Question about Zebra 110PAX4 Thermal Label Printer Print Engine - P/N 113el01-00000
Printer not calibrating labels right
When load with label the print will feed out the two labels like it should but when it stop, it stop half way on the 3rd label.
itdude4321
  • 13 Answers
SOURCE: Zebra S600 printer continues calibrating
The factory default settings for the S600 is to auto calibrate every time the printhead is closed and every time the power is cycled. If the media sensor is not positioned correctly for the media you are using the label size will not be detected during a calibration. You mentioned the media has no markings, doe sthe media have a space between the labels? If so, the media sensor may not see the gap in the labels adn therefor is not calibrating properly or not calibrating at all. Check the media sensor position. I have found that the media sensor must be at least 1" from the inner wall of the printer so it doesn't see the edge of the backing in oder to read the size of the labels.
Posted on Feb 02, 2008
SOURCE: Prints half the label.
Had this problem myself with an S600. Did a factory reset on it, and everything went back to normal. Hope this helps.
Posted on Jul 03, 2008
SOURCE: TLP 2844 skips 15-16 labels then prints intended label
It sounds like they may need to set their "Q" values for the labels they are using.   If that isn't it, we may need more info - are they using Zebra brand or custom labels?
To start with, I would ask them to try adding these "Q" value commands: q456 Q152,24
If that doesn't work, then maybe they can provide the other info mentioned above so we can understand the problem better.
Posted on Jan 05, 2009
bartech9
  • 155 Answers
SOURCE: Manual calibration of labels not
Press pause and feed keys and turn on the printer, release the keys until it begins to move the label. Expected to finish printing, the printer was calibrated.
Posted on Mar 16, 2009
  • 97 Answers
SOURCE: Zebra LP 2844 doesn't feed label all the way out
Hi Brian,
When the last label printed is still under the printhead, that means the printer is in "rewind mode". There should be an option for "tear off" mode in the printer driver. This is the mode that pushes the last label printed out to the tear bar. The printer will then "backfeed" when printing the next label. Peel off mode is used if you want to print a label and have it "peeled" off the liner so that you can just pick up the label off the liner and apply it. That takes the rewind option to be installed.
Watch out though, if you are using a label software package, there might be a setting in the label format setup for "tear off" which usually overrides the settings in the printer.
Hope that helps !
Posted on May 06, 2010
Printing on two labels
lets start with the basics.
Do a calibration of the label to the printer : -
1/ Turn off the power
2/Press and hold the feed key
3/ Turn on power and wait for the green feed light to flash twice.
4/ Release the feed key
5/ The printer should feed and print the configuration.
Now press the feed key and the label should feed and stop at the gap.
If this does not work , then let me know via this page.or contact me at the link below
trev
thermal labels printers co uk
Mar 06, 2014 | Zebra TLP 2824 Printer
My Zebra ZDesigner LP2844 feeds a blank label after printing a label. How do I make it stop doing that?
Define your label size correctly. Measure your LABEL exactly, do not include the backing paper or the gap. Calibrate the printer. HOW?
Power off printer. Press and hold the green feed button down and power printer on. Count one, two and release green button. The printer will calibrate and move labels and then print some stuff on the label. Wait until it has comletely stopped. wait another few seconds and the press the feed key once. The printer will print "out of dump". You should now be ready to print again.
Aug 31, 2013 | Zebra LP 2844 Thermal Printer
How to calibrate the label in QL320 plus zebra printer?How to make it only feed 1 label per print?
create a text file called Calibrate.txt and in the text file type this:
~JC
^XA
^JUS
^XZ
then send the file to the printer using label vista.
this will then print 3 - 4 labels and stop.
once u press the feed button it will only feed one label.
Dec 10, 2010 | Zebra QL 320 Thermal Printer
Printer does not print in correct place after calibration, stops and says paper error
Sounds like the printer is not getting the proper calibration on the label being used. After putting printer in pause and pressing calibrate button, a good calibration is indicated by the labels feeding, a slight hesitation, and the feeding a couple of more labels at a faster speed. If the labels just feed and then stop, that is not a good calibration. Then you have to make sure the top and bottom media sensor are properly aligned.
Mar 01, 2010 | Zebra 110Xi III Plus Thermal Printer
Problem with my Zebra LP2824 printer
You have to calibrate the printer to solve this problem
Check following to solve this problem
1)Press the feed button and hold it for 1-2 seconds switching printer on.It will calibrate the labels.
2)Install Zebra Designer driver from CD.After installing Zebra designer Add printer Zebra Designer LP2824.After installing driver right Click the printer Zebra Designer LP2824 and go to printing preferences then select advanced option and calibrate printer.It will calibrate printer
3)Check the label size is properly set in printer or not.Label width and label height in printer settings should be same as label which you are using .
Aug 22, 2009 | Zebra Eltron LP 2824 Thermal Printer
Zebra stripe s500 skips 5 labels prints 1 skips 1
He are the steps you need to calibrate your printer
Label Length Calibration
Note: This is typically the only procedure required when first installing the labels.
1. Load the printer with media and ribbon.
2. Press the printer front panel MODE key until the CALIBRATE LED is lit.
3. Press the FEED key and allow the labels to feed.
4. When the labels have stopped press the MODE key once to save the value in memory.
Jul 10, 2009 | Zebra Stripe S500 Thermal Label Printer
Unable to print a 4X 6 label
asslam aleekum wr wb
mere pass zebra printer hina but us mian ak problem ya arha hian k us k print out blank arhha hian why?
plz mujhe batey
Apr 22, 2009 | Zebra Z4Mplus Label Printer
TLP 2844-Z is faded on the right half when it prints
It probably needs a print head adjustment or calibration.
Here is a link for the user guide,(it takes a minute to load and display) you will find cleaning and diagnosing tips :
http://www.systemsprintmedia.co.uk/downloads/ZEBRA%20TLP%202844Z%20MANUAL.pdf
If your zebra label printer is not feeding to the next label correctly it may need to be calibrated. Follow these steps to calibrate the printer:
  1. Turn off printer and have media loaded (on older Transports, with no ON/OFF switch, remove battery).
  2. Hold feed button down, and turn printer back on (on older Transports, re-insert battery) while holding down the feed button.
  3. When the light starts flashing, release the feed button.
  4. Printer light will turn green and advance a few blanks.
  5. After printer stops advancing and prints the internal information, press the feed button one time.
  6. You will get another label with the “Out of Dump” message on it.
  7. Printer is now ready for use.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 21, 2009 | Zebra TLP 2844-Z Thermal Label Printer
TLP2848Z blinking red, will not print
1: Is it a TLP2844 or a TLP2844Z.
Operationally they are completely different printers. TLP2844 uses ELP (Eltron Programming Language. but TLP2844Z uses ZPL (Zebra Programming Language). You need to calibrate the printer to the labels.
Calibration:
If its a TLP2844. Load media. Connect power.
Hold down feed key, power on, count one, two, release feed key. The printer will go through a calibtation routine and print config label. IMPORTANT - When it prints this label you must press the feed key and see the message OUT OF DUMP. Your printer will now be calibrated. Check this by hitting the feed key a few times and printer will feed one label each time feed is hit.
Calibration:
If its a TLP2844z.
Load media. Turn printer on and wait for green light (Approx 1 minute)
Press feed key and keep it pressed until green light blinks once, then twice, now release feed key.
Dec 22, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Intermec PC4 label printer
Your printer is not sensing the gap between two labels.Please try calibrating the printer for the gap.
Switch ON the printer while holding FEED key down, on printer start feeding label realese the FEED Key.
Printer will stop feeding paper after printing SELF TEST, Once again press FEED key for 3 seconds. Printer will enter into normal Mode.
Check now.
Aug 14, 2008 | Intermec EasyCoder PC4 Label Printer
Zebra 110PAX4 Thermal Label Printer Print Engine - P/N 113el01-00000 Logo
43 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
