Question about Health & Beauty
How rare is a 3.7ml. bottle of Chloe Narcisse perfume?
  • 85 Answers
Unfortunately it's not so rare . It was made in 1992 although it's discontinued but still available for about $35 .Check this link .
http://www.ebay.com/itm/Chloe-Narcisse-PURE-PARFUM-RARE-MINI-Perfume-12-Fl-Oz-3-7-ml-NWOB-/321208079666?pt=fragrance&hash=item4ac97e5532
Posted on May 17, 2014
Tip
Tip on keeping the perfume fresh
Speaking of heat, if you want to keep that favorite perfume as fresh as the day you bought it, keep the bottle in a cool, dark place. Keep the bottle in it's original box, if possible. You may even want to keep it in the fridge, so you can have a refreshingly cool spritz of your perfume before heading out for the day!<br /><br />
on Nov 23, 2010 | Health & Beauty
Trying to find touche perfume with a slash above the e please HELP ME haha
I just got a bottle for from a friend, its only been used a couple times the bottle is practically full, it has the accent over the e, with the cap the goes closes around the neck of spray nozzle
Nov 17, 2015 | Health & Beauty
Did Avon make a perfume called white diamond
White Diamonds By Elizabeth Taylor, Not Avon
Oct 14, 2014 | Toys
Betsey johnson perfume spray broke
1. Look at the tip of the nozzle to ensure that it is still intact. If there seems to be a perfume buildup within the tip, simply run the tip under hot water and use a pin to pry any gunk loose. Press the nozzle tip gently down on the top of the perfume bottle to reattach.
2. Remove the tip of the nozzle if it will not spray and soak a cotton ball with rubbing alcohol. Apply the alcohol to the interior top of the plastic tube and let it sit for 10 to 15 seconds. Use a pin to slide down the center of the tube to remove any built-up gunk that may exist in the tube. This tube is what feeds the perfume from the bottle, to the tip.
3. Use tweezers to pull the plastic tube upward if it will not connect to the nozzle of the tip properly. The tip should snap onto the plastic tube; however, if it does not then the tube is too low in the bottle.
4. Return to the store, where you bought the perfume, and request a new replacement tip. Craft stores may also carry the replacement tips. The sprayer inside the tip may be off or uneven which will cause the perfume not to spray.
5. Exchange the perfume for a new bottle at the store. Manufacturers, especially if it is a new bottle, will replace the bottle at no charge. Depending on the store, you may be able to exchange the bottle even if it is almost empty.
6. Pry out the inner workings of the perfume bottle and dab the perfume on your skin, instead of spraying.Take the insides of the nozzle out by removing the tip, and use tweezers to remove the inner tube. Around the edge of the perfume bottle is a plastic encasement that will need to come off. Use a pocket or paring knife to loosen the edges around the encasement and pop it off. Under the encasement will be a metal ring that attaches the encasement to the bottle. Using the same method as the encasement, pry the metal ring off the bottle. Purchase a small cork to insert in the bottle to prevent a spill.
Aug 05, 2012 | Betsey Johnson 3.4oz Eau De Perfume Spray...
I bought a 60g/90ml JONTUE perfumed body spray last week and everytime i use it the perfume comes out from the front and the back of the nozzle. this caused perfume to drip. thank you natasha 072 080...
This is a common issue with spray types of perfume and cologne. It is very easy for the head to break.
The best thing you can do is to try and find another spray bottle of some sort and use its spraying device in place of the existing one. If that isn't an option, you could always exchange it for a new one if it is mostly unused. Most retail stores will replace it, just tell them it came like that.
If all else fails you always have the option of permanently removing the spraying device, turning your bottle into a pour style of perfume bottle. Then just wrap some plastic over the top to keep it sealed.
I hope this helps!
May 16, 2011 | Revlon Health & Beauty
There is no perfume coming out from the atomizer
Make sure your that part of your atomizer that is inside the bottle is not broken. You can open the bottle and try it with water if it works. Other problem could be the nozzle. If it's not working you have to go to the store where they sell this fragrance and ask for a new atomizer( no charge) or exchange if your bottle is still full.
Nov 28, 2010 | Britney Spears Beauty Curious Britany...
Which is the world's most expensive men's perfume?
The worlds most expensive Men's perfume is made by Clive Christensen and it comes in a Crystal Baccarat bottle with a 5 carat diamond around the upper portion of the bottle, that retails for $250,000 it comes in both Mens and Womens versions. If you want it in a 1.5oz crystal bottle it will cost you only 2,500.00, or if you want it in a glass gold painted bottle it will cost you around only $750
How long can I keep my perfume before it “turns”?
Some industry experts say that perfume should be replaced every year, but properly stored, perfumes should last much longer. Most perfumes will keep several years, some will keep many more years than that.
To store perfume properly, keep it away from heat and light. A dark closet or a covered box is best. Also avoid direct exposure to air. Splash bottles, which expose the fragrance to air every time they are opened, are problematic. Consider decanting into a smaller atomizer for regular use. If you apply perfume directly from a bottle stopper, wipe the stopper with a clean, lint free cloth before replacing it in the bottle.
Health & Beauty Logo
222 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
