Question about Sony MEX-BT4000U CD/MP3 Car Radio with USB port and Bluetooth support
I can't get my Sony unit to switch on, however I can load and unload a CD
  • 162 Answers
Check to make sure you have 12V + on the red wire. (Ignition)
Posted on Jul 08, 2014
Fire department says it is leaking at pressure switch, does this unit have a unloader valve and a check valve?
It would have to have a check valve and a unloader valve or it could not start again with any air pressure in the tank. The unloader is in the limit switch, should see a small plastic air line going into the limit switch, when the limit switch shuts off the electric motor it drains the pressure in the cylinder so there is no load on the compressor so it can start, so if there is air coming out of the unloader when the electric motor is shut off it is the check valve if it is coming out all the time even with the motor running it is the unloader in the limit switch.
Apr 21, 2016 | Air Tools & Compressors
Compressor UP6 25 125, runs all the time but is only under load for a short time, should it shut down between loads?
This unit will shut down if unloaded for a set period of time. Usually 5 to 10 minutes. This time could be longer if some one has changed it from the factory setting. There is a timer in the control box that starts counting down when the unit unloads. If it stays unloaded long enough for the timer to count down the unit will stop until the air pressure drops to the low set point on the pressure switch. It will then start up. If the unit loads before the counter counts down the timer starts from the beginning when it unloads again. This cycle continues until you manually shut it down or you stop using air long enough for the timer to reach Zero and shut down.
Apr 22, 2011 | Ingersoll Rand UP6-25-125 120 Gallon...
I get E-01 error of my cd changer
The fault is actually inside the CD changer, when one disc is selected the changer moves the gearing inside to slot from one CD to the other.
While this operation is happening the selection arm jams !!
Then giving an error at the radio display..
To fix the problem, disconnect the CD changer from the trunk of the car,
take off the top plastic slide cover,
with a small screwdriver slowly move the gearing so that the CD disc holder will move back to the load - unload position.
Pop out the CD holder.
Replace unit, reconnect the optic and power lead, switch on radio and the unit will work again,
grease the moving parts with light lubricant
Good Luck
Feb 24, 2011 | Mercedes-Benz C-Class Cars & Trucks
Sony CDX-626 10 disc compact disc changer will not load and play selected disc. It loads and unloads disc #1 then loads and unloads disc #2 and so on loading and unloading discs but not playing any
It needs a new optical eye,also called laser eye.It's probably close to $100 total to replace,but I haven't worked on them in 10+ years so you may want to call an electronic shop anywhere and they should be able to give you a pretty good estimate if you ask specifically for that part change/repair.Greg
Feb 11, 2011 | Sony Car Audio & Video
Switches off for no apparent reason. Can't see an 'on' button. Can only get it going again by loading and unloading a CD,
To switch the unit on you normally have to press the source button, and too turn it off you press and hold the source button
Feb 21, 2010 | Kenwood KDC-5021 CD Player
Ford cd changer problems
CD player is not working. Motor will not unload or load discs. It will play CDs fine but cannot change them. Unit will need to be repaired by an audio specialoist or replaced.
Sep 07, 2009 | 2003 Ford F250 Super Duty Crew Cab
Disk tray wont open
Either loading belt for mech has gone meaning not unloading for door eject,or door belt has gone
Dec 28, 2008 | Sony CDP-XE570 CD Player
Sony DVP-CX995V
Its problem of incomplete unloading of CD tray so system control in player sense it and generate command to close it.
CD Loading mechanism needs service and cleaning to loading belt.
If you have electronics experience, you can make it easily. let me know if you need further info.
Nov 20, 2008 | Sony DVP-CX995V Multi-disc DVD Player
Jensen VM9511TS AM/FM/CD/DVD/SD
you may have to open the unit up and manually turn the unload and load gear to eject the DVD from the carriage. The load and unload gear is a round gear located under the DVD carriage and is attached to the load and unload motor
Sep 20, 2007 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Sony MEX-BT4000U CD/MP3 Car Radio with USB port and Bluetooth support Logo
65 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
