Question about National Detroit Air Tools & Compressors
How do I get the shoe off of my air file to change the bottom bearing
The file is an f8-24101
2005 Yamaha Big Bear 400. How do I replace rear brakes?
Removing The Rear Brake Drum & Shoes on Grizzly 600 ...
? 5:04
www.youtube.com/watch?v=n5oO7v3nT6s
Mar 11, 2012 - Uploaded by myquadrepair
Removing the rear brake drum & shoes on Yamaha grizzly 600. ... Yamaha Big Bear Oil Change and More! - Duration: 10:43. by jfrost77hd ...
HONDA FOREMAN REAR BRAKE CHANGE PART 1 ...
? 11:49
https://www.youtube.com/watch?v=xQanZdlDCI0
Jul 17, 2012 - Uploaded by 400EX99N
HOW TO CHANGE REAR BRAKES ON A HONDA ATV. ... is this about the same for a 2004 yamaha big bear 400? Read more Show less.
Nov 03, 2015 | ATVs
Change cam bearings 1450 flhx
No, but if your cam shoes have never been replaced, have them checked. In some bikes they go as early as 30,000 miles. I just replaced the shoes in my Fatboy at 32,000. If you do replace the cam shoes or do any other work in the cam cavity, change the stock cam bearings for the Screamin' Eagle bearings. Better bearings and cheap insurance, but there is no need to change them unless you're in there for something else, unless the bearings went bad for some reason.
Sep 09, 2012 | 2006 Harley Davidson FLHX Street Glide
Need illustration for rear drum brakes
Long shoe in the back,ilIllustration is at the bottom of the page for some reason,scroll down!
Click on a part in the image to check price & availability at your local store.print_icon.gifPRINT DIAGRAM1.imageVIEW SOLUTIONS TO COMMON PROBLEMSpartstab.gif
listarrow_icon.gifBrake Shoeslistarrow_icon.gifBrake Drumlistarrow_icon.gifWheel Cylinderlistarrow_icon.gifBrake Lines and Hoseslistarrow_icon.gifBrake Hardwarelistarrow_icon.gifBearings & Sealslistarrow_icon.gifThe Parking Brakelistarrow_icon.gifFlushing the Systemsolutiontab.gif
Select a part to view solution for common problems associated with the item.Operation: Brake shoes provide the friction material that when forced against the friction surface of the drum stops the vehicle. Advice: Check the old brake shoes for uneven wear. Uneven wear from one side of the shoe to the other is an indication of loose or worn brake hardware. Uneven wear from the top of the shoe to the bottom is indication that the shoe is not contacting the drum correctly, usually due to a drum that is beyond wear specifications. Recommendations: Brake hardwareOperation: The brake drum provides the rotating friction surface for the brake shoes to interact with in stopping the vehicle. Advice: Check the friction surface for uneven wear, grooves or small stress cracks caused by excess heat. Uneven wear is an indication of lose or worn brake hardware. Grooves in the friction surface are an indication of brake shoes that have worn down to the metal rivets or brake shoe framework, or of debris lodged between the brake shoe and drum, possibly broken brake hardware. As long as the damage is not too severe, uneven wear can be corrected by resurfacing the drum. Check to make sure that the drum is within specifications before and after the resurfacing. A drum with heat stress cracks should be replaced. Recommendations: Resurface or replace the brake drums.Operation: The wheel cylinder converts the hydraulic pressure sent from the master cylinder into the mechanical force that pushes the brake shoes into contact with the brake drum to stop the vehicle. Advice: Check for moisture anywhere around the wheel cylinder. Moisture is an indication of a leaking wheel cylinder. A leaking wheel cylinder should be either rebuilt or replaced. If a wheel cylinder is allowed to leak brake fluid onto the new shoes, it will ruin the new shoes causing the brakes to grab and emit a growling or rumbling noise when applied. Recommendations: Rebuild or replace leaking wheel cylinders.Operation: The brake lines act as a conduit for the brake fluid, supplying each wheel with the hydraulic action necessary for brake operation. The system is made up predominantly with metal brake lines. Flexible hoses are used at the wheels to accomadate the movement of suspension and steering. Advice: Check metal brake lines for signs of corrosion, physical damage or leakage. Check flexible brake hoses for splits, cracking or signs of leakage. The brake lines are connected to the various brake components with hollow fittings called flare nuts or line fittings. Because flare nuts are hollow they are susceptible to damage if a normal open ended wrench is used to remove them. Flare nut wrenches, sometimes called line wrenches are special open ended wrenches designed to slide over the brake line and still provide maximum grip on all sides of the fitting. Apply a generous spray of penetrating oil to the threads of the fittings and allow it to soak in before loosening the fittings. Recommendations: Flare Nut Wrench set Penetrating sprayOperation: Brake hardware is a term used for all of the springs, clips, guide pins and other misc. pieces that hold the brake pads and calipers in place and guide their movement during brake application. Advice: Check for corroded, bent, worn out or broken springs, guide pins or clips. Damaged or worn out brake hardware can cause uneven wear on the new brake pads. To ensure the best results from your brake job, the brake hardware should be replaced with the new brake pads. Recommendations: Replace Brake hardwareOperation: The wheel bearings support the weight of the vehicle and allow the wheels to spin freely. Advice: All wheels will have some sort of bearing and a seal to hold in lubricant and keep out dirt. Some bearings are sealed in a hub assembly or pressed into an axle housing and can only be serviced by replacing them. Others such as tapered roller bearings can be cleaned inspected and repacked with grease. Use a can of spray brake cleaner to remove the old grease. Check the integrity of the cage holding the rollers in place. A loose wobbly cage is an indication of wear. Check the rollers for discoloration. Discoloration is an indication that the bearing has been subjected to excess heat and should be replaced. Always install a new race when replacing a bearing. Always install a new seal whenever servicing or replacing a bearing. Recommendations: Spray Brake cleaner Wheel bearing grease Wheel sealOperation: The parking brake on a drum brake system has a series of cables that when actuated from the driver's compartment moves the parking brake levers on both rear wheels, forcing the rear brake shoes against the friction surface of the drums to hold the vehicle in place. Advice: With the parking brake disengaged and the drum removed, check to ensure that the brake shoes are fully seated at the top and bottom anchors. If not the parking brake cable may be sticking internally and holding the brake shoes partially applied. A sticking parking brake cable should be replaced. Never adjust the parking brake cable until after normal brake shoe adjustment has been made. After normal brake shoe adjustment if the parking brake still does not hold the vehicle stationary, then the parking brake cable can be adjusted.Operation: Flushing the brake fluid removes old or contaminated brake fluid from the system replacing it with fresh brake fluid. Advice: Brake fluid is a hygroscopic fluid, which means that it is in its nature to absorb moisture from the air. Over time the amount of moisture accumulated will decrease the efficiency of the fluid to act hydraulically. Moisture in the brake fluid can also cause corrosion in the system. Brake fluid should be flushed every two years. Recommendations: Brake fluid
Apr 01, 2012 | 1994 Chevrolet K1500
How do you release the rear brakr shoes to remove the drum and bearings?
Remove or disconnect the following:
  • Rear wheel
  • Wheel speed sensor, if equipped
  • Brake drum, bearing and spindle assembly
  • Brake shoe hold-down springs and pins
  • Brake shoe assembly from the wheel cylinder and anchor block
  • Parking brake cable
  • Lower return spring
  • Upper return spring
  • Primary shoe from the strut and brake shoe adjuster
  • Parking brake return spring
  • Secondary shoe from the strut support
I hope this answers your question. Best of luck!
Greg
Jun 28, 2011 | 2003 Ford Focus
How do I get the rear spindle off so I can replace the emergency brake shoes on my 2006 chrysler pacifica?
Adjustment
  1. Place parking brake lever in -full released- position.
  2. Raise and support vehicle.
  3. Remove plug in parking brake shoe support to access adjuster star-wheel.
  4. Through the access hole, rotate the adjuster star wheel in the following direction to expand the shoes outward against the drum:
    1. Left brake - Rotate star-wheel toward rear of vehicle.
    2. Right brake - Rotate star-wheel toward front of vehicle.
  5. Using an appropriate tool, turn adjuster star wheel until wheel will not rotate (dead lock).
  6. Back off adjuster six detents (teeth).
  7. Rotate wheel, checking for light drag. If drag is too heavy, continue to back off adjuster one detent at a time until light drag is present. Do not back off star-wheel more than 17 detents from wheel lock.
  8. Install access plug.
  9. Adjust opposite wheel parking brake shoes using same method.
  10. Lower vehicle.
  11. Apply and release parking brake lever once to ensure proper operation of parking brakes.
Removal & Installation NOTE The following procedure may be used to remove shoes on either side of the vehicle.
  1. Lock out automatic adjuster in parking brake lever.
  3. Access and remove rear hub and bearing.
  4. Remove parking brake cable bolt at knuckle.
  5. Completely back off parking brake shoe adjustment.
  6. Remove parking brake shoe adjuster spring.
  7. Remove shoe adjuster.
  8. Remove upper brake shoe hold-down clip and pin.
  9. Remove lower brake shoe hold-down clip and pin.
  10. Remove upper and lower shoes with return spring from shoe actuator.
  11. Remove return spring from shoes.
    Fig. View of the actuator (1), support (2), adjuster spring (3), return spring (4), caliper adapter (5), shoes (6), hold-down clips and pins (7) and adjuster (8)
To install:
  1. Install return spring between upper and lower shoes.
    NOTE Before installing shoes on actuator, make sure actuator hooked to rear cable is positioned with word -UP- facing outward.
  2. Install upper and lower shoes with return spring on shoe actuator located on parking brake cable.
  3. Install lower brake shoe hold-down pin through rear of support and lower shoe, then install hold-down clip.
  4. Install upper brake shoe hold-down pin through rear of support and upper shoe, then install hold-down clip.
  5. Install shoe adjuster. Place end of adjuster with star wheel upward.
  6. Install parking brake shoe adjuster spring.
  7. Install bolt securing parking brake cable to knuckle and tighten bolt to 21 ft. lbs. (28 Nm).
  8. Using Brake Shoe Gauge, Special Tool C-3919, or equivalent, measure inside diameter of parking brake drum portion of rotor.
  9. Place Gauge over parking brake shoes at widest point.
  10. Using adjuster star wheel, adjust parking brake shoes until linings on both park brake shoes just touch jaws on gauge. This will give a good preliminary adjustment of parking brake shoes, before a final adjustment is made at end of this procedure.
  11. Install hub and bearing with wheel speed sensor as well as all components necessary to access it.
  12. Lower vehicle.
  13. Unlock automatic adjuster in parking brake lever.
  14. Perform final adjustment of parking brake shoes
  15. Adjustment This vehicle is equipped with permanently sealed rear wheel bearings. There is no periodic lubrication or maintenance recommended for these units.
    1. Raise and support vehicle.
    2. Remove wheel mounting nuts, then tire and wheel assembly.
    3. If equipped with AWD:
      1. Remove cotter pin, nut lock and spring washer from half shaft.
      2. While a helper applies brakes to keep hub from turning, remove hub nut and washer.
    4. Remove brake caliper and rotor from hub and bearing assembly.
      Fig. Hub assembly
    5. Disconnect vehicle wiring harness connector at wheel speed sensor connector.
    6. Unclip wheel speed sensor connector from spare tire mounting support.
    7. Disconnect two sensor cable routing clips on rear suspension crossmember.
    8. Disconnect two sensor cable routing clips along toe link.
    9. Disconnect sensor cable from bracket on brake support.
    10. Completely loosen, but do not remove four bolts fastening hub and bearing in place. Once loosened from threads in hub and bearing, push bolts up against rear of hub and bearing to keep brake support plate in place when hub and bearing is removed.
      Fig. Rear hub and bearing mounting bolts
    11. Pull hub and bearing off knuckle and half shaft (if equipped with AWD), then thread wheel speed sensor cable through hole in brake support plate as it is removed with hub and bearing.
    To install:
    1. Position hub and bearing bolts though rear of knuckle and parking brake support just enough to hold support in place as hub and bearing is installed.
    2. Install hub and bearing by first feeding end of wheel speed sensor cable through hole in bottom of parking brake support. As this is being done, if equipped with AWD, slide hub and bearing onto half shaft. Place hub and bearing through brake support, onto knuckle, lining up mounting bolt holes with bolts and placing wheel speed sensor head at bottom.
    3. Install four bolts fastening hub and bearing in place. Tighten mounting bolts to 60 ft. lbs. (81 Nm).
    4. Place wheel speed sensor cable routing grommet into bracket on parking brake support.
    5. Route wheel speed sensor cable along toe link and rear suspension crossmember connecting routing clips where shown.
    1. Connect vehicle wiring harness to wheel speed sensor connector.
    2. Install brake rotor and caliper.
      1. Install washer and hub nut on end of half shaft.
      2. While a helper applies brakes to keep hub from turning, tighten hub nut to 180 ft. lbs. (244 Nm).
      3. Install spring washer, nut lock and cotter pin on end of half shaft.
    4. Install tire and wheel assembly. Install and tighten wheel mounting nuts to 100 ft. lbs. (135 Nm).
May 18, 2011 | 2006 Chrysler Pacifica
The rear passenger wheel is making a grinding /rubbing noise is it an easy job to repair also there seems to be more brake dust on that wheel is this the cause of the problem due to the wheel bearing ps...
This definitely sounds like a wheel bearing going out, or possibly the rear brake shoes/pads are worn out. Either way you will have to take the wheels off to determine the cause of the noise. Changing the wheel bearing or brake shoes/pads is not that difficult of a job and with the right instructions, you will be back on the road in no time. For detailed information on changing the wheel bearing, please go here. If it turns out to be a break shoe/pad, then please go here for detailed instructions on changing brake pads/shoes.
May 02, 2011 | Renault Sport Cars & Trucks
I have a problem with one of my air max is flat it is somthing to fixed?
What do you mean flat like the bottoms? I have a pair of them and they are suppose to be the same exact shoes just opposite feet, so of one is different then the other that could affect you foot while playing and could potential cause problems. If you could tell me more of what is wrong I could help because I am a little confused on what you mean flat. The bottom of the shoes are suppose to have an indent on the inside like the indent on you foot has (arch of your foot). Now if you foot starts to bother you because the shoes is flat then you can add and insoles with an arch to help. I found they help a lot with shoes even my tennis shoes.
Mar 18, 2011 | Nike Air Max CourtBallistec 1.2 Tennis...
How do you remove rear axel to change bearings? 97 town car
you don't remove the axle to remove wheel bearings. take off tire, take off brake shoe, take off rotor, then next to come off is the wheel bearings
Dec 19, 2009 | Lincoln Town Car Cars & Trucks
1993 Ford F-150 drum brake problem
It appears the rear axle shaft seal is leaking. You will need to pull the axle and replace the seal. Then check the rear end for adequate gear oil. The iron filings I am not to sure about. It sounds as if something came loose from the brakes or brake hardware and got chewed up in the drum. You will need to replace the brake shoes and maybe the brake hardware kit. Always change the shoes or pads on both sides when working on brakes, rear or front. If the inside of the drum is not perfectly smooth it will need to be turned or replaced. If this were brake fluid leaking from the wheel cylinder the master cylinder would be low on fluid and your brake pedal would go down much further than normal.
Jul 18, 2009 | 1998 Ford F150 Regular Cab
Air Tools & Compressors Logo
423 people viewed this question
Top National Detroit Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a National Detroit Air Tool and Compressor Expert? Answer questions, earn points and help others
