SOURCE: how do I change name
From the phone connected to Jack 01 or the authorized phone (generally 101) press PROG and dial **1234 Dial 004 and ENTER and dial the ext number of the phone you want to change Use the keypad to enter the name (you have Upper and Lowercase letters) and the arrow key to step to the next character. When you finish, press STORE.
Carl
SOURCE: How can I set the number of rings on our Panasonic
it's best to have your local panasonic dealer/serviceman do it, because it will require you to know the installer programming password which the installer sets, and it requires you to know the inbound call paths so you set the correct timer (all very simple if you have a computer hooked up and own the programming software, but a pain if you are trying to program through a phone)
SOURCE: I have a PANASONIC KX-DT333
I don't know about a handset, since mine doesn't have a dial, but the phone underneath the handset has to have a button programmed with the lines you use in order to work. By default, the system has some number of Single CO buttons assigned in numerical order from the bottom to the top and left to right. You can test that by pressing PROGRAM, press the line buttons in sequence, and reading the display. They will say CO 001, 002, 003 etc. If they don't, you can always dial 0 001 store, 0 002 store etc and get the line appearance back.
This solution works in a small system and is very basic. It doesn't take a T1/E1/PRI or group CO buttons. into consideration. Such a solution is beyond the scope of a free forum.
Carl
SOURCE: The hold music on our
Depends. If it's the "circus" music, then you need to add a music source at the cabinet and some programming is required. If you already have a music source, it can be changed. We us a promotions on hold company or the "canned" music from Intellihold.
Carl
