sure that the path for water isn't blocked to the dispenser. Ours will do that too if we forget to leave some space for the streaming water to hit the little tray.
Posted on Dec 23, 2009
Dishwasher gu2275xtvyo powder left in dispenser
detergents don't dissolve as well anymore because they no longer contain phosphate. It was outlawed recently. if you live in an area with hard water, it is especially noticable. This website explains it and sells an all-natrual product that contains no phosphate.
May 17, 2014 | Dishwashers
I do most of my shopping online and liquid bleach sometimes doesn't ship without breaking. Is it OK to use dry or powder bleach? I have the whirlpool cabrio top load large capacity model.
It should be okay to use dry bleach, if you follow the instructions on the bleach. Some bleaches require dissolving in water first, others can be used dry.
May 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My son has given me his Whirlpool washing machine but I can't figure out how to take out the soap powder dispensing drawer to clean it. Can you help?
hi.
pull out the drawer as far as you can.
in the centre you can see a plastic insert (usually a different colour to the main drawer)
you should be able to press this down and this releases the catch holding the drawer in.
it is the same sort of system you find holding a car ashtray in place if that is any help.
Apr 02, 2011 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
The powder will not dispense. Water is getting in because the powder is wet and clumpy but is still left in the dispenser.
I suggest you remove the soap dispenser drawer and thoroughly clean it, ensuring that the outlet at the back of the drawer where the water and soap feed into the machine are completely clear of any soap buildup.
Before you replace the drawer, ensure that the water feed into the drawer (this is a pipe or tube above the drawer slot) is not clogged with soap.
Feb 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
White powder residue left on dishes after washing. I run hot water before running dishwasher, use Cascade powder (fill dispenser less than 1/2 full per installer and do not use prewash detergent...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Nov 10, 2010 | Whirlpool DU805DWG Dishwasher
Put powder directly in the front load drum instead of the dispenser. What will happen?
not effectively. run the machine for a long cycle to clean any excess detergent out. the add normally through the dispenser
May 25, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Soap not disolving
is it liquid or powder? we had this problem with cascade powder.... tried liquid cascade and the same thing happened even though i'd been using cascade for YEARS.... manual said could be detergent was "old" and beyond its shelf-life, or that we used too much or too little (go figure that one out LOL).... not trying to promote a brand here, but we switched to palmolive ECO gel and haven't had a problem since -- no goop left in dispenser!.... hope that helps... -cynthia :)
Apr 17, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Soap not being used
We learned from our new Duet that when washing with Tide soap powder, there is an adjustment inside the pull out drawer where the soap powder goes. You will see a grey plastic slider that goes to the right for liquid soap & to the left for powder soap.
Moving this slider to the left corrected this problem - not using all of the soap powder needed - for us.
Good luck !
Marilyn in FL
Jan 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Front Loading Washer Does Not Dispense Softener
its not the sediment that is the problem the filter will do nothing for this problem.The best thing to do is to remove the drawer from the machine and clean the syphon on the softener compartment.It becomes blocked when excessive amounts of wash powder is being used.Alternatively the powder can be put straight into the drum.
Mar 16, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Dishwashers Logo
24 people viewed this question
Top Dishwashers Experts
