Hotpoint aquarius washing machine
Showing error F5
    New Friend:
  • 85 Answers
Go to this web site and download the manual of your model
http://www.hotpointservice.co.uk/category/laundry/
Posted on May 17, 2014
SOURCE: HOW CAN I GET MY HOTPOINT AQUARIUS 1400 - OFF CONSTANT TEST PROGRAM?
This works
To exit the TEST mode, press and hold down the "Start/Cancel" button until ALL of the console lights light up. Press both "Start/Cancel" and On/Off buttons simultaneously until " dOFF " appears in the display. The default setting will now appear and the machine can be used normally.
Posted on Feb 07, 2008
localwonder
  • 6784 Answers
SOURCE: lights flashing / flickering on face on controls-machine not work
This is normally a signal that is for a control fault. you will need to pull the power and shut this unit down for 5 minute.. if the unit continues to flash after this reset, you will need to replace the control board/timer in this case. it has failed.
Posted on May 22, 2009
barkencoa
  • 3463 Answers
SOURCE: Noisy spin on hotpoint aquarius WF530 6kg washing machine. Suspect bearing how do I replace them.
If you spin the drum by hand, and it is niosy and rumbling then the main drum bearings have failed.
If under 5 years old, then you should be able to get it repaired under Hotpoint 5 year guarantee, You just pay for labour and call out, cheapest option, it is not really a D.I.Y job, as it is quite involved, and entails a lot of work.
Please rate my advice.
Thanks.
Posted on May 27, 2009
SOURCE: How do I change the door boot seal on a Hotpoint Aquarius WMA31N?
Ok - I will answer my own problem seeing as though I have now fitted it!
1. remove door (2 screws)
2. There is a tensioned wire loop holding the front part of the boot seal in position. - prize off the plastic cap at the 11 o'clock position, all will become clear and you will be able to remove the wire loop.
3. Remove top of washing machine (2 allen screws behind caps at the front.
4. Remove soap dispenser draw and any screws holding the front control panel and top of the door.
5. Remove bottom front plinth (just pull it off) underneath are a couple of screws holding the front panel part of the machine, remove these.
6. Remove front of machine giving you access to the steel band which locks the other end of the boot seal in position. Slacken this band right back using a nut-spinner screwdriver. Pull off the old boot and clean the lip ready for fitting of the new boot.
7. Fit new boot seal using a squirt of washing up liquid as lubricant if needed (mine didn't) to reseat the seal.
8. Refit and tension steel band.
9. Re-assemble front panel, ease boot back into front lip position then refit wire loop using a suitable pair of pliers/molegrips to crimp the retaining plastic cap back in situ.
Posted on Nov 02, 2009
barkencoa
  • 3463 Answers
SOURCE: hotpoint aquarius wmf 740 has error code f5 - what does it mean?
I think you mean F05, in which case it means that the pressure switch is jammed on full.
You need to remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well, and look inside the pump.
This should solve your problem.
Posted on Nov 28, 2009
Why is my washing machine flashing f5
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
F05 - Pressure switch jammed on full
All error codes at above link...
May 12, 2011 | Hotpoint Aquarius WD640 Front Load...
Disply screen flashes F-05
I have a hotpoint waschmachine wt640 since lastweek I have an error on the control panel F5 andnow it changes to F11 .The machine is just working for a few minutesand stop showing the error message F11 . please help
Feb 28, 2011 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius stopped working full of washing F5 showing on screen
hi im pretty sure f5 is pump blockage try filter on the front bottom right hand corner behind the kick plate if its not blocked it could be the level switch this is located under the lid its a round switch with a plastic tube going into it this could be faulty thankyou
Jan 18, 2011 | Hotpoint Aquarius WF000 Front Load Washer
I have a hotpoint aquarius wmf740 that is showing a fault f--5 and wont empty out the water
Something wrong the pump would prevent the machine draining and generate an F5 code.
http://appliancejunk.com/ge/washer/31-9103.pdf
Service manual above.
Jun 25, 2010 | Washing Machines
While on a cotton wash machine continues until the rinse cycle stops and shows f5 machine blocked.
You need to clean the filter.
Remove lower rear panel of washer/
Locate and remove large black hose on bottom of drum.
Rempve hose onto pump, and check for blockage and or obstruction here as well.
This should solve the problem.
Please leave feed back for my solution.
Thankyou.
Jan 11, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius wash system plus ultima 1200 wm72
it's a motor problem. could be as simple as the brushes or could be the circuit board at fault.
Jan 17, 2009 | Hotpoint Ultima WD72 Front Load...
AQUARIUS HOTPOINT WD440
How many times does it flash.
it still sounds like you have an obstruction in something.
May 09, 2008 | Hotpoint Aquarius WD640 Front Load...
Washing machine error 14
check for blocked sump hose filter, this should resolve problem
Oct 15, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
