Question about Xerox Office Equipment & Supplies
99008:00:385 does this code mean I have had a power surge to the printer
  • Brad Brown May 17, 2014
    Hi Roy Potter, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? What model?
  • Roy Potter
    Roy Potter May 17, 2014
    Xerox 8570 Colorqube
Canon image RUNNER 6000 Copier error E 000001-0000
A E000001-0000 is a error code for the fuser unit. It means it is not warming up to correct temp. Also, it may show up after a power surge or power lose. You may be able to reset it in service mode.
Nov 14, 2010 | Canon imageRUNNER 6000 Copier
Fault code pl48 displayed on samsung v+ box and wont start up
Hi, dont know what the code means but these boxes are problematic with power surges, contact virgin, they should replace it, and invest in an surge protector.
Oct 30, 2010 | Samsung HDTV Digital Terrestrial Receiver
The printer is HP LaserJet III . Please - what means the message "50 service " on the panel ? Thank you! MP
A 50.4 code is bad line voltage. Don't plug it in a surge protector.
Any other 50 error is a fuser problem. Turn the printer off for at least 10 minutes. Power it back on. If the error returns, replace the fuser.
Oct 21, 2010 | HP LaserJet IIIp Printer
Das gerät sharp al 1252 arbeitet nicht mehr. im display erscheint h und 4 abwechselnd blinkend. bitte um hilfe. danke.
The error code H4 means that you have a problem with the fuser unit. It is not warming up correctly. Also, the problem maybe that you may have had a power surge.
Sep 06, 2010 | Sharp AR-5316 Advanced Digital Imager...
Model c6180 printer gives improper shutdown error
The printer is not getting enough power. When you get this error message it means the printer is being turned off by unplugging the power cord. In this case it maybe that the printer is not getting enough power due to being in a surge protector or perhaps the power module is no longer holding power correctly.
First step is to disconnect printer from any power strip, surge protector, or extension cords and plug in so directly to the wall. If printer still will not stop looping cycle you may need to contact hp for a new power module.
Sep 25, 2009 | HP Photosmart C6180 All-In-One InkJet...
The Mx310 will not power on. We had a few bad storms this week but the mx310 is on a surge protected outlet.
Those surge protectors are not really a good protection in heavy storms which means that the power unit did get damahged and therefore you may have to try and obtain a new power unit ... mybe try another unit that you are sure about its working condition to prove the problem. It may even be the printer itself the got damaged
Jul 06, 2009 | Canon PIXMA MX310 All-In-One Printer
Hi all...!!! Power failed and came back minutes later. Can't start HP Media Center M7060n Green light on back flashes slow when power not connected, slower when power cord connected but I press the ON...
On HP computers, I believe that this means that the power supply or the motherboard is bad. I assume that the outage was due to the thunderstorm and you may have received a surge. In your manual, there should be diagnostic light codes where they will outline the exact meaning. Again, to the best of my knowledge, this means that there is a bad power supply or a motherboard.
If you need further help, reach me via phone at https://www.6ya.com/expert/jarrad_11786570be7a2abd
Jun 10, 2009 | HP Media Center m7060n PC Desktop
Hp laserjet printer 2840
Most surge protectors only protect up to a certain limit. If you had a large surge, then i would say the power board in your printer has been zapped. I would suggest you purchase a new or second hand printer to replace yours, unless your willing to pay more than the printer is worth to fix it.
Another thought is that the problem could be the actual power point it was plugged into. Try plugging it in to another power outlet that you know is working.
May 14, 2009 | HP LaserJet 2820 Printer
Getting code H 3
The printer repair guy just left. I'm paraphrasing what he told me:
The Sharp MX4501N was displaying the error: H3-04. This does mean that the printer was reading an above average temperature for the fuser, for some reason.
He said that in his experience, 90% of the time, this is due to power surges/spikes and not an actual incident of the fuser over heating. A good surge protector isn't normally enough and he recommended that we look around for a cheap UPS to condition the power.
Other things that can cause a higher than average reading of the fuser can be caused by paper jams, where a piece or pieces of the paper are lodges inside, insulating the fuser and restricting air flow to the internal compnents. Printing 15-25 blank sheets through the copier can usually dislodge these. If not, call for assistance.
In order to clear the error code (H3-04) from possible powewr surges/pikes, I was given the following code: #P, *, C, 1,4 PRINT
This will remove most of the codes restricting printing to the copier, however, should the code reappear, contact customer service and arrange for a visit from the local repair person.
I hope this helps anyone else who may run in to the same problemThe error: H3-04. This does mean that the printer was reading an above average temperature for the fuser, for some reason.
90% of the time, this is due to Power surges/spikes and not an actual incident of the fuser over heating. A good surge protector isn't normally enough and recommended that we look around for a cheap UPS to condition the power.
In order to clear the error code (H3-04) from possible power surges/pikes, I was given the following code: #P, *, C, 1,4 PRINT
May 11, 2009 | Sharp AR-5316 Advanced Digital Imager...
My computer tell me that my printer as a error code 20
Error code 20 in HP printers usually means you are trying to print to a non-default printer. try setting your D7200 as the default printer. Here is the direct link to HP about your problem:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00759728&jumpid=reg_R1002_USEN
Jan 07, 2008 | Office Equipment & Supplies
130 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
