Question about Konica Minolta Magicolor 2530 DL Laser Printer
Remove 2530dl fuser - Konica Minolta Magicolor 2530 DL Laser Printer
  • Konica Minolta Master
  • 6,680 Answers
3 Suggested Answers
  • 118 Answers
SOURCE: Instructions for Fuser Unit Change - Konica 2530DL
Send me you email at dhudson at Gmail dot com, and I will reply with the manual attached. It is a very involved process, that, having done it, would not ever want to do again.
Posted on Apr 20, 2009
  • 1218 Answers
SOURCE: My Konica Minolta 2530DL printer has paper jam ,as
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Posted on Nov 12, 2010
Remove fuser
These model you replace the fusing unit you don't get small parts for the fuser for these small machines.
Sep 04, 2014 | Konica Minolta magicolor 2530DL
Paper jam at fuser
Buy a new fusing unit can't get small parts for the fusing un it for these models
My 2530dl prints blank pages then gives a media jam fuser error
I literally just fixed the same problem in my 2530DL.
Look at section 6.3.23 in this service manual for a nearly identical model http://printer.konicaminolta.com/drivers/other/Manuals/24_25/fs_2400s.pdf and notice the "Precaution for Reinstallation"
This Registration Roller Solenoid is an electromagnet-activated lever which controls the timing of the page's movement through the printer.
The manual notes that the space between the "flapper" and gear is critical for proper timing. In my case, the tiny foam pad at the bottom end of the flapper had apparently become compressed over time, resulting in the spacing going out of tolerance.
I removed the foam pad and replaced it with layers of electrical tape, adding layers until I found the thickness needed to make the printer work correctly (6 to 8 layers). Then I removed the tape and glued in a piece of hard rubber of the same thickness. (Tape is only a temporary measure as it can compress or become sticky after a while.) Everything is back to normal now!
Sep 23, 2012 | Konica Minolta Magicolor 2530 DL Laser...
My Konica Minolta 2530DL printer has paper jam ,as i tried to remove paper a part of it tornoaway and got stucked in the fuser roller arear. How can i remove the fuser to get the piece of paper out
Nov 12, 2010 | Konica Minolta Magicolor 2530 DL Laser...
I have a Konica Minolta 2530DL printer. I have
the reset is done via a 'first use fuse' in the drum unit.
check the contacts or put in a new one.
Oct 21, 2009 | Konica Minolta Magicolor 2530 DL Laser...
Since replacing the fusing unit on my Magicolor 2530DL, I am getting very light prints. Can you give me some ideas about how to resolve this?
faint prints wont be from the fuser. if u can physically rub the image off the paper with your hand then your fuser is faulty. check condition of the drum unit. if a new drum doesnt fix this then u have a dirty laser which will need a tech to clean.
Jul 16, 2009 | Office Equipment & Supplies
I've replaced all neccesary ink colors and now my 2530DL Konica Minolta wants me to replace my Drum Cartridge... I don't know what that is or how to do it!
Open the Front Cover and remove the OPC drum cartridge by pulling up from the green lever. I'm sure you'll find all these instructions on the box the new drum is comming.
May 14, 2009 | Konica Minolta Magicolor 2530 DL Laser...
Apr 17, 2009 | Konica Minolta Magicolor 2530 DL Laser...
Trying to get magicolor 2530DL printer connected & printing
http://onyxftp.mykonicaminolta.com/download/SearchResults.aspx?productid=965&filetypeid=0&osid=18 Try this website and let me know how things go. all you need is a new driver as for the old one might be corrupt. Good Luck
Fehdi
Apr 14, 2009 | Computers & Internet
Konica Minolta Magicolor 2530 DL Laser Printer Logo
87 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
