Question about Electrolux Vacuums
Remove handle from hose electrolux
Electolux renaissance- take apart handle to attach othe impiments
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 72 Answers
You don't have to "remove" the handle from the hose to attach other attachments, just depress the tab at the end of the hose and pull the upper wand loose then use the "adapter" to use the dusting brush or simply snap the crevice tool in place to use. If the handle won't come loose from the upper wand, then the described "tab" needs replaced as it's locking up the parts. Hope that helps!
Posted on Nov 24, 2014
4 Suggested Answers
  • 15 Answers
SOURCE: RENAISSANCE HOSE/VAC
THE RENAISSANCE IS KNOWN FOR HAVING PROBLEMS WITH THE CIRCUIT BOARD IN THE HANDLE.YOU'LL NOTICE THAT MODELS THAT CAME AFTER THAT HAD SLIDING SWITCHES. UNFORTUNATELY THE NEW HOSE DESIGN WON'T WORK ON YOUR MACHINE BECAUSE THE CIRCUIT BOARD INSIDE THE MACHINE WAS CHANGED TOO.AERUS MAY OR MAY NOT STILL MAKE THE PARTS YOU NEED. OTHER WISE LOOK ON E-BAY FOR A NEW HOSE.
ELECTROLUX FOOLISHLY REPLACED IT'S FLAGSHIP STEEL MACHINE WITH THIS DESIGN...A FEW YEARS LATER ALL THEY HAD WORTH SELLING WAS THEIR NAME, HENCE THE NEW NAME AERUS.
Posted on Apr 10, 2008
SOURCE: Electrolux Renaissance Hose Replacement
Notice how the hose has a groove just around the outer edge of the gray plastic near the white plastic insert. The hose is held into the handle buy two "tongues" inserted into this groove. One of these tongues is on the end of the top plastic piece of the handle. The second is on the piece of plastic that is slid into the little hole at the base of the handle and it is visible in the picture.
To remove the first, you'll have to remove the two screws in the top of the handle that hold the top plastic piece. This can be a challenge unless you have the right tool. It's essentially a hex-star allen wrench tool that is required, I'm guessing about 1/16 inch. I had one in my tool box that fit. Remove the screws and pop the top plate off. This frees the first tongue from the groove. Now, just get a screw driver (or use your finger) to press the plastic piece inserted in the hole at the bottom of the handle. Press from the "t" side and this should slide right out. Now your hose will slide right out of the handle and you can replace the old with new. Re-insert the small plastic insert, and refasten the top plastic piece of the handle and you're good to go.
-DB
Posted on Aug 04, 2009
BElectric
  • 1140 Answers
SOURCE: What exactly is the name of the tool to remove the
It's not a particular tool, it's simply a type of screwdriver bit. They are called either "Torx" or T-Star and come in a range of sizes, e.g. T15, T20, T25, T30, etc.
I think the one on your vacuum is a T20, but it's hard to remember the size of every screw on every appliance. I've attached a picture below to assist you. If this isn't the right tool, please describe the shape of the recess in the head of the screw and I will post back with the correct answer.
Regards,
BElectric
Posted on Nov 11, 2010
Testimonial: "Was very helpful, pointed me in the right direction & it worked. Thanks."
I have a renaissance cansiter vacuum. When I plug in the canis ter no hose attached, it does not come on like it shouldn't , however when I attached the hose and wand I turn it on it will start to ru
It is running properly if you are doing what you say you are.
It should NOT run without the hose and should with it plugged in if the electronics in the hose and vac are working properly. This was the major problem with the Renaissance Model and was only manufactured for a few years.
With 30 yrs. experience dealing almost exclusively with the original Electrolux, I have a legitimate store front business and do service by mail at a reasonable cost if interested. mickeymackmark1@yahoo.com
Hope that helps! Mick
Dec 07, 2014 | Electrolux Vacuums
Electrolux Vacuum Renaissance Power head brush won't turn
if it is making a humming sound but not turning you belt is broken, if it is not check the reset switch (little res button) if that doesnt work check the connections between the cord of the powerhead and the wand, the wand and the hose, and the hose and the vacuum
give the hose itself a good look over sometimes the wires up by the grip break in the casing
Mar 12, 2014 | Electrolux Vacuums
Renaissance manual
disconnect the power from the unit, then remove two screw in the handle and pull the handle apart and this will expose the wires.
Jul 19, 2013 | Electrolux Vacuums
LUX RENAISSANCE WONT TURN ON. HOSE CONTROL BAG LIGHT IS ON
Could be the board in the handle but I found that a lot of the times the contacts where the handle meets the hose just need to be cleaned. It could also be a clogged hose but I'd say it's one of the other two.
Dec 04, 2009 | Electrolux Vacuums
Electrolux Epic 6500/ handle clip broke....
The clip can be replaced by taking apart the handle. Small round plastic inserts cover up the screws that hold the handle together. Use a very small screwdriver to pry them off, then use a small screwdriver to remove the screws(Some of the screws may be star screws requiring a special screwdriver. The top part of the handle will then lift off and you will be able to change out the clip. Before reasembling the handle, clean the contacts which attach to the hose and be careful that you do not bend the contacts. It is kind of tricky to put back together.
Good Luck
Captaintek
Mar 26, 2009 | Electrolux Epic 6500 Vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=576614
Generic problem for all Vacuums
Electrolux renaissance
Posted by maryannn2l on May 06, 2008
No power when I plug into outlet
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You may have 3 problems that I can see. You may have a bad electrical outlet, but I doubt it, the bad cordwinder cord or a short in the cordwinder itself, or a connection came loose in the motor section. If you need further assistance then contact your local vacuum cleaner dealer in your area or contact the Electrolux factory listed below. . So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 06, 2008 | Vacuums
-DB
Dec 04, 2007 | Vacuums
Electrolux renaissance power hose
If the wires power a motor then it shouldn't actually matter as the motor is AC which has no polarity.
Oct 07, 2007 | Electrolux Lux 7000 Bagged Canister Vacuum
Vacuums Logo
197 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
