Defination of Abbrivated term of CCD, AGC & PWB in connection with kyocera KM-6030
  • 2,013 Answers
How to remove C6400 error in kyocera km 6030
http://www.copytechnet.com/forums/kyocera-mita-copystar/11146-kyocera-km-4050-c6400-error-codes.html
Dec 02, 2016 | Kyocera Office Equipment & Supplies
C9050 code
Kyocera code c9050 Printers & Copiers Questions ... - Fixya
www.fixya.com > Forum > Tags > code c9050 > Printers & Copiers
Kyocera printers & copiers code c9050 related questions and answers. ... error code C-6 for kyocera km 1500 blingking code C-6 in my kyocera km 1500 c6-400
Oct 15, 2015 | Cars & Trucks
How to solve the km 6030 machine error code c7200
Hi Farid,
Error Code c7200 means : Broken internal thermistor wire • The thermistor output value is 4.5 V or more.
Because of : Poor contact in the connector terminals. Defective developing humidity sensor.Defective engine PWB.
Need to replace the defected part. please visit to the nearest service center.
Thanks
Aug 18, 2015 | Kyocera Km-6030 With Feed, Finisher, Bank,...
C3300 kyocera km 6030
Open the Glass and clean the opitcals. dirty mirrors and ccd. Run mode 906 after.
Mar 08, 2014 | Kyocera Km-6030 With Feed, Finisher, Bank,...
Kyocera error c7200
km 6030 machine have a code on screen c7200 so how i solve it
Dec 18, 2013 | Kyocera Km-6030 With Feed, Finisher, Bank,...
In KM-6030 C4110 appear
laser scanner unit and main PWB check for correct operation
Oct 27, 2013 | Kyocera Km-6030 With Feed, Finisher, Bank,...
How do I install driver for Kyocera CS 5035 on MAC
Kyocera and Copystar models are the same just replace KM with CS.
The following instructions should help you. TO download the current driver use this link to th emanufacture website; http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?rid=18657.
Kyocera Printer Drivers and Mac OS® X 10.5 Leopard FAQ:
Is the installation for Mac OS X 10.5 the same as for Mac OS X 10.4 and earlier? Mac OS X 10.5 introduced a new printing architecture that requires changes to the installer and installation process. For this reason, Mac OS X 10.5 requires a new printer driver installer.
I cannot see my Kyocera AppleTalk® printer. How can I make it visible to OS X 10.5? AppleTalk is disabled by default in Mac OS X 10.5. Enable AppleTalk to discover your Kyocera printer.If you use the Kyocera installer, a message will appear, asking you to enable AppleTalk. Click Yes to continue the installation.
I cannot find Printer Setup Utility on Mac OS X 10.5. Is it still supported? Apple has removed Printer Setup Utility from Mac OS X 10.5. To install a printer, open System Preferences and click Print & Fax.
When I manually install a printer, multiple PPD files are listed for the same Kyocera model. Which should I choose? When manually installing a printer or changing a PPD for a installed printer, both Linux and Mac OS X PPDs are listed for some older Kyocera models due to a change in PPD handling in Mac OS X 10.5. Linux PPDs can be identified by the word Gutenprint in the PPD filenames.
Supported Multifunction Printers: KM-1650, KM-1815, KM-1820, KM-2050 ,KM-2530 ,KM-2550, KM-3035, KM-3050, KM-3530, KM-4030, KM-4035, KM-4050, KM-4530, KM-5035, KM-5050, KM-5530, KM-6030, KM-6330, KM-7530, KM-8030, KM-C830, KM-C830D, KM-C850, KM-C850D, KM-C2520, KMC2525E, KM-C2630, KM-C3225, KM-C3225E, KM-C3232, KM-C3232E, KM-C4008, KM-C4035E, CS-1650, CS-1815, CS-1820, CS-2050,CS-C2525E, CS-2550, CS-6030, or newer. Supported Printers: FS-820, FS-920, FS-1018MFP, FS-1020D, FS-1030, FS-1100, FS-1118MFP, FS-1300D, FS-1800, FS-1800+, FS-1900, FS-1920, FS-3800, FS-3820N, FS-3830N, FS-6020, FS-6026, FS-9100DN, FS-9120DN, FS-9500DN, FS-9520DN, FS-C5016N, FS-C5020N, FS-C5030N, FS-C8008N, FS-C8026N, FS-C8100DN, or newer.
I hope this is helpful,
Shawn
Mar 08, 2011 | Kyocera Copystar CS-5035 Copier
Kyokcers km 16 20 error code c 6 400
C6400 Zero-cross signal error
While fuser heater ON/OFF control is
performed, the zero-cross signal is not
input within 3 s.
Defective PWB. Replace the engine PWB or power source
PWB and check for correct operation.
taken from different kyocera copier but it will be the same sounds terminal
check fuser if looks ok main board if that the case may as well get a new copier
Oct 12, 2010 | Kyocera KM-1505 Copier
Kyocera KM-C4035E Colour Printer Copier. Help with system error code C2300
Fuser Motor Error. The motor speed is not stabile for 2 sec or more. Detection begins 1 sec after motor drive ON signal is output.
1) Run sim U030 (fixing motor) to check for drive problems,
2) Reseat YC27 @ engine PWB and motor connector,
3) Run sim U030. Check YC27-A10 @ engine PWB for a low output. If yes, repl fixing motor,
4) If no, repl engine PWB.
Feb 24, 2010 | Kyocera KM-1505 Copier
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
