Question about Sewing Machines
I have a singer simple sewing machine 3210 and I tried to use it for the first time today. I threaded everything fine and started to sew and after 15-20 seconds it popped and sort of exploded. The stitching looks fine. I think this was the lightbulb? There are shattered bits of thin glass (may have been white but is black now). Is this normal? Why did it explode? Is it defective?
  • 55 Answers
Hi... well that is certainly not normal. However, does the machine still sew? If so, I would replace the broken bulb... if the bulb blows again... then you have a short-circuit on the power line to the bulb... look for abraded cable... or then take to a machine repairer.
Posted on May 17, 2014
3 Suggested Answers
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
  • 1788 Answers
SOURCE: Hi! I have a singer simple 3116 sewing machine
It is the top threading that is giving you the problem not the bobbin thread. Try this, totally rethread, the machine. A new needle will not hurt either. Now with the presser foot up, pull on the top thread, it should feed smoothly, now lower the presser foot, pull the thread again, it should barely move. This usually will seat the thread in the tension discs.
Good luck and Merry Christmas
Posted on Dec 24, 2010
Problem with singer 590c. Thread bunches up & breaks or the bobbin thread wont sew. 1 time happened to get everything right & it sewed beautifully.Today I cant get it to pick up the bobbin thread.
Make sure to use a brand new needle.
ALWAYS RAISE the presser foot when threading.
Unthread and re-thread from the beginning.
Verify the thread path is correct.
Set the upper tension to midway between High & Low numbers.
Verify the bobbin is loaded and threaded correctly in the bobbin case.
Begin sewing slowly and check the result. The upper tension can be tweaked so the upper & bobbin threads meet in the middle of the fabric.
If it is still not working properly, the machine may be out of time and require service.
Nov 20, 2016 | Singer Sewing Machines
My singer simple the needle hits the bobbin and my needle thread will not pick up my bobbin thread. what can I do?
change the needle to see if that will take care of the problem
if it doens't then the machine needs to be checked at a sewing machine shop about the timing
May 28, 2012 | Singer 3116 Simple
I think I have a Singer 5528. I hate it. Never could get it to work properly. I am not a person who knows how to sew. I need a simple machine that goes front and back and that is all. Now that I have this...
Sounds like it is not threaded right, I think you should invest in a new machine. They have them now, where automatically thread themselve. Go to JoAnn's and they will even give you a free lesson on how to operate it. And their prices are reasonable on Singers. Don't frustrate yourself, sewing is coming back and your old machine will be welcome at a community center or sell it in the newspaper. Treat yourself good, because you deserve it. Good luck
Oct 07, 2010 | Singer 3116 Simple
My Singer HD110 is sewing very slow> It just started doing this when I turned it on today. It was fine last week. HELP!
the machine may need oiling
check the bobbin area for lint or loose thread
your belt might be getting loose & need to be tighten up
Aug 22, 2010 | Singer HD-110 Mechanical Sewing Machine
Wads of Thread Caught in Singer Simple Sewing Machine
Sounds like you threaded it wrong and kept trying to sew, gently get all of your material out of the machine, DO NOT FORCE, GENTLY ROCK IT OUT OR YOU WILL WRECK THE MACHINE, also watch your dvd and learn about threading from your book. Always, hold your thread ends when you start to sew. If, you cannot find your manual go to www.singerco.com, I have sewn for 50+ years and found that the dvd was very helpful, each machine is different.
Jan 07, 2010 | Singer 3116 Simple
Singer simple sewing machine will not sew
Mar 15, 2009 | Singer 3116 Simple
Singer Simple bottom thread is loose
hi there
raise pressure foot up thread making sure thread passes between thread guide this should solve problem never alter bobbin tension,
mary h
Dec 29, 2008 | Singer 3116 Simple
Sewing machine either breaks thread or comes unthreaded every time i try to sew.
Your threading is not right, totally remove your thread and rethread according to the manual directions and dvd. If, you still have problems call Singer at 1-800-4singer
Sep 29, 2008 | Singer 3116 Simple
My singer athena 2000 won't pull the bottom thread up to form a stitch. I know this is an OLD machine and I couldn't find the right selection from the list My Singer Athena 2000 sewing machine was...
I think if you watch the hook as you turn the wheel you will see that it is not moving.If it's not moving it can't pick up the thread or sew or wind the bobbin. If you really like this machine you can take it to a technician who is going to tell you you have a broken gear.Always have them replaced in pairs. On this machine there are 2 gears( 1 Pair) on the left and 2 gears( 1 Pair) on the right. If the machine is making buzzing noises, replace the machine instead of the gears. Singer makes a nice machine which sells for around $300 which will do more than the one you have and it is easier to use. Look at Model 7467. I sell quite a few of these and they don't give me or my customers problems.
sewman7
Aug 28, 2008 | Sewing Machines
Raising the bobbin
Use a SA 156 metal bobbin (ebay, 20 of them for $8.99 free shipping) and make sure the bobbin thread is turning the right direction, read you manual or call singer at 1-800-4singer
Aug 23, 2008 | Singer 3116 Simple
Sewing Machines Logo
51 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
