Question about Sony Audio Players & Recorders
1038858 Why does BD function shows no input and (BD optical)System is not working on BD
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 110 Answers
Often a reset will solve the problem. google your make and model no how to reset.
Posted on May 17, 2014
How can audio fiber cable be activated on samsung ht-c6500
Fiber Obtics is activated all the time on most units. take a look at the fiber connector, if you push the little door on the connector and look in side you should see a fiber optic light glowing red. If not there is a problem with the units Digital.
1. Connect the digital input(optical) on the product to the Digital output of the external digital componet.
2. Press the FUNCTION button to select D.IN input.
* The mode switches as follows: BD/DVD -D.IN-ONLINE-HDMI 1-HDMI-2-FM.
Apr 01, 2017 | Samsung Audio Players & Recorders
Configuring a Sony STRDH510 - 3 HDMI & 1 composite input
Is the composite/analog signal going into the same input as one of the hdmi's? i.e. DVD,BD, etc.? If so, the receiver can only look at one of those signals at a time. To use two different signal types going into the same function, you will have to manually select where you want the receiver to look - either hdmi, analog, optical, etc. The receiver defaults to auto-selecting which signal to look at, and will always look for a hdmi signal if one is available.
Dec 26, 2012 | Sony STRDH510
I have connected to my 2311: HDMI 1: Oppo BDP 83 HDMI 2: Denon DVD 1740 HDMI 3: Apple Mac Mini Issue: The Mac Mini works fine and I have audio and video through the receiver, but for the BD and DVD only...
hi,
You have to check the digital audio assignment of you AVR for HDMI 1 and HDMI 2. There is three options for the digital audio for HDMI 1 and HDMI 2. You can set it as optical ,coaxil, or the HDMI itself. In you receiver the assignment may be in optical input or in coaxial input for the two HDMI inputs.
1. Go to the system setup
2. Select input setup
3.Select input assignment.
4. Select all the three input ,you are using as HDMI
ok
Apr 11, 2011 | Denon AVR-2311 Receiver
NO OPTICAL SOUND I connected HDMI from reciever to TV, HDMI from PS3 to TV, Optical from PS3 to Receiver (PS3 Sound settings switched to Optical, with Dolby Digital 5.1CH, and Dolby DTS 5.1 selected) ...
I think your problem might be at the digital audio setup at the receiver. To fix this, go into the setup under digital audio and make sure that the input that your connected to is set to optical, not analog or coaxial. Example if your plugged into video 1, make sure that the audio setting corresponds to the optical input where your connected. Video 1-optical-1.
Good Luck
Jan 07, 2011 | Samsung HTC5500 Theater System
How do I get tv audio to play on the home theater system
This HTS isn't really designed to be a versatile processing center for external sources.
My advice is to treat TV-related audio as any other audio component. First, its best source will be the first device that processes it - cable box, sat box, gamebox, BD etc.
I'd also bypass this unit's video connections for those video sources and run them directly to your TV or monitor. The best unit for each function (audio or video) should get the best source directly.
Get the best-quality digital audio that unit will provide and run it into the HTS. This HTS has one optical (TOSLINK) digital input, so THAT would be where the best digital audio would enter it. Hopefully, your source uses optical audio output. Otherwise... analog audio is limited to stereo or derived Dolby Surround.
Sorry.
Dec 23, 2010 | Samsung HTC550 Theater System
Denon AVR-1908 speaker issue
Before we play taps and throw dirt on top of the Denon, perhaps a bit more triage is in order. I'm not certain who the patient is. Especially when you have "speaker issue" in the title. Are you saying there are some speakers that don't work ONLY with BluRay?
If it has NEVER worked the (unnamed) BD player or its cable(s) could be at fault, too.
What 'connections' are we talking about. HDMI, coaxial- or optical audio, 5.1 analog; to what input on the Denon assigned to what function?
Have you tried all audio paths out of the BD player? Is it configured to squawk in the right digital mode?
Do you have any other digital audio sources (CD/DVD) you could use to certify the audio paths that don't work with the BD player?
Apr 08, 2010 | Denon AVR-1908
Hi I have a Yamaha yht 292 surround sound system with a model htr 6230 reciever. I have a panasonic (42'') plasma HDTV (model TC P42X1) attached to the receiver by a HDMI cable. I also have a Samsung Blue...
As per HTR-6230 specifications (http://www.yamaha.com/yec/products/productdetail.html?CNTID=5028494&CTID=5000400&ATRID=1020&DETYP=ATTRIBUTE) the HDMI function is only "audio-passthru", which means your receiver is not able to get the audio from HDMI cable, it can only pass it forward to TV. You would need a receiver with "HDMI switch" to be able to listen to audio via HDMI cable. You can find such receiver by looking if it supports TrueHD audio (which can be transferred ONLY via HDMI cable).
With your current receiver, you can connect it to the Blue-ray player via Optical SPDIF cable. I have checked the specs and both receiver and BD player supports optical connection.
Feb 25, 2010 | Yamaha YHT-390 Theater System
When connecting hdmi out from my panasonic blue-ray player to the dvd input in my yamaha rx-v365 there is not audio or video,why?
There are several video and audio inputs named DVD. For video you have HDMI, component and composite. For audio you have standard analog stereo and digital coaxial spdif input.
You need to configure the receiver to use the correct inputs - that means HDMI and coax. Also you need to connect the BD player via coax spdif cable to the receiver, because rx-v365 doesn't support audio via HDMI. If BD player has only optical output, use DTV/CABL HDMI input and DTv/CABL Optical input on the receiver.
Nov 23, 2009 | Yamaha DVD-S661 HDMI DVD Player
I want 5.1 surroud sound from a panasonic home cinema system model number sc-ht1500 through a blue ray disc player bd-hp20s what audio leads do i need
TOSLINK (optical cable). do not forget to set audio output in the setup menu of the BDHP20 and select optical as an input on scht1500.
Nov 22, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
No Audio
What port do you have the HDMI from you BD player into on the 510. If you have it on the DVD port then fiber optic will do you no good, the DVD HDMI only supports digital coax, the Video2 HDMI only accepts fiber optic, and there is an extra fiber optic for the Sat input. If your BD player does not have digital coax out, or if you dont want to buy another cable, just move the HDMI from DVD to Video2 on the 510. I am willing to bet you have the BD player plugged into the DVD HDMI port and the fiber optic cable from you BD player to the Video2 fiber input.
Dec 18, 2007 | Sony STR-DG510 Receiver
29 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
