Question about LG DLE5977 Electric Dryer
New Drum Install - Rubbing
I had the common "cracked drum" problem. I ordered and received the new drum, and installed it. However, it is now rubbing heavily in the front. It is rubbing on the front white support plate, in one place on the drum only, on each revolution. It comes up off one of the the front rollers as it rotates. Seems like the new drum is out of round. Is there something I should check / adjust to verify it is round or properly supported? I'm also not sure how the felt seal is supposed to look. Should it fold down in the front, or lay out on top? Any assistance would be appreciated.
    Novelist:
    Champion:
  • 210 Answers
Ken, Don't know if this will be of any help or not, as I've never seen a dryer drum with the felt seal on the front. All of the machines I've repaired, (and that's a bunch), had the felt seal on the rear of the drum, with the front being supported by the configuration of the front panel where the door is located. Mostly the front of the drums were supported by small strips of teflon, or cork, as slides, but that's it. Never had one with felt in front. Is it possible the drum is in backwards?
Posted on May 17, 2014
rickzilla
  • 706 Answers
SOURCE: LG 2514W Rear Seal
Here is a link to the service manual ( think you already have this but if not.. here it is..
http://136.166.4.200/contents/Laundry/DLE2514/DLE2514_Service_Manual.pdf
and here is the disassembly link
http://136.166.4.200/contents/Laundry/DLE2514/DLE2514_Disassembly.pdf
As for gasket replacement, consider this.. If you are attempting this yourself.. order the correct gasket and gasket cement from an appliance dealer..I believe item #A460 and the part number for your model is 4986EL2004D so that is what you will need to order. Typically, you would just remove the drum from the chassis and glue the gasket in place after removing the original one. Just follow the disassembly intructions tyat I've attached as a link and then the drum comes out fairly simply.. If you have access to a digital camera, take a few before pictures of the drum, belt and pulley system so you can use them as backup in case you get confused.. It really isn't all that difficult. As alway.. make sure you UNPLUG it first... Good Luck..
Posted on Sep 19, 2008
stradeteox
  • 88 Answers
SOURCE: Loud Thump each time the Drum Rotates
A new drum and rollers should have solved this issue. The rollers were upgraded to have a harder rubber consistency about 1 year ago. Ensure that the technician did not use old stock parts. The new, updated rollers should have a blue dot on them. As for a cracked drum weld, this would be a defective part. Make sure to call LG customer service to have the issue documented so that there will be a history. This way, even when your unit goes out of warranty they will have records of the service and the repairs should still be covered for sometime.
Posted on Jan 07, 2009
  • 5 Answers
SOURCE: Drum noise
Ordered drum from Sears parts. 3045EL1002D
Cost of 85$ + 15 to ship. It came in 5 days.
Here is how to do it on a DLE2514W. Takes about an hour. I only used a phillips screw
driver. Take your time and look over the situation. I hope that I rememberd
everything. Good luck.
Dryer Drum Repair
Dryer Drum Repair
1. Remove L bracket with 6 screws at the top, rear.
2. Slide top back 2 inches to unlatch and remove.
3. Remove control panel with 2 screws at top, inside corners.
4. Carefully unplug 4 plugs from back of control panel.
5. Looking at inside at the top. Remove wiring bundle from 2 guides.
6. Unplug wire from dryer light.
7. Open dryer door and unscrew 2 screws behind door just below lint trap.
8. Remove 4 screws at top of front panel that holds the door.
9. Lift up front panel to remove. I couldn't get the door switch plug to disconnect
so I carefully rotated it an set it on top of the dryer.
10. Remove upper case bracket with 2 screws in front and 2 screws inside at top.
11. slide up a bit to unlock from sides. Watch routing of dryer switch wire bundle.
12. Remove lint trap duct with 2 machine screws. Carefully slide down to remove.
13. Remove front drum support with 4 screws attached to sides. Lift up to disengage
sides. Lift drum to free from rollers.
14. Observe how drive belt is routed around motor and tension roller. Push tension
roller up and release belt. Carefully take belt off and remove.
15. Almost done. Lift drum up at rear to free from rear rollers. Remove.
16. While your're there vacuume up dust and reverse procedure to install.
Posted on Apr 02, 2009
hunter19_46m
  • 7482 Answers
SOURCE: Model DLE2516W Dryer sounds like something is
UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
And also the noise could be the front seal is out of alignment or broken and this may cause the machine to be slower in tumbling.
If you have a front loading machine,
Remove the electrical box that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. Now you should be able to see the front seal and see if it is ok and now this will also expose the drum and belt Remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Posted on Oct 26, 2009
ftw1952
  • 10319 Answers
SOURCE: dryer making a thumping noise, heating okay, drum
the roller is out of round instead for the internal bearing has dried up and locked tight making the belt to burn the nylon roller flat in the spot the belt rides on. It will be neccessary to replace the belt and the roller as well
Posted on Feb 20, 2010
1997chevy cavalier drum brakes rubbing
yes it is dangerous but an easy fix. common mistake when doing drum brakes is an improper adjustment or faulty part the brake adjuster is installed incorrectly or the brake wheel cylinder is not releasing do both sides of the wheel cylinder press in if not replace check the E brake for proper adjustment as well as some have self tensioner and would need to be backed off for new shoes
Jun 03, 2013 | 1997 Chevrolet Cavalier
Replacing the drum
Did you replace the drum unit? If not order a new drum unit & install the drum and read the paper work with the new unit. There is most likely a life counter that needs to be reset. Good Luck
Oct 03, 2012 | Dell B1160
Remove rear brake drums
Light Duty Models
  1. Raise the vehicle so that the wheel to be worked on is clear of the floor and install jackstands under the vehicle.
  2. Remove the wheel. Remove the three retaining nuts and remove the brake drum. It may be necessary to back off the brake shoe adjustment in order to remove the brake drum. This is because the drum might be grooved or worn from being in service for an extended period of time.
  3. Before installing a new brake drum, be sure to remove any protective coating with brake cleaner or a suitable fast-drying degreaser.
  4. Install the brake drum in the reverse order of removal and adjust the brakes.
Heavy Duty
  1. Raise the vehicle and install jackstands.
  2. Remove the wheel. Loosen the rear brake shoe adjustment.
  3. Remove the rear axle retaining bolts and lockwashers, axle shaft, and gasket.
  4. Remove the wheel bearing locknut, lockwasher, and adjusting nut.
  5. Remove the hub and drum assembly from the axle.
  6. Remove the brake drum-to-hub retaining screws, bolts or bolts and nut. Remove the brake drum from the hub.
To install:
  1. Place the drum on the hub and attach it to the hub with the attaching nuts and bolts.
  2. Place the hub and drum assembly on the axle and start the adjusting nut.
  3. Adjust the wheel bearing nut and install the wheel bearing lockwasher and locknut.
  4. Install the axle shaft with a new gasket and install the axle retaining bolts and lockwashers.
  5. Install the wheel and adjust the brake shoes. Remove the jackstands and lower the vehicle.
// // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 32; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]> // // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 32; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]>
May 08, 2011 | 1991 Ford F250
WE HAVE HAD THE LG DLE2532W DRYER JUST OVER THREE YEARS. RECENTLY, WE HAD TO REPLACE THE DRUM BECAUSE IT HAD A CRACK IN IT. NOW THE REPLACEMNT DRUM (FOUR MONTHS OLD) HAS A CRACK IN IT AND THE DRYER IS NOT...
Here's one place you can order a new drum. However, if the drum has cracked twice in four months you need to find out if there's something else with the dryer that's making the drum crack. You also need to think if you're doing something like putting shoes in there or something that's stressful on the dryer.
Nov 01, 2009 | LG DLE2532W Electric Dryer
LG DLE2514w electric dryer has loud thud every turn
Most model dryers are supported at thge rear of the drum with a bearing configuration, but usually the front of the drum is supported by some lining pads or guides. These help hold the rotation of the drum concentric. It sounds like your drum is not spinning concentric. My guess would be that some new guides might need to be installed.
Hope this helps...
Sep 02, 2009 | LG DLE2514 Electric Dryer
Nov 23, 2008 | LG DLE5977 Electric Dryer
Maytag Neptune MDE9700AYW
We have the same machine. The drum also broke so we had it professionally installed. It wasn't done well enough and after the 90 day repair warranty, other problems developed. We still don't have a dryer and the next repair is $500 as other parts were damaged and we didn't catch it within the 90 days.
Bottom line: do have it professionally installed but be sure to ask about their work guarantee. As soon as you have any problem at all, call them back.
Jul 27, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Drum for Image Runner 2200
Hi Deborah.I can tell you. Open the front cover,drop/release the transfer unit located directly below the drum.To the right of the drum is the develpment unit. Use the handle on the dev unit to cam it away from the drum. Now there is a "thumb" screw on the front of the drum unit, its almost like the knob on a gumball machine as you are gripping a slotted "knob".turn it counterclockwise and remove it (you will use it to install the new drum).Now slide the drum unit straight out toward you, noticing the rail/track the old drum is riding on along the top edges.Then follow the instructions enclosed within the box for the new drum.I will attempt to describe it in case you have bought a 3rd party drum that may not have the instructions. Obviously remove all the packing materials mindful that the "greenish/gray" roller is the drum and is fragile and is sensitive to fingerprints and such. Use common sense as you remove the pressure release blocks at the front and rear of the drum, since they will seem difficult to remove but you can do it. :-) Install the drum in the reverse order followed to remove the old one.Once installed,you will need to enter "service mode". This is done in a 3 step process. Look at the operator control pad and to the right of the display you will see a button that says "additional functions". Press additional functions>>>next press the numbers 2 and 8 AT THE SAME TIME>>> next press the additional functions button again. If done properly a new screen will appear that will have "blocks".Press "Copier". Now a new screen appears with tabs at the top. One of the tabs says "FUNCTION". Press that tab. Once again a new menu, but this time the focus is on the new tabs in the main viewing area. Find "DPC" and press it.In the lower right corner of the display you will see "OK" .Press it and you will have successfully introduced the new drum to the copier (or visa/versa) and 1 sheet of paper will exit the copier.It may look nasty but that is normal. Congrats!!!!!! You are a drum professional !! I hope I helped walk you thru this adequetely and helped you. Take care and GFL :-)
Jan 08, 2008 | Canon (6981A002AA) for imagerunner 2200,...
LG DLE5977 Electric Dryer Logo
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
