Question about Broksonic CCVG4200 42 in. Plasma TV
Where is the cable coaxial - Broksonic CCVG4200 42 in. Plasma TV
  • Broksonic Master
  • 15,441 Answers
The coax cable connection is 1/2 inch screw type connection that sticks out from the back of the set. It has threads on it and has a little hole in the middle of it.
Posted on May 17, 2014
Are there coaxial cables on the ocean floor connecting the US and Europe?
There are transatlantic coaxial cables under the ocean much like the fiber optic cables that connect the world to the internet. The coaxial cables were first laid down in 1956.
Dec 23, 2013 | Electronics - Others
How do we connect our system using a Shaw PVR
Do you have a optical/coaxial input on your system? Eg: cable, TV.I use a optical input on my Yamaha ( cable, satellite ). Look to see if there is a optical/coaxial output on your pvr, there should be. Use ether the optical or coaxial output from your pvr and connect it to the cable (satellite ) optical/coaxial input on your receiver. The manual that came with your Shaw PVR should explain how. You will get 5.1 surround if available on certain channels.I prefer optical over coaxial myself, but they both work well.If you don't have optical/coaxial inputs on your receiver, you will have to use RCA cables, analogue out on cable box, to tape input or aux on your receiver. You will not get surround sound, just stereo. But it's better than nothing.
Jan 18, 2013 | Onkyo Ht-rc330 5.1-channel Home Theater...
Why does neither the co-axial cable from my DVR Cable box nor the one from my TV fit into the coaxial plug on the Magnavox ZV427MG9 DVD Recorder/VCR Combo ?
Check the coaxial cable connector type. There are two kinds--one that look like the RCA connector that you can just push in.
The other kind has a nut that you have tighten over the coaxial cable connector on the DVD recorder.
Dec 05, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
How to connect a philips antenna to a trutech tv
Unplug your television and turn the set around so the back of the set is facing you.
  • 2 Disconnect the antenna or cable connection from the television's "VHF," "Antenna In" or similarly worded port if it is connected.
  • 3 Examine your splitter and notice one end of the device has a coaxial port while the other end has two coaxial ports.
  • 4 Plug the coaxial end of the television antenna into one of the two coaxial ports on the splitter.
  • 5 Plug the coaxial cable coming from the cable television connection outlet into the second coaxial port on the splitter. Use the port next to the one you used to plug the television antenna into.
  • 6 Place one end of a 2 foot piece of coaxial cable into the single coaxial port on the splitter.
  • 7 Plug the other end of the 2 foot piece of coaxial cable into your television's "VHF," "Antenna In" or similarly worded port.
  • 8 Plug in the television set and turn it around so the screen is facing you.
  • 9 Use your television's remote control to access the "Menu," "Setup" or similarly worded function. Or press the "Menu" or "Setup" button on the front of the television.
  • 10 Select the "Channel Setup" or similarly worded function. Set the Input to "Cable" and perform an "Auto Scan" to locate all available cable television channels.
  • 11 Select the "Channel Setup" or similarly worded function, then set the input to "Antenna" and perform an "Auto Scan" to locate all available broadcast channels. Your television will locate both broadcast and cable television channels.
  • 12 Scan the channels on your television to make sure all available channels have been found. If you are missing any channels that you know you should have, manually program the channels into your television using the "Channel Setup," "Manual Channel Setup" or similarly worded function.
  • Oct 17, 2011 | Televison & Video
    No coaxial connection
    check if the LOCAL cable box has RCA out put, if not get this and hook up from the coaxial wire
    http://www.radioshack.com/product/index.jsp?productId=2486501&CAWELAID=107592963
    fosg2000
    Feb 26, 2010 | Akai PDP4225M 42 in. Plasma Television
    Can i connect my audio and video cable to a coaxial cable? so one side is coaxial cable and the other is audio and video cable one for the the wall and the other audio and video for the tv, this is beause...
    U have HDMI ports,order HD from the cable or telicom compannies.Use a HDMI cable for the tv,also get HD channels.Do not have HDMI ports than ur Main signal board must replaced the Antena analog coaxial it broken.Well not able to buy the coaxial input for the antena along for part.
    Jan 10, 2010 | RCA HD52W58 52" TV
    On the digital input 1 have the coaxial cable hooked up to blu-ray player but i have no sound, but if i hook up optical i do have sound.. wrong coaxial cable
    Possibly a bad cable, but not likely its a 'wrong' one. Any RCA-style cable will do for SPDIF coaxial digital signals. Try another one. Are there other Digital Coaxial inputs you could try to prove the function?
    You may have to configure your Digital Inputs so the receiver knows Digital Input 1 is Coaxial.
    Nov 19, 2009 | Technics SA-DX950 Receiver
    My phone line comes through a cable modem. how do i connect
    well no promises but this may work
    items you will need
    2 coaxial cables
    3 way coaxial splitter
    1 old phone cable you can sacrifice
    soldering iron (optional)
    solder (optional)
    steps,
    take a coaxial cable and cut on of the ends off, throw the severed end away and strip the insulation of the coaxial cable (only strip about 3 inches of it away.
    seperate the coper (or sliver wire) from the wire center wire and twist toeghter to make a neat wire
    strip some of the insulation away from the white center post revealing the coper wire inside
    cut end off phone cable and take about 4 inched of insulation away
    5
    connect the green wire of the phone cable to the copper outter most wire of the coaxial cable and tape it so that there isnt any of the outer most wire showing
    6
    connect the white wire to the center wire of the coaxial cable and tape so that there isnt any wire showing
    7
    connect the coaxial/phone cable you just made to the 3 way splitter
    8
    connect the coaxial line that comes from your house to the splitter
    9
    connect the other coaxail cable to the last available port on the splitter
    10
    connect the non-modified coxial line to your modem/router
    11
    connect the phone cable to the fax
    this might work, no promises, i havent tried it, but it might work and is worth a try
    Jun 14, 2009 | Brother MFC-5460CN All-In-One InkJet...
    CANNOT FIND CABLE CONNECTION FOR AKAI TV LCT42V6TN
    They don't make a coaxial to RGB or Component adapter. I know they make a coaxial to RCA. If you go that route you would just connect the coaxial to the video. Now if you do this not sure as to what would happen with sound, if you would have it or not. It is possible but not sure. The adapter I am talking about is called a
    UHF Female to RCA Male Coaxial Adapter. Which can be found at most Radio Shacks. If this doesn't work I would contact the cable company about a cable box that they could then run the coaxial to and then the RGB or Component cables to the TV.
    Hope this helps.
    Mar 01, 2009 | PC Connection RG6 Bulk Coax Cable, Plenum...
    Locating a coaxial cable to replace factory supplied cable
    Radio shack should have what you need. RG6 is better than RG59 if you have a choice.
    Jul 28, 2008 | RCA DRC8335
    Broksonic CCVG4200 42 in. Plasma TV Logo
    26 people viewed this question
    Top Broksonic Televison & Video Experts
    Computer Repairing
    Computer Repairing
    Are you a Broksonic Televison and Video Expert? Answer questions, earn points and help others
