Question about Cannon Cameras
IXUS 900 Ti the len is retracted after fell.
I have fallen the camera on the floor when I wanted to shoot picture.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 126 Answers
Main board failed needs specialist work not somthing a lay person can repair
Posted on Jun 17, 2014
3 Suggested Answers
t00nz
  • 4738 Answers
SOURCE: Canon Ixus 900 Ti ~ Lens error Restart camera
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Posted on Jun 18, 2010
  • 420 Answers
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
Posted on Sep 11, 2010
My canaon camera len is not going in it is showing error and asking for restart please solve my problem it is ixus 900ti and it not fallen down
Lens errors are fairly common. Usually sand or grit interfering with the lens extension mechanism is usually the culprit. A single grain of sand can do it. Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Sep 11, 2011 | Canon Digital SD900 / IXUS 900 Ti Digital...
Jun 18, 2010 | Canon Digital SD900 / IXUS 900 Ti Digital...
Oct 08, 2009 | Canon Digital SD900 / IXUS 900 Ti Digital...
Canon Ixus 900 Ti started taking bad pictures
Smoke out of the speaker holes when the flash fires is just collected dust burning off no problem
Sep 18, 2009 | Canon Digital SD900 / IXUS 900 Ti Digital...
My canon 550 has a len error an saying E18!
Hello there,
The E18 error is related to the LENS not able to retract fully. If it is still under warranty, I would advise you bring it to the nearest service center. This is to avoid further damages. Otherwise, you can try a few things below.
There are a couple of things you can do.
1. Turn it on and then off. Spray canned air around the lens.
If trick 1 will not work out, try this.
2. Make sure the battery is fully charged. Turn on the camera and then give it a couple of firm whacks on the side. Make sure nothing is blocking the lens and wait for it to fully retract.
Let me know how it goes.
Aug 29, 2009 | Canon Digital SD900 / IXUS 900 Ti Digital...
Lens error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Mar 23, 2009 | Canon Digital SD900 / IXUS 900 Ti Digital...
Camera fell on the floor (carpet) and now the
Your lens may need adjusting. This info may help . Other People solved problem. Lots of Info on this link.
http://www.fixya.com/support/t102982-e_18_problem
Mar 23, 2009 | Casio Exilim EX-Z750 Digital Camera
Stuck lens
The lens needs to be repaired or replaced. Could be one of several problems, sand, impact damage, broken gears. A professional camera repair shop should be able to do this for a reasonable price.
May 06, 2008 | Canon Digital SD900 / IXUS 900 Ti Digital...
Error 18
The "E18" error code indicates an error that involves the lens unit or lens cover. This error may appear where the lens is prevented from properly extending or retracting such as, for example, when pressure is applied to the lens or the area surrounding the lens while handling the camera. The error may also be displayed if the lens unit/camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera. Solution Check the following when you operate the camera to avoid applying pressure to the lens and surrounding area: - Hold the camera so that your fingers do not touch the lens unit when you are shooting. - Make sure the camera is off before you put it back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.
Aug 31, 2005 | Canon PowerShot SD500 / IXUS 700 Digital...
Cameras Logo
16 people viewed this question
Top Cannon Cameras Experts
Computer Links
Pavel Pranovich
Pavel Pranovich
bhargav
Are you a Cannon Camera Expert? Answer questions, earn points and help others
