Question about HP Color LaserJet 2600n Printer
Hi, I am getting faint reprinting down each page on my HP2600. Makes the whole document look bad. Is there a cleaning procedure that will fix this.
    Champion:
  • 220 Answers
Could be toner or transfer belt.
Posted on Jun 24, 2009
    Sergeant:
    Champion:
  • 253 Answers
Its your cartridge problem or may ink is finished
and for our technician help ucan call ua at toll free no 18884276640
Posted on Jun 23, 2009
Document not printing from top of page
This is a common problem with this model as it gets older the sponge on the feed solonoids becomes sticky and needs to be replaced. Also one or two of the clutches may need cleaning/replacing.
Feb 20, 2013 | Kyocera Mita FS 1010 Laser Printer
The documents are faded even after putting in a new cartridge
  • make sure you are using inkjet papers as inkjet printers work on inkjet papers.
  • Lift the printer access door, then remove the ink cartridges from the printhead.
  • Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
  • Close the printer access door.
  • Reprint the picture or document that had the quality problem.
  • if still light prints then proceed further
  • Print Test Page
  • Review the printed test page and verify that:
    • the left color blocks are gray, cyan, and black.
    • the right color blocks are magenta, yellow, and black.
    • each block is completely filled with color.
  • If no---> Clean Printhead, the On/Off light flashes during the cleaning procedure.When the On/Off light glows steady, print test page again.
  • If Yes---->The problem could be caused by the type of paper you are using.
May 28, 2010 | Kodak Office Equipment & Supplies
Phaser 3200 mfp laser printer leaves streaks on paper. First sheet is okay then rest get worst as printing continues.
One of two things.
If the streak is a line. No visible print in the streak, Then most likely the drun cleaning blade is bad and the drum unit will have to be replaced.
If the streaks are sort of reprint. a faint reprint of what is already on the page, then you need to replace the fuser.
Mar 25, 2010 | Xerox Phaser 3200MFP/N Laser Printer
Our Laser printer doesn't print on the left had side of the paper--well, very faint--the right side is just fine. I just replaced the cartridge. What is the problem?
If your printer prints like this:
657b300.jpg with the any color printing faintly down the page, then the problem is with the developer blades in the imaging unit. What happens is there are metal blades that meter the amount of toner that gets put on to the drum that makes the image on the paper. The toner is made up of fine particules of plastic. As the printer prints, some of this toner collects on the edge of the developer blades causing less and less toner to make it onto the page making the print look faint.
To correct this problem, you either need to buy a new imaging unit or clean the developer blades. There is a document on the internet that gives a detail instructions on how to do this, but, the link no longer works. I have a copy of this document, I will try to post it if people are interested.
Jan 15, 2010 | Samsung CLP 300 Laser Printer
Page two of a word document prints so every other line is faint
do 1 thing, save document-2 as a pdf file and try to print one document @ a time. it will resolve the issue.
Jul 24, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Samsung CLP-500 output problems
i have found that removing the toners, and shaking them side to side, while keeping them horizontal, which seems to spread the toner for even distribution. This can sometimes fix the problems with fading prints. hope it helps.
Margins i think might be a problem with the wysiwyg of the program, some don't do it well, but also excel in particular has a shrink to fit page option, you may find the percentage not at 100%. you can also copy an excel table to word and print from that if it is driving you nuts.
Jan 23, 2009 | Samsung CLP-500 Laser Printer
Ghost printing
Hi Phillip,
If you have changed the drum and toner, then check the fuser unit. The teflon coating on fuser film could be worn.
S88
Dec 16, 2008 | Brother MFC-8460N All-In-One Printer
Dirty printing job
Are they lines from one edge to the other in a straight line. Or is it faint reprint across the page?
Thin lines would most likely be a bad drum or cleaning blade.
If it is faint reprint it is the heat roller in the fuser.
May 22, 2008 | Xerox Office Equipment & Supplies
HP Color LaserJet 2600n Printer Logo
122 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
