I have an older air conditioner that needs the freon Charged but i cant find the hook ups
  • 434 Answers
They don't put charge ports on them. You have to by piercing valves to add the ports. They are generally hard to come by
Posted on Jun 24, 2009
I have an older 8000 btu unit - i have no manual. its 98 outside - when i start up this unit , should i have it on hi- med - or lo ? if i run it too hard will i freeze it up?
If everything is clean and the unit is properly charged with freon then it should not freeze up and I would start it anywhere you want to as that just controls the fan speed. It's108 here. Best of luck and thank you.
Jul 22, 2011 | Kenmore 8,000 BTU Single Room Air...
How do I recharge the freon in my unit? model is 38CKB060300
Hello, freon should be charged by a hvac technician with a epa card. But the way you charge it in is hook up the manifold gauges to the unit tjen take the yellow and hook it up to your refrigerant bottle. If this is a R-22 unit then you add vapor refrigerant to the low side of the system untill your superheat is correct if it is a fixed orifice system, however if it is a txv system then you chek the subooling. If it is a 410a system then the same principle applies however you flip the cylinder upside down and add liquid refrigerant through the low side a little at a time here is a link that shows you proper charging methods http://www.air-conditioning-and-refrigeration-guide.com/charging-air-conditioning-systems.html.
May 27, 2011 | Carrier 38CKC036 Air Conditioner
My Hitachi airconditoner 0.8hp temperature stay at 23c and 22c even i adusted it to 21c or lower. What seems to be the problem? please help
How long you have been using your air conditioner? Older air conditioner needs to be cleaned at least quarterly and if necessary be charged with freon to enable a normal cooling system.
Nov 08, 2010 | Hitachi Heating & Cooling
Why did the can of R134 freeze when I charged the air conditioner on my 97 Chevy Cavalier? The low side line to my air conditioner (where i hooked up the can of r134) froze as well and my air conditioner...
History?was it working before? you cant just hook up a hose and put it in. First find out why compressor wont run, If it needs compressor, it needs a drier and orifice tube, put on a vaccuum pump for 1 hr then recharged with the correct amount of r134. You need someone who knows a/c to look at it.
Jul 22, 2010 | 1997 Chevrolet Cavalier
Ac's are over charged, installer says they come fully charged from Goodman.... having many problems now. What is up?
they come with a factory charge for a set line length but quite often they need more freon. Have freon level checked by another company.
Aug 11, 2009 | Heating & Cooling
Air is comming out just noy cold enough
if it is a window unit check the capacitor you cannot hook guages up to it. to check freon level. if it is 3 years or older replace it. they are much more efficiant. DO NOT LET A COM PANY PUT FREON IN IT IT WILL WORK FOR A WEEK OR 2 THEN IT WILL NOT
Aug 06, 2009 | Amana Heating & Cooling
Air unit freezig up after 8hours or so of use on rv fithwheel camper
Sounds like you need to recharge system with freon. Hope this helps :>)
Jul 13, 2009 | Dometic Rooftop RV Air Conditioner
Air conditioner cant keep up and just keeps running!
IF IT WORKED BEFORE THEN IT COULD BE A CLOGED AIR FILTER. OR CHECK FOR CLOSED VENTS. WINDOWS OR DOORS NOT AIR TIGHT .
THEN IT MAY NEED TO BE CHARGED WITH FREON.
Jul 10, 2009 | Ruud Matching Split Air Conditioner
How much should it cost for an air conditioner charge-up? I have not had the freon replaced in 2 years
shouldn't be more than $125.00 If you need freon,you have a leak.They do not ever need charged unless the system leaks.Good Luck!!
May 05, 2009 | 2006 Saturn ION
Heating & Cooling Logo
50 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
