Question about Kenmore Elite Oasis 27052 Top Load Washer
Ld error - Kenmore Elite Oasis 27052 Top Load Washer
  • 3,230 Answers
Ld - Long drain - Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. Press STOP/CANCEL to clear the display.
Good Luck!!
Thanks
Posted on Aug 09, 2009
Again and again got a error of sc329 .......how to fix
this error code came from the LD unit which means the seconder LD is not synchronized on the machine but try to clean the mirror if it came agin the replace the LD board
Aug 14, 2015 | Gestetner DSm745 Black and White Copier
How do i clear code sc322 on nashua aficio 2016
Code SC322: Laser synchronization error
The main scan synchronization detector board cannot detect the laser synchronization signal for more than 5 consecutive 100 ms intervals.
Causes:
• Poor connection between the LD unit and the BICU board
• Damaged cable between BICU and LD unit
• LD unit out of position
• LD unit defective
• BICU board defective
Error Codes Ricoh Aficio 2016
Jan 04, 2015 | Office Equipment & Supplies
Sc 241 ricoh mp c300
LD error
LD error continues for 0.5 seconds. (After LD error is detected, a release of LD error is written to the GAVD circuit during monitoring.).
LD unit defective
Dec 03, 2013 | Ricoh Office Equipment & Supplies
Me aparece el codigo de herror sc241
Error de LD
Un error de LD continúa durante 0,5 segundos. (Después de detectarse un error de LD, se escribe una liberación de error de LD en el circuito GAVD durante la monitorización.).
• Unidad LD defectuosa
UNIDAD LD
Dos diodos láser en la unidad LD emiten 2 rayos láser de escaneo principal.
Contar con dos láseres acelera la creación de imágenes. También permite al
motor poligonal funcionar a menor velocidad, lo que reduce el ruido y prolonga la
vida del motor.
Aug 29, 2011 | Ricoh Aficio 1232C Color Copier
Error coad 322 is showing. what i do now?
ERROR 322 is Laser synchronization error
Detected LD error signal for
continuous 1.5 seconds while
polygon mirror motor was
running at constant speed.
Possible Cause • Synchronization detection mirror
defective
• LD unit defective
• FCU defective
• LD harness damaged
• THM not in place
Jan 08, 2010 | Ricoh Aficio 1013F Copier
Whirlpool Calypso: LD error message
hi replace the hall sensor... this will remove ur LD error code...
thank u
rate me!!
May 24, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Lanier 5245 it has an error code SC329-00,
Did this happen after the machine was serviced? this is typically when it would occur...."LD pitch error"
Perform LD pitch adjustment with SP109-3, and SP109-4 (400dpi & 600dpi) or the ribbon cable on LD unit is blocking proper movement of the unit.
Apr 18, 2009 | Office Equipment & Supplies
''LD'' error
“LD” stands for “long drain,” meaning it took an excessively long time for water to drain out of the washer. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I’ve even heard of bra wires coming loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Can you imagine? Yea verily, as surely as the Sacred Suds doth eternally pass my lips, the “LD” error code springs forth from such anomalies.
for more information follow the below link --
http://fixitnow.com/wp/2009/03/11/whirlpool-calypso-washer-full-of-suds-wont-drain-and-throwing-an-ld-error-code/
Mar 20, 2009 | Whirlpool WTW6600SW Top Load
HE error code on an LD-12AW2 dishwasher
also check the back of the pcb and see if the plastic case is melting.
Sep 21, 2007 | LG 24 in. LD-12BW5 Free-standing...
Kenmore Elite Oasis 27052 Top Load Washer Logo
233 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
