Question about Dell OptiPlex GX150 PC Desktop
How do you set original boot configuration or can you make the desktop automatically do it?
  • ozzie distanisloa
    ozzie distanisloa May 17, 2014
    Hi ozzie distanisloa, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
  • ozzie distanisloa
    Its a dell 330 optiplex at 1st splash screen it blinks something about the boot up. It flashes so quick that I can't tell what it says. In msconfig there is no boot order at all. It is not recognizing any operating system, and also says partition not found!
  • Dell Master
  • 15,734 Answers
When you turn on the power, start pressing the F2 key. This should bring up the BIOS screen that will allow you to see what the settings are for the computer hardware. Make sure that you check the date and time because this is an indication that the battery in the computer is dead. If the date and time are correct, then look for the screen that shows the hard disk drives. If none is shown, then it be an indication that the hard drive has failed. IF the drive is shown, then you can look for the screen that shows the boot device order. Usually the CD drive is listed first and then the hard drive.
If you did not change the boot order or any of the settings in here before this happened AND the battery is not dead, THE HARD DRIVE has most likely failed.
Posted on May 17, 2014
Tip
How to configure Netgear WGT624 v3 router with Globe Broadband Huawei B200...
1. You have to reset your router to its original factory configuration by using the reset button at the back of the router (WGT624 v3) near the antenna. 2. Connect the cable from the Globe Broadband Huawei B200 modem to the wan port of the router. 3. Connect another cable (RJ45) from the router (any Lan port on the router) to the laptop or desktop. 4. Switch on both device (modem and router). 5. Wait till both device boot up and the modem flash a blue, green and yellow color on its led and solid green to all router indicator led except the test led indicator flashing for a few seconds only.
6. Open your browser (e.g. Mozilla Firefox, Safari...) 7. Type http://192.168.1.1 at the address bar. 8. Netgear setup website will open. 9. Go to advance settings. 10. Go to back up menu and click erase to reset your router to its original factory settings. 11. Logout. 12. Switch off the device (modem and router). 13. Remove the cable connecting the computer and the Lan port of the router. 14. Connect the modem directly to the laptop using the cable. 15. Open a browser. 16. Go to the netgear website. 17. Go to the Support menu on the Netgear Website. 18. Type the model of the modem (WGT624 v3) on the blank space provided (Find your product). 19. Go to Downloads. 20. Download WGT624v3 Firmware Version 2.0.26_1.01 NA. 21. Read the instruction how to download the firmware and how to upgrade your router to the new firmware. 22. Save the downloaded firmware. 23. Exit the Netgear Website. 24. Switch off the modem. 25. Now follow the instructions #2 to #8. 26. Go to "Upgrade the Router" menu. 27. Upload the downloaded firmware to the router. 28. After uploading the firmware go to the Basic Settings Menu or use the Smart Wizard Menu to configure your Router.(Important Updates: Lan IP Address will be changed automatically to 10.0.0.1). Automatic internet connections will be tested by the network. 29. Configure your wireless settings. Logout. 30. Reboot all the devices and the laptop/desktop. 31. Follow the sequence when rebooting. (modem-router-laptop/desktop). 32. Open a browser and browse any website. 33. Enjoy.
on Jul 12, 2010 | Computers & Internet
Overclocking in bios made desktop crash.
clear the bios - locate the little 3-pin jumper labeled with "CLR" or simmilar next to the bios chip/battery. short circuit the free pin with the one next to it (yiou will need to use the jumper that is on there). once you have kept it on for 10 seconds - put it back in to original position and configure your bios (time settings, boot device,...)
if you can't find the jumper or you think it's too complicated - unplug your pc from power and remove the bios battery. after 30 minutes install the battery as it was and configure your bios (time settings, boot device,...)
Mar 19, 2012 | Systemax Venture Computers & Internet
Computer fails to boot. searching for either hard
These pins are referred to as "jumpers". Each manufacturer can have their own jumper settings. Each device should have letters indicating which pins correspond to master, slave, or cable select. The best method to insure operation is to use the cable select (CS) jumper setting. Using this setting, the hardware will be automatically configured.
Mar 11, 2010 | Compaq Presario 5000 PC Desktop
T-2642 restore CDs not working
After you instll from norton ghost, when you reboot pc, press f8 go to safe mode, once in safe mode go to device manager, change display Adapter to std display, monitor to std monitor, ide drive to std ide controller,
Feb 07, 2010 | E-Machines T2642 PC Desktop
Tower wont boot only beeps. cant get picture on screen.
OK follow this steps Bro.
perhaps you forgot to boot first the hard disk.
Note this steps is only for phoenix BIOS hardware.
1. reboot your system unit by pressing the combination short-cut key (alt+ctrl+del).
2.press delete button to check your BIOS configurations while on reboort mode.
3.select BOOT from menu to set your hardware configuration.
4.select hard disk codename or serial name using the arrow-up or down button to high-light the selected hardware and press plus button to replace the high-ligh color=equivalent to ascend the specified high-light.
5.press F10 to save the configuration.
6.the system hardware automatically reboot you machine in order to save your system hardware configurations after pressing the F10 button.
7.your done.
I hope this one will help you and God bless.
Nov 20, 2009 | Computers & Internet
Can't bootup my EMachines T3882
if you can't get into the bios, you can't start a repair, when it's booting, continually press F2 to get the bios up, if that does nothing reboot an continualy press Del, this is for the bios menu and set the cd drive as first boot device.
If not continually press F8 on boot up this is safe mode, then when youre in highlight last known good configuration and press Enter.
Give this a try as your pc will not be set to boot from cdrom as default and will just try to boot into windows.
Aug 19, 2008 | E-Machines eMachines Desktop PC
I have sony vaio laptop with vista..recently an automatic uptade went on vista pack 1..now not able to start my laptop..
dowload vista recovery iso on a difrent machine burn to disk then boot viao with disk read option make a choice
Jul 30, 2008 | Sony Computers & Internet
Medion Compsoser 5200
Based on the information that you gave us...You can't access your BIOS for reconfiguration. To go to BIOS settings, try to press DEL or F2 button when you see the LOGO of the manufacturer.. Then change its Boot Sequence: 1st Boot - Optical Drive..2nd Boot- Floppy (if there's one) and 3rd Boot - Hard Drive. If your BIOS is protected then you need to shutdown your computer, 1. remove the powercable, 2. open your Desktop CPU, 3. look for the CR2032 Button battery, 4. locate the jumper near this Battery with CLEAR CMOS label. 5. change the setting of this jumper by removing the jumper and mount it on the other setting. Maintain for 5 seconds and then remove it back from its original setting.. Note: dont forget the original setting of this CLEAR CMOS jumper. Also never to POWER ON your Desktop while the jumper is at CLEAR CMOS setting. This will destroy your motherboard. 6. Connect the power cables and power ON your Desktop and you will encounter an error on BIOS setting. press DEL button or F2 to configure BIOS. 7. Then change BOOT SEQUENCE of your Desktop to boot to Optical Drive or CDROM first and then press F10 to Save and Exit. ..................... Check your keyboard if its working well otherwise get a GOOD Known keyboard or a new one.
Apr 09, 2007 | Medion M3 Composer 5200 PC Desktop
Dell OptiPlex GX150 PC Desktop Logo
23 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
